Got a new wireless printer/MFC
by y_p_w. 02/22/19 02:48 PM
NM
by y_p_w. 02/22/19 02:47 PM
Names of brand names quality non-pro multi-meter
by JLawrence08648. 02/22/19 02:16 PM
Lady Luck
by CourierDriver. 02/22/19 02:06 PM
Ford MPG
by Zee09. 02/22/19 02:03 PM
Canucks in need of licensed ATF+4
by StevieC. 02/22/19 12:42 PM
Viscosity of Synthetic oil in the bottle
by JLR. 02/22/19 12:35 PM
2006 Tundra trans fluid change with Toyota WS
by njohnson. 02/22/19 11:32 AM
How do you prefer your vehicle seats?
by ZZman. 02/22/19 10:35 AM
GKN awd vs the Haldex in my Chevy Equinox
by wbwanzer. 02/22/19 10:28 AM
Craftsman Tools “Ultimate Collection”
by dkryan. 02/22/19 09:38 AM
Q 50 maintenance questions
by Robertslowpoke. 02/22/19 09:19 AM
No start
by Roughneck777. 02/22/19 08:24 AM
A Quick Question for ebay Sellers...
by Touring5. 02/22/19 07:38 AM
Small 4x4 with a 4 cyl and manual not to be found
by Elkins45. 02/22/19 07:17 AM
jcthorne, duckthis1, Roughneck777, KDW, avantika31
67313 Registered Users
106 registered members (007, 1978elcamino, 240_Ed, 19074, 2000Trooper, 8 invisible), 1,900 guests, and 53 spiders.
Topics284,665
Posts4,874,796
Members67,313
Most Online2,548
Feb 16th, 2019
propane or gas for generator #4810571
07/10/18 04:56 PM
07/10/18 04:56 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
bought a new generator from costco today. replaces my old 23 year old one. this one is dual fuel. propane or gas. mine old one is gas only and i have 20 gals stored for it.
now that i have the option of propane would that be a better way to go? or is gas still the best .
Re: propane or gas for generator [Re: WhyMe] #4810576
07/10/18 05:02 PM
07/10/18 05:02 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
Propane never goes bad. Do not use the smaller tanks, use AT LEAST the hundred pound tanks at minimum, smaller tanks somehow dont put out enough pressure and it wont run correctly.
A 20/30 pound tank will freeze up with any kind of demand worth running, and a 100lb is much cheaper to fill.
Re: propane or gas for generator [Re: WhyMe] #4810586
07/10/18 05:18 PM
07/10/18 05:18 PM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
How much do you plan on using the generator? I use mine once every 8 years.
Re: propane or gas for generator [Re: WhyMe] #4810646
07/10/18 06:33 PM
07/10/18 06:33 PM
ME
eljefino Offline
eljefino  Offline
ME
Even if you normally run on gasoline, finish it off with propane so it'll completely dry out the carburetor.
In the summer at least you could throw a 20lb bottle in a washtub full of tepid water to keep it from freezing up.
Liquid propane has somewhat less BTUs than gasoline per unit. I could get a 20 lb fill, which is 4.3 gallons, for $10.75 from BJs wholesale. That's $2.50 a gallon, a little cheaper than gasoline, for a little less power. But it's nice that I don't have a smelly gas can in my car. BJs claims DOT regs don't let citizens transport more than 90 lbs at a time, which to me, seems generous.
I have an aftermarket propane carb on my generator and several 20lb bottles. Will report how it works under extended heavy use.
Re: propane or gas for generator [Re: WhyMe] #4810659
07/10/18 06:48 PM
07/10/18 06:48 PM
Florida
chainblu Offline
chainblu  Offline
Florida
If I could do it again, I'd go with a dual fuel generator. During the aftermath of the last hurricane that came thru here, there was no gasoline to be found. However, you could get your propane tank refilled at several places.
Re: propane or gas for generator [Re: WhyMe] #4810670
07/10/18 06:57 PM
07/10/18 06:57 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
What brand did you buy? If it's a Generac, dual fuel could translate to twice as many things to go wrong. My 16kw standby Generac is 12 years old and is being held together by wire, zip ties and pressure treated wood.
For your original question, most people feel propane is safer than gasoline storage. Good luck with your purchase.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: propane or gas for generator [Re: WhyMe] #4810680
07/10/18 07:01 PM
07/10/18 07:01 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
cool
Re: propane or gas for generator [Re: WhyMe] #4810684
07/10/18 07:02 PM
07/10/18 07:02 PM
NY
mx5miata Offline
mx5miata  Offline
NY
Propane might be cleaner burning not as efficient or power output not 100% sure
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: propane or gas for generator [Re: NormanBuntz] #4810758
07/10/18 08:34 PM
07/10/18 08:34 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
Bought the champion brand. was on sale for 549.00 for the 7k model. seems to run pretty good. quieter than my old one. 3 year warranty
Re: propane or gas for generator [Re: mx5miata] #4810767
07/10/18 08:42 PM
07/10/18 08:42 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Truth - - unless the compression ratio is raised to take advantage of the high octane,
Power will be down only a little bit - - - BUT
You will burn a LOT more gallons of propane than gasoline.
Re: propane or gas for generator [Re: WhyMe] #4810798
07/10/18 09:26 PM
07/10/18 09:26 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Propane has a vaporization rate from each size tank. You need to find how many BTU of propane your generator needs per hour and that will tell you the minimum tank size for a given temp. What might be fine in the summer may not work in the winter.
A 20 lb tank is good for a test, but not to run it to power anything. Minimum of 100 lb tanks as you can bring them places to get filled. Better to get a tank that is 100 gal. Or bury a 500 or 1000 gal.
Never rent propane tanks.
2015 Ford F250 w/Powerstroke
Re: propane or gas for generator [Re: WhyMe] #4810885
07/11/18 12:33 AM
07/11/18 12:33 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
have not bought propane in a while. exchange seems to be about $21 and refill about $4 a gallon. with less btu per gallon and higher price , it seems that gas is still the way to go?
Re: propane or gas for generator [Re: WhyMe] #4810895
07/11/18 01:01 AM
07/11/18 01:01 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
It's very location dependent, but Propane should be cheaper than Gasoline.
It has a little less energy, but not a huge difference.
You can buy propane in an emergency, as the refill process uses stored pressure, not electric pumps, to fill. You can't buy gas if there is no electricity.
Propane stores much better, essentially forever. Gas goes bad after some months, I would say 6 maximum but others say 12 months.
Propane gells at low temperatures, making it useless (no pressure). You can heat the tank to turn it back into a gaseous state but that can be dangerous if you don't know how to do it. Some say the critical temperature is -20F but in my experience it's closer to -35F. However it will have less pressure as it gets close to that temperature. 0F is fine though.
Agree on avoiding the BBQ-sized tanks. May as well consider using the same cylinder for the BBQ though. If you do something like that, make sure the generator is far enough away from the home to avoid carbon monoxide entry to the living space.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: propane or gas for generator [Re: WhyMe] #4810908
07/11/18 01:45 AM
07/11/18 01:45 AM
northern NY
Driz Offline
Driz  Offline
northern NY
Only thing with gas is remembering to change it out . Then theres the dreaded Ethanol monster. It especially corrodes and plugs carbs on gen sets because they sit so much. Dont ever use it in a Genny unless youre actually simply burning it through at the time. Its ok for that though. Just dont leave it sitting ? Also no matter which you use put a fuel shut off and mini filter on the line. Theyre cheap .
Gas, no opinion. I used to drive a 350 Chevy with a 2 bbl carb and a switching rig. Some sort of gov study trial rig 1070 Chevy half tons even had air bags right down to the exact same label on the visors in later they drove as normal burned more propane than gas and did stink if you sat idling long. Also tended to give one a headache if you sat idling long.
Re: propane or gas for generator [Re: WhyMe] #4810996
07/11/18 06:59 AM
07/11/18 06:59 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
New-age generators use natural gas.
2019 Hyundai SantaFe 2.4 factory fill / QS 5w20 conv. / Mahle OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Moderated by  ekpolk
