WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
112 registered members (2K2AcuraTL, 14Accent, 2015_PSD, 92saturnsl2, 53' Stude, 240_Ed, 11 invisible), 2,110 guests, and 48 spiders.
Topics286,244
Posts4,905,149
Members67,587
Most Online2,967
Mar 10th, 2019
Anyone consider Valvoline Premium Blue 15w40? #4809973
07/10/18 09:00 AM
07/10/18 09:00 AM
Michigan
Goodkat Offline OP
Goodkat  Offline OP
Michigan
Has anyone used or thought about using VPB 15w40 conventional in their motorcycle? It looks like it has the same certs as Delvac 1300 other than VPB is SM and SN rated where as Delvac is only SN rated? Am I missing anything in a comparison with VPB vs Delvac 1300 or T4?
Just curious as VPB isn't talked about as much. Tractor supply has it and I might try it if its similar enough to Delvac or T4.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4809976
07/10/18 09:07 AM
07/10/18 09:07 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Done it.
A slight, although noticeable grab of clutch at engagement point that never went away.
I chalk it up to the particular Honda it was in, and it wasn't uncomfortable or bad, just a different feel.
I'd say you'll find it to be fine.
VPB still has over 1000ppm of P and Z if that interests you. Delvac was dumbed down with it's recent formula.
beanoil: Tough under heat, real dirty afterwards.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4809980
07/10/18 09:11 AM
07/10/18 09:11 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Do, any name brand HDEO is good in a bike. The result will be either fine, or some mini-issue like clutch engangement that will have you looking elsewhere. But, you won't know until you try smile
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: beanoil] #4809992
07/10/18 09:23 AM
07/10/18 09:23 AM
Michigan
Goodkat Offline OP
Goodkat  Offline OP
Michigan
Originally Posted By: beanoil
Done it.
To be honest I don't know what P or Z does for oil so I'm not sure if 1000ppm is good, bad or neutral. My knowledge of limited but I'm always up for a quick education.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: BrocLuno] #4810012
07/10/18 09:41 AM
07/10/18 09:41 AM
Michigan
Goodkat Offline OP
Goodkat  Offline OP
Michigan
That's just it, you font know until you try even if it's to satisfy curiosity or for the sake of variety.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810016
07/10/18 09:46 AM
07/10/18 09:46 AM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
Hey man, Z and P is zinc and phosphorous. Motorcyclists generally are concerned about their oil having enough anti-wear additives in their MC oil.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4806549/Re:_Zinc_vs_molybdenum#Post4806549
[Moly is shy-ed away from because it's commonly used as a friction modifier. These can inhibit the lockup of the clutch, or at least cause an increase in heat at the clutch during shifting.]
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Brian553] #4810046
07/10/18 10:23 AM
07/10/18 10:23 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
The chemical symbol for zinc is Zn, not Z.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810048
07/10/18 10:26 AM
07/10/18 10:26 AM
USA
SOHCman Offline
SOHCman  Offline
USA
ZDDP instead of Z and P for correct usage?
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810129
07/10/18 11:36 AM
07/10/18 11:36 AM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
I'd happily try their Premium Blue One 10W30 in my newer Honda. No big reason I wouldn't try the 15W40 version of Premium Blue in my older Magna.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810155
07/10/18 11:51 AM
07/10/18 11:51 AM
Michigan
Goodkat Offline OP
Goodkat  Offline OP
Michigan
The biggest aspects of HDEO that appeal to me is the shear resistance, wear protection and then price. None of our bikes are high performance and we have 4 bikes on the road so more oil for less would be nice. I like the idea of a good 15w-45 for my vstrom 1000 clutch basket and it also has gear driven cams chewing up the oil along with the transmission.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810201
07/10/18 12:18 PM
07/10/18 12:18 PM
Central Texas
Brian553 Offline
Brian553  Offline
Central Texas
Kschachn, I gotcha!
CK-4 oils will help to maintain the shear stability. You could also try mixing in 20w-50 synthetic MC oil (a lot of people like Valvoline and Mobil's offerings--just two options) if you want to make sure it stays in grade. If you don't want to go that route and just stay with a HDEO, Rotella is one of the few right now that keeps ZDDP levels back to SM standards. Most CK-4 oils ought stay in grade for the most rigorous shared-sump bikes (exception probably being Rotella T6), but Delo XLE 15w40 and Rotella T4 both show that it meets Allison TES-439 (shear stability spec.)
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4810220
07/10/18 12:28 PM
07/10/18 12:28 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Only one oil has JASO MA on the back of the bottle. Why experiment? It makes no sense. You have a wet clutch, why not just stick with the very readily available and easy to find and affordable Rotella? What do you gain by trying Delvac or premium blue?
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: bubbatime] #4810937
07/11/18 05:47 AM
07/11/18 05:47 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Yes, it pays to experiment.
Any 15/40 HDEO will work in a bike just fine in any bike but some bikes will shift better with one brand over the other, there is no reason to just stick to Rotella and accept it as the only one.
Unknown to most Rotella is NOT JASO listed/rated/approved oil.
Rotella just takes the extra step to make a statement that their oil meets Jaso standards.
Other companies do not make that statement, dont know if there is a reason other then they are not after the MC market or dont want to bother testing or whatever. Its not like I do not believe Shell/Rotella in that statement but just making sure everyone knows it is not a Jaso Approved Oil it is an oil that the maker says meets their standards.
A safe choice for sure but I personally did not use it in my metrics, I found other HDEOs gave me longer lasting good shifting but not by a huge margin and if someone wants to be "safe" then Rotella is just fine. Im talking the 15/40 oils and firmly believe if you ride only in temps above 45/50 degrees or so in a shared sump bike any HDEO 15/40 oil is superior to a 10/40 in a shared sump bike.
Being I dont have a shared sump bike anymore, I dont follow and have not looked into if the new CK4s area all safe like the Cj4 s ...
If you live in the hot climate I even more firmly believe that you are better off with Valvoline 4 stroke conventional motorcycle oil in the 20w50 weight.
Cost almost the same as an HDEO at roughly less then $5.00 a quart in Walmart (or walmart online), add a dollar if its in a auto parts store.
In hot weather the Valvoline 20/50 will blow away any 15/40 in shift quality, good stuff.
Great stuff, great shifting in my Yamaha 1300, ran a number of UOAs on it back in 2011/12 right here in this forum.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: alarmguy] #4810993
07/11/18 07:51 AM
07/11/18 07:51 AM
Michigan
Goodkat Offline OP
Goodkat  Offline OP
Michigan
I'm glad you posted this because I thought I had read that although Rotella claims it JASO MA MA2, it's not recognized by JASO. To me its like helmet companies claiming their helmets are DOT approved based off their own inhouse testing vs helmets that are SNELL approved. Seeing the DOT sticker may make a customer feel better but it may not be as substantial as its implied.
https://www.bobistheoilguy.com/forums/ub...JAS#Post4803519
I changed the oil in my wife's CTX700 with more Delvac and I tried VPB in my VSTROM 1000 yesterday. As far I can tell there is no clutch slippage and the bike didn't explode. I leave for a 7 day trip tomorrow so we'll see how it goes. So far I'm pleased with how the bikes run and shift with conventional HDEO. I don't think we'll be riding these bikes below 45 degrees but if we do I'll probably throw Valvoline 10w 40 in them. My DR650 is the bike I'll keep insured all year so I can ride it on the nice winter days we get every now and then. It fill get a lighter weight oil at point and I'll block the oil cooler.
Re: Anyone consider Valvoline Premium Blue 15w40? [Re: Goodkat] #4811497
07/11/18 03:54 PM
07/11/18 03:54 PM
Palmyra, PA
kmrcstintn Offline
kmrcstintn  Offline
Palmyra, PA
I like hdeo alot...my current bulk 'frankenbrew' is mostly traveller 15w-40 & valvoline 15w-40 (white bottle formula) with leftover frankenbrew from last season (various 15w-40's & 10w-40's); good results in several common sump motorcycles with straight hdeo's and frankembrews with hdeo in it
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
