Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Skendread, NGK, Thomas1, RE_Vision, JamesMc
67587 Registered Users
109 registered members (AlanGonzales, Anton93, 2010Civic, 2015_PSD, Aichiguy, 13 invisible), 2,037 guests, and 52 spiders.
Topics286,245
Posts4,905,177
Members67,587
Most Online2,967
Mar 10th, 2019
Brake fluid as a Penetrating fluid #4806923
07/06/18 03:45 PM
07/06/18 03:45 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
can brake fluid be used as a penetrating fluid, to relieve rusted up broken studs. ive busted 3out of 4 m8x1.25 bolts that hold up my Toyota Tacomas skid pan and rather not drill and tap them out, I have access to the top of the broken stud and want to screw them right up and out but they are seized pretty good, also I have no access to heat torch. I was thinking of using a double nut jam or just use vise grips to tighten the shaft up and out. any good tips/tools appreciated. also ive used PB Blaster and a WD40 that really didn't penetrate the threads at all.
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806925
07/06/18 03:47 PM
07/06/18 03:47 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Read a lot of people use ATF as a penetrating fluid.
Subscribing for brake fluid.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806926
07/06/18 03:50 PM
07/06/18 03:50 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Brake Fluid tested as a penetrating fluid. Courtesy of Project Farm.
https://www.youtube.com/watch?v=st8dkGzJWtg
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806930
07/06/18 03:52 PM
07/06/18 03:52 PM
NY
mx5miata Offline
mx5miata  Offline
NY
I heard transmish fluid and acetone
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806933
07/06/18 03:55 PM
07/06/18 03:55 PM
south charleston wv
fordmanwv Offline
fordmanwv  Offline
south charleston wv
yes my grandfather used brake fluid as penetrating oil. Use new fluid put it on and let it set overnight or longer.
Re: Brake fluid as a Penetrating fluid [Re: mrsilv04] #4806935
07/06/18 03:57 PM
07/06/18 03:57 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
this is the video I watched, it seems the brake fluid had penetrated very well down the threaded shaft compared to generic penetrant fluids
Re: Brake fluid as a Penetrating fluid [Re: fordmanwv] #4806938
07/06/18 04:01 PM
07/06/18 04:01 PM
new jersey
jrvn Offline OP
jrvn  Offline OP
new jersey
I had new front struts put on my truck and basically all 4 bolts were seized/rusted even after soaking PB Blaster for days all the bolts I broke threads were dry as a bone. I actually used a toothbrush to scrub the remaining broken studs with brake fluid hopefully it does better than PB Blaster did
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806950
07/06/18 04:24 PM
07/06/18 04:24 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I know you said that you don't have access to a torch, but I'd still recommend that route. A small propane torch is pretty inexpensive and can make a huge difference in getting a frozen bolt loose. Even a small butane torch like you'd use for lighting cigars and such could be used (might not work well if it's not quite designed to be held on for long periods of time).
Plus, there are lots of different uses for a torch!
Re: Brake fluid as a Penetrating fluid [Re: EdwardC] #4806970
07/06/18 04:54 PM
07/06/18 04:54 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Mapp gas gets pretty hot and with Oxy works good for rusted fasteners and brazing, its not a full on smoke wrench but for occasional home use its really okay.
https://www.amazon.com/Bernzomatic-BZMOX...YQMGRKTS54WPH2C
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806981
07/06/18 05:14 PM
07/06/18 05:14 PM
UT
BHopkins Offline
BHopkins  Offline
UT
While brake fluid may be effective as a rust penetrating fluid, it is also very corrosive, and using it will lead to worse corrosion later on. Project Farm did a follow-up to the video above. The results should not be too surprising to most.
https://www.youtube.com/watch?v=UoijjWUGU2Q
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4806994
07/06/18 05:23 PM
07/06/18 05:23 PM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
Penetrating oil often takes several days or even a couple of weeks to really penetrate in and do it's work. A good dose of patience is often required. I recently changed the rear and front diff fluid of our 2010 Forester and had quite a time with the front diff drain plug, it was frozen and rusted in pretty good and I did not want to use a cheater bar and round out the torx drain plug. Since the threads point upward and gravity was doing it no favors, I sprayed it really good about every other day or 2 with WD40 and when that ran out I had a can of Johnson penetrating oil, finally after about 3-4 weeks of keeping it sprayed down good, I was able to remove it fairly easily without a cheater bar and without damaging the torx. Not sure about brake fluid, but my grandfather used to use nail polish remover (acetone) along with trans fluid and it worked about as good as liquid wrench or WD40, but still took time to penetrate. Any penetrating oil is certainly going to work better and faster if the head of the bolt/ screw or plug is pointing downward, vs upward or horizontal.
2010 Forester:122K
2009 Sonata :189K
OCI 5K using TSC conventional Travelers oil.
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4807025
07/06/18 05:49 PM
07/06/18 05:49 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
brake fluid also melts your paint off.. I'll pass.
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4807095
07/06/18 07:47 PM
07/06/18 07:47 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
I like Kroil myself. You can get 2 cans directly from them for $14 plus shipping. I think Amazon charges $17 if you have a big enough order to get free shipping.
https://websecure.cnchost.com/kanolabs.com/orders/order_kroil.shtml
Re: Brake fluid as a Penetrating fluid [Re: Wolf359] #4807233
07/06/18 10:25 PM
07/06/18 10:25 PM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
Same here. Aerokroil is amazing IMO
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: Brake fluid as a Penetrating fluid [Re: jrvn] #4807267
07/06/18 10:59 PM
07/06/18 10:59 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Another vote for Aerokroil. If you buy a quart of Kreen, you can get a free can of AeroKroil. Not sure if the moneyback guarantee covers the free spray can, but I just bought my third quart of Kreen. smile
