I am a new member in this forum and I need some serious help.
Honda has introduced 4 stroke personal watercraft into the market beginning in 2002. From day one, owners of this watercraft have been experiencing high levels of gasoline in their oil. This has been confirmed many times via oil analysis. Gasoline content is measured between 5...10% routinely (this is with as little as 10 hours run time on the oil, and the manufacturer recomending 50...200 hour oil change intervals!) Theories include: PWC runs cold; data loggers record 90...147degrees (f); PWC runs ritch: Fuel mixture 12.6 / 1 @ idle; 11.9 /1 WOT A/F ratios (verefied.) Also lots of running at idle / low rpm because of no wake zones (engine max RPM 6800; suspect average cruising speed for a lot of people is very low with lots of ide); blow by because the engine is turbo charged and fuel injected. Testing has involved leak down, fuel rail pressure, fuel injectors, compresson, etc; specific root cause remains un-identified.
While we work to deduce the specific cause of the problem, I'm looking for the best method to continue to run the PWC, minimizing the risk of what contamination can do over time. This is where we desparately need this forum's expert's advice. Would you suggest:
Reduced oil change intervals (obvious),
specific oil types (e.g. Red Line because of the ester based stock.) (Note: This is a direct drive PWC; no gear reduction; no clutch; engine oil is only used for engine (not shared.) Engine has a sump type oil system if that means anything.)
specific oil weights (e.g. 20W-50 versus Honda spec of 10W-40)
oil additives (please help and be specific; brand, target content and why; and what volumes)
gas additives (please help and be specific; brand, target content and why; and what volumes)
oil additive brew? (In my personal case I am running Red Line 10W-40 if that helps.)
gass additive brew? (In my personal case I am running Red Line 10W-40 if that helps.)
What oils would you stay away from?
What would the ideal gas package contain to help combat this (the side effects this can cause.)
What would the ideal additivve package containg to help combat this (the side effects this can cause.)
Obviously the first and best defense is to determine and mitigate the problem. In the mean time, many members of the Honda PWC community would appreciate your expert's immediate and detailed assistance. PLEASE HELP! Sincerely, Christian...
