2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
Antioxidant additive overdose
by xomyeusun. 02/20/19 08:50 PM
F15 Arrested Landing at Portland.
by PimTac. 02/20/19 08:43 PM
Why is Mobil 1 0w30x1 rated higher than most
by spiderbypass. 02/20/19 08:14 PM
Castrol Confusion
by PWMDMD. 02/20/19 07:13 PM
Crashed the Volt this morning...
by 14Accent. 02/20/19 06:55 PM
Best place to file online for Fed taxes?
by Vern_in_IL. 02/20/19 06:47 PM
alienyouth33, RoyFJ, Intell77, RA_TJ, tiberius54
67294 Registered Users
76 registered members (beanoil, aquariuscsm, 2strokeNorthstar, Best F100, 69Torino, 8 invisible), 842 guests, and 56 spiders.
Topics284,591
Posts4,873,007
Members67,294
Most Online2,548
Feb 16th, 2019
Anyione here have an Ecobee thermostat? #4786936
06/14/18 05:45 PM
06/14/18 05:45 PM
MN
14Accent Offline OP
14Accent  Offline OP
MN
Xcel Energy is running a KILLER deal on smart thermostats right now, so I went ahead and ordered an Ecobee3 Lite for the house. $63 shipped! Anyways, my house doesn't have central air and uses a boiler and radiant heat. I posted a question about this before, however I think the Ecobee should help in my situation.
Here's how the genius that installed the boiler and zone valves set up the system:
Thermostat #1, located on the ground floor in the living room controls ALL free standing radiators in the house. That's the basement, dining room, entry way, living room, sitting room, 3 of 4 upstairs bedrooms, and the upstairs bathrooms.
Thermostat #2 is located in the kitchen, approx. 15 feet from 'Stat #1. It controls the baseboard heaters in the kitchen itself AS WELL AS the baseboard heat in the master bedroom, directly above on the second floor.
The problem with my setup is this: 'Stat #2 simply can't acquire a proper temperature reading to maintain comfort in the master bedroom! The laws of convection just don't allow it. The entire main level is basically open, and anyone who's had old-school radiators in their house knows that the really pump out the heat. It's incredibly easy for the 3 large radiators on the main floor to keep the kitchen warm, thereby causing the the #2 'Stat to turn off long before the master ever gets warm.
My initial thought was to use the Ecobee in conjunction with a room sensor to separately control the two zone valves at the boiler, however it seems that's really not possible. I'm not sure why, exactly, because it's a simple matter of programming: built-in sensor commands zone #1 water valve, room sensor reports back and main unit commands #2 zone valve, but I digress. In my application, I plan on using a room sensor in the master and telling the Ecobee to ignore it's own internal sensor, which I do believe is possible after reading the instructions.
Apologies for the long winded post, but I like detail! Does anyone else have experience installing/living with a smart thermostat? I'd love to hear feedback!
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4786973
06/14/18 06:49 PM
06/14/18 06:49 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
We have an Ecobee but not the new one that you can connect up to zones.
You sound like what you want to do is the way to go. Why he hooked up to the upstairs baseboard with the thermostat downstairs doesn't make sense.
2002 Silverado 5.3 0w-20 AMSOIL
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4786978
06/14/18 06:55 PM
06/14/18 06:55 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I live in South Florida and smart thermostats are not worth the trouble in my experience. The claimed savings don't really materialize and if your schedule changes, you come home to a hotter house, right when you want it cool.
Back to your requirements, it seems like you are just turning this device into a bedroom thermostat that controls the system. The cold room situation was a major reason behind forced air systems. Without changing your system for more even heating, I don't think it's going to work.
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4786981
06/14/18 06:58 PM
06/14/18 06:58 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
I think you need to straighten out the zones before the Ecobee can help. Each zone should bring all the rooms it heats to roughly the same temperature. I am sure a plumber can make plumbing changes that will allow the zone to work properly.
I am not sure how much the Ecobee will really help because radiant heat is very slow. It takes hours not minutes to come up to temp from a setback temp.
I installed a small electronic device that sets the boiler high temp based upon the outside temp, along with some other parameters. It will help more than an Ecobee.
2015 Ford F250 w/Powerstroke
Re: Anyione here have an Ecobee thermostat? [Re: Cujet] #4787020
06/14/18 07:27 PM
06/14/18 07:27 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
I live in south Florida and smart thermostats are DEFINITELY awesome, in my experience. Program it to turn up right before you leave, and turn down, right before you come home. It saves a lot of energy and money. When in bed I can adjust the temp right from my smart phone without having to get up.
When I go on vacation I set the AC to 82, and then when on my way home, I'll cool the house down to 74 a few hours before I get home, right from my smart phone. I love it and highly recommend them.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Anyione here have an Ecobee thermostat? [Re: Donald] #4787095
06/14/18 09:51 PM
06/14/18 09:51 PM
Texas
JustinH Offline
JustinH  Offline
Texas
I have an emerson sensi. It has options for fast cycle or slow cycle. I use the slow cycle on my system because I want it to run for longer periods at once.
The directions say that the slow cycle is appropriate for boilers also.
It also has a methodology of getting the house to a certain temp by a certain time, so it will start early to be at that temp when you get home.
'11 Hyundai Sonata GLS
'11 Scion XB
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4787129
06/14/18 11:11 PM
06/14/18 11:11 PM
Tampa, Florida
flanso Offline
flanso  Offline
Tampa, Florida
Nest offers a wireless sensor that can be placed remotely from the main Nest thermostat. Nests are pricey but probably cheaper than repiping your boiler.
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4787235
06/15/18 06:50 AM
06/15/18 06:50 AM
Madison, Wisconsin
TWG1572 Offline
TWG1572  Offline
Madison, Wisconsin
I'm not sure why you say it's not possible, unless I'm not following what you want to do. You can program the Ecobee to ignore the sensor in the thermostat and just use the remote sensor. Put the remote in your master, and you should be set. Here are the instructions:
https://beta.ecobee.com/faq/can-i-disabl...ature-readings/
I really like my Ecobees. I don't think they generate the savings they claim, but I like the features they have like auto home/away, etc.
Re: Anyione here have an Ecobee thermostat? [Re: TWG1572] #4787289
06/15/18 07:52 AM
06/15/18 07:52 AM
MN
14Accent Offline OP
14Accent  Offline OP
MN
That's how I intend to use it. However, what I really want to do and what I believe the Ecobee can NOT do is use the room sensor readings to control one of the zone valves, and use the Ecobee sensor to control the other valve. This would remove the 2nd thermostat in the system and leave the Ecobee to control everything. However, this does not seem possible. I tweeted their support team but I haven't heard back in 2 days.
Re: Anyione here have an Ecobee thermostat? [Re: Cujet] #4787324
06/15/18 08:24 AM
06/15/18 08:24 AM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
I live in Florida and our NEST is absolutely worth it. It has saved us money and being able to adjust it from my phone or my Google Home is very nice as well.
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Anyione here have an Ecobee thermostat? [Re: Cujet] #4787368
06/15/18 09:10 AM
06/15/18 09:10 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Absolutely agreed IMO. We have irregular hours so we never know exactly when we are coming home or leaving. Turn the temp up when you leave and then back down when you come home. the reason we have a highly efficient AC is to use it...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Anyione here have an Ecobee thermostat? [Re: gregk24] #4789894
06/18/18 09:17 AM
06/18/18 09:17 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I don't work normal hours, so I was constantly coming home to a warm house. Or cooling it when I was not home. Using a phone to control it is exactly as difficult as turning it (a little or a lot depending on the circumstance) up when you leave the house turning it down when you return.
I saw no savings with my digital thermostat. I actually went back to the old Honeywell dual stage mercury thermostat. While I don't doubt that people save some money over just leaving the house cold all the time, I'm not that lazy and I turn it up when I leave. Nil savings. None.
Plus, I found that moving the little lever to adjust temp was far faster than changing a digital display.
Re: Anyione here have an Ecobee thermostat? [Re: 14Accent] #4808794
07/09/18 04:21 AM
07/09/18 04:21 AM
CA, USA
NeoDad Offline
NeoDad  Offline
CA, USA
I do have an Ecobee, we like how it's got built-in Alexa already however, it's been acting up recently. I noticed it won't stick to the temp I set it. It keeps on changing.
Moderated by  ekpolk
