Spark Plugs - 6.2L GM
by jdw1222 - 05/28/20 07:16 AM
seat belt retracts slowly
by NH73 - 05/28/20 05:19 AM
Bent Jack Stand Ratchet Bar
by The Critic - 05/28/20 01:44 AM
Can a 2005 Volvo go 300K Miles easily?
by VolvoZ - 05/27/20 11:17 PM
Cam specs for '62 Corvette Fulie
by JeffKeryk - 05/27/20 11:06 PM
Grub hub
by Chris142 - 05/27/20 10:52 PM
Fiat 500e In the Stable
by Scout1 - 05/27/20 10:41 PM
Windows 10 2004 (May 2020 Update) is out
by KeithS_NW_Ohio - 05/27/20 08:56 PM
Harley Davidson Lithium LiFe 6Ah Battery 66000174
by DuckRyder - 05/27/20 07:29 PM
Belron Toolbox with collapsible cart. One neat setup
by 10WSmuckers - 05/27/20 07:16 PM
[Cut Open] Mobil 1 M1-209 (5267 miles)
by DuckRyder - 05/27/20 07:15 PM
[Cut Open] FRAM TG8A (30 minutes)
by DuckRyder - 05/27/20 07:06 PM
[Cut Open] Motorcraft FL500S - 5341 miles
by DuckRyder - 05/27/20 06:59 PM
Battery powered 1/2 inch impact wrench
by RazorsEdge - 05/27/20 06:50 PM
Subaru Dealer Filter 7KMI
by Jason_Michaels - 05/27/20 05:52 PM
Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
76 registered members (andyd, Bailes1992, adamschoena, AurionX2, aquariuscsm, 4WD, 9 invisible), 1,572 guests, and 38 spiders.
Topics305,960
Posts5,283,706
Members71,546
2017 WRX STI: Motul X-clean EFE - 5,000 miles #4784224 06/11/18 07:16 PM
T
Tiir Offline OP
T
Motul X-clean 5w-30 EFE fill.
2017 WRX STI - Sold
2017 ES300h - Sold
2016 Lexus GS F
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784236 06/11/18 07:28 PM
O
oil_film_movies Offline
O
Copper is probably from the oil cooler. Its been seen a lot on WRX engines. The other possible source is the crank bearings, yet it just seems unlikely here.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784565 06/12/18 06:58 AM
Snagglefoot Offline
For what itís worth that is a very low iron number, down at 1 ppm/ 1000 miles. Where the other checks with the same Motul oil?
If you want the job done right......do it yourself.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784694 06/12/18 09:18 AM
G
Gubkin Offline
G
"TBN is still good at 2.2. Try 7000 miles"
Crazy lab! )))))))
It's mean that TBN > TAN
necessary decrease interval to 4000 miles
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784713 06/12/18 09:32 AM
K
kschachn Online Content
Online Content
K
What?
Crazy lab! )))))))
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784735 06/12/18 10:00 AM
G
Gubkin Offline
G
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Tiir] #4784746 06/12/18 10:07 AM
Z
zeng Offline
Z
Very good metal wear rates.
Cu and (part of) Al likely comes from cooler, not bearing.
This C3 oil of TBN 7.8 drops to 2.2 over 5100 miles, which I interprete as good TBN retention.
I won't look at TAN , if any, and agree with BStone OCI could be extended further to 7000 miles or probably beyond.
Edit:The test of the pudding is in the eating, which in this case refers to (the very good) Fe wear of 5 ppm over 5100 miles.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4784786 06/12/18 11:10 AM
B
bluesubie Offline
B
I believe that Blackstone uses a different ASTM test than either of those (at least they used to).
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=221275
I doubt the OP will extend the interval very much. And probably not likely to go beyond 6k miles which is Subaru of America's recommendation unless Blackstone will cover the Powertrain Warranty. smile2
'20 Subaru Outback Onyx XT | Idemitsu Zepro 0W-20
'04 Subaru Forester 2.5XT | Castrol Edge 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4784788 06/12/18 11:15 AM
1
1JZ_E46 Offline
1
Wear metals ppm is only a piece of the story. You will not see deposit formation in a UOA, which you get from low TBN or where TAN is higher than TBN.
2019 Tesla Model 3 SR+
2016 Countryman S: Castrol 0W-40
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: Gubkin] #4785143 06/12/18 06:29 PM
K
Online Content
K
What is the TAN here?
1994 BMW 530i, 252K
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: 1JZ_E46] #4785163 06/12/18 06:48 PM
Z
zeng Offline
Z
Deposit formation,contents of Na,Ca,Mg etc, sludge,varnish,low TBN , high TAN,residual [email protected]*C, fuel dilution % etc are merely/strictly noises.
Re: 2017 WRX STI: Motul X-clean EFE - 5,000 miles [Re: zeng] #4789145 06/17/18 12:42 PM
1
1JZ_E46 Offline
1
Respectfully disagree. What a dense statement.
