2020 BMW M2 Comp | BMW 0W30 | ~4500 miles
MSH
2020 BMW M2 Comp that I purchased used back in April at about 19k miles.
Factory warranty just ended back in August, so was still on factory fill BMW 0W-30.
Mild M4GTS+ level of tune added about 700 miles prior to oil change. Bumps power from roughly 410whp/410wtq stock to 485whp/465wtq
Use case = 2nd car primarily used for canyon runs and spirited drives here in Colorado.
Switched over to Motul on this last oil change (5L of Motul Sport 5w40 I had left over from previous car and 1.5L Xcess Gen2 5w40)
Will use 100% Xcess Gen2 5w40 starting with next oil change
Everything looks good except the Al but with the lower mileage engine perhaps there's still some wear in taking place & is trending down. I agree with your choice of 5w-40 & should not shear down as low over the same duration or longer. Thanks
