Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
122 registered members (2010Civic, ABerns, 01rangerxl, 2009Edge, AndyB, 853okg, 11 invisible), 2,288 guests, and 69 spiders.
Topics286,029
Posts4,901,104
Members67,549
Most Online2,967
Mar 10th, 2019
Slight slipping flare on 3rd to 4th 05 Solara 5AT #4783774
06/11/18 10:59 AM
06/11/18 10:59 AM
texas
audia6 Offline OP
audia6  Offline OP
texas
Hi,
Got a 05 Solara that has been slipping or flaring in gear changes of 3rd to 4th. Happens when I got car at 55k. Had ATF changed at dealer 60k drain and fill only. It still does it. Now has 96k. I'm thinking of changing the fluid again since it's been 35k.
Been reading here and Valvoline Max life came in highly recommend. Along with a lube guard shudder fix. What is that? I am extremely.skeptable of snake oils. My.logic is, it may fix for while but will make it worse in long run. Planning on keeping car for long haul. Has 96k or so now.
So: is Valvoline Max life okay to use?
What exactly does this shudder fix do? It it like "stop leak ATF or PS fluid" where it stops leaks temporarily and makes other things worse?
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4783787
06/11/18 11:14 AM
06/11/18 11:14 AM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Yes, Maxlife is ok to use smile
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4783804
06/11/18 11:32 AM
06/11/18 11:32 AM
California
Billbert Offline
Billbert  Offline
California
drop the pan and change the filter (and use maxlife)
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4783823
06/11/18 11:45 AM
06/11/18 11:45 AM
Northeastern Vermont
littleant Offline
littleant  Offline
I do not think lube guard shudder fix is what you need. Lubegard red is what I believe you should use. Lubegard will not hurt your trans. It may not help (like worn out parts) but will not hurt. It's not a snake oil but a good product. Do a google search lubegard red bitog or search the forum. Most like the product and have had good results. I use it as preventive maintenance no issues. I believe Toyota recommends ATF+4
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4783834
06/11/18 11:57 AM
06/11/18 11:57 AM
California
VeryNoisyPoet Offline
California
Maxlife cured shift flares on my mom's car. If the only fluid change the car ever had was a drain and fill at 60k, you are due for another at the very least. Three drain and fills, each one spaced maybe a week apart will do even more good. After that one every 30k should keep things happy.
Lubegard red might help smooth things out as well.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: littleant] #4783854
06/11/18 12:16 PM
06/11/18 12:16 PM
TEXAS
InhalingBullets Offline
TEXAS
I think you mean ATF-WS[u][/u]
'16 Toyota Prius 4
'15 Honda Accord Sport
'14 Victory Cross Country Tour
'13 Toyota Prius 3
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4783885
06/11/18 12:31 PM
06/11/18 12:31 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
Originally Posted By: audia6
Hi,
If you are doing to work, you may as well flush it though the cooler line . If this is beyond you, just do a D&F with maxlife. Add the LG red either way, it is not snake oil. Lubegard Red is the only additive on BITOG than everyone can agree on.
Maxlife + Lubegard Red = BITOG transmission concoction.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: InhalingBullets] #4783919
06/11/18 12:55 PM
06/11/18 12:55 PM
Alberta
tcp71 Offline
tcp71  Offline
Alberta
The aisin U151E transmission requires toyota type T-IV, not ATF+4 or WS. It is the same as JWS3309.
https://www.ebay.com/bhp/toyota-atf-t-iv
https://www.ebay.ie/itm/141103693775
Lubeguard red would be fine. DON'T use the shudder fix. It will make a for very hard shifts and converter lockup. Clanging and banging around.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: mobil 0w40 (varies)
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4784030
06/11/18 03:48 PM
06/11/18 03:48 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
You've got the same U151E that's in my Camry
I've got similar complaints (shuttle shift, flaring, feels like it's slipping or falling into neutral but it really isn't)
I'm shopping for a reman valve body that's got all new solenoids and a shift kit preinstalled
Whatever you do, don't use Transmax IMV, hated how it shifted on that stuff
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4784036
06/11/18 03:54 PM
06/11/18 03:54 PM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Two stories. Just putting these out there.
I pulled a buddy's transmission out of his Suburban for a rebuild. When I got it back in, it was flaring on 2-3. Ugh, right? Turns out it had a dirty MAF. Took a while to figure it out, but once I cleaned the MAF, it shifted fine.
A few months ago, I did a bunch of work on a neglected 2005 Camry (free work for a friend). It had 238k miles and I doubt it ever had anything beyond 10-30k mile OCIs performed. I did a full tune up and when I was done, took it out for a test drive and it was flaring between shifts (it didn't before the work). Wonderful! I thought back to my Suburban experience and pulled the MAF for a cleaning. Popped it back in and the transmission was perfect again.
If you've never touched it, clean the MAF. Worth a shot before anything else. Cheap and easy.
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: audia6] #4784453
06/11/18 11:32 PM
06/11/18 11:32 PM
Fort Worth, Texas
clinebarger Online content
clinebarger  Online Content
Fort Worth, Texas
cpayne5....What you stated has a lot of merit!
"Delivered Torque" values are calculated off the frequency/output of the Mass Air Flow sensor, Delivered Torque values have a great effect on commanded transmission line pressure.
2001 Chevy Camaro L92/4L80E
Re: Slight slipping flare on 3rd to 4th 05 Solara 5AT [Re: clinebarger] #4784782
06/12/18 11:05 AM
06/12/18 11:05 AM
Virginia
cpayne5 Offline
cpayne5  Offline
Virginia
Good stuff. Thanks for adding to the discussion. thumbsup
