API diesel / gas ratings
by KiwiBiker - 08/21/19 10:18 PM
For the XOM fans!
by Marco620 - 08/21/19 09:43 PM
I have to set up Wake-On-Lan
by vavavroom - 08/21/19 09:17 PM
A Nut About Motor Oil
by Mr_Luke - 08/21/19 09:12 PM
Is VW507 okay for flat tappets in EA 827?
by vavavroom - 08/21/19 09:06 PM
Brake pads on a Cadillac ATS?
by Oro_O - 08/21/19 08:32 PM
2019 GMC Sierra - Rear view mirror is new tech
by Reddy45 - 08/21/19 08:18 PM
Mobil Super or Mobil 1
by 80Boxcar - 08/21/19 07:34 PM
17 Accord 6AT "service"
by Schmoe - 08/21/19 07:26 PM
Caliper Recommendations for 2002 Tacoma
by madibob - 08/21/19 07:14 PM
KoruWorks code
by GumbyJarvis - 08/21/19 06:34 PM
Differential / Axle VENT
by MasterSolenoid - 08/21/19 06:14 PM
Oil for Volvo S60 T6 R-Design
by Luke352 - 08/21/19 05:52 PM
Motorcraft 5w30 synthetic blend SN+
by mpgo4th - 08/21/19 05:37 PM
6.7 powerstroke cab off repair work
by mattd - 08/21/19 04:23 PM
talk to me about security cameras
by 1978elcamino - 08/21/19 03:30 PM
modem in 1 room want phone in another room
by raaizin - 08/21/19 02:17 PM
AC Belt Question
by BISCUT - 08/21/19 02:10 PM
Pros and cons of Electronic Parking Brakes?
by KGMtech - 08/21/19 01:50 PM
Robto, Chaparro_trucker, KiwiBiker, Rixter, yote556
69025 Registered Users
84 registered members (01rangerxl, AdmdeVilleneuve, 4WD, AdditiveOCD, 15 invisible), 1,820 guests, and 22 spiders.
Topics293,631
Posts5,043,739
Members69,025
Most Online3,532
Jul 30th, 2019
Anyone using a conventional synthetic in a CR TDI? #4777491 06/04/18 05:49 PM
T
Terry270 Offline OP
T
I have a deleted CR TDI and have been sticking with the recommended VW 507 oils since new but I am considering switching to T6 or Schaeffer's. Is that ok since it's 5w-40 instead of 5w-30 like the VW 507 oils?
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4777496 06/04/18 05:59 PM
A
Audios Offline
A
Id say youd be fine, most of the reason you had to use specific oils was when the oil burned it affects the emission equipment.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4779491 06/06/18 07:15 PM
J
jayg Offline
J
Lots of people stopped worrying about that certification after being deleting. Any modern synthetic diesel rated oil will do fine in them once the DPF is gone.
I will say that your thread title "conventional synthetic" was a little hard to follow for a second. cool
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Anyone using a conventional synthetic in a CR TDI? [Re: jayg] #4779707 06/06/18 10:48 PM
T
Terry270 Offline OP
T
I hear people say that, but no one has posted an analysis yet.
Lol. It's been so long since I've used a non synthetic oil in anything I forgot about them being referred to as "conventional".
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4779959 06/07/18 09:09 AM
J
jayg Offline
J
I wouldn’t worry about seeing an analysis. People have been doing it for almost 10 years since the CR 2.0 came out over in TDIclub. I did it for a few years on my deleted 2012 Jetta with m1 tdt with no issues.
Without the dpf to worry about, there’s nothing to worry yourself over as far as lubrication. HPFP grenading , intercooler icing (for the air to air equipped cars) , egr issues....those on the other hand are still what if worry about.
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4780795 06/07/18 11:44 PM
E
edyvw Offline
E
would move to Castrol 0W40. Forget T6.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Anyone using a conventional synthetic in a CR TDI? [Re: edyvw] #4781501 06/08/18 05:14 PM
T
Terry270 Offline OP
T
The car has 240k on it now so I probably will get an analysis done.
As far as the other issues I have the 2micron kit so if the hpfp dies then I only have to replace the pump and filter. Egr is gone which also does away with intercooler icing issue. It should be pretty solid.
Have any data to back that up?
Re: Anyone using a conventional synthetic in a CR TDI? [Re: jayg] #4781740 06/08/18 09:21 PM
G
Garak Online Content
Online Content
G
And happy birthday!
Plain, simple Garak.
Re: Anyone using a conventional synthetic in a CR TDI? [Re: Terry270] #4781885 06/09/18 04:12 AM
E
edyvw Offline
E
Back up what? It has much lower NOACK (9.1% compare to 12.6%), it has robust HTHS, it has much lower cst. Simply it is much better oil for personal vehicle with engine of that size.
Research on the BITOG, numerous topics on Castrol 0W40, T6 or whatever.
