(NEW) Wix 51522 Cut Open
by rooflessVW. 01/15/19 10:23 PM
Is this guy for real? (HUMOR)
by StevieC. 01/15/19 10:18 PM
Elf 4T moto tech 10w50 is good?
by firstime911. 01/15/19 09:25 PM
New Champ Filter
by CapitalTruck. 01/15/19 08:30 PM
19 Elantra vs corolla vs civic vs 18 Mazda 3
by wolf_06. 01/15/19 07:28 PM
New guage cluster need to be programed?
by callbay. 01/15/19 07:28 PM
good brand of inner tie rod?
by motor_oil_madman. 01/15/19 07:27 PM
Look at this blast from the past!
by SubieRubyRoo. 01/15/19 05:50 PM
Factory service manuals?
by buck91. 01/15/19 05:49 PM
Road Trip - Drive My Own Car or Rent?
by The Critic. 01/15/19 05:23 PM
‘19 GTI specs 0w-20 508 00
by LotI. 01/15/19 05:22 PM
Fram TG11955
by advocate. 01/15/19 03:03 PM
Bosch Steeltech = Wix?
by Black_Thunder. 01/15/19 02:44 PM
CVT and 6 speed automatic
by jerseyguy123. 01/15/19 01:56 PM
Hypothetical - X6M vs X5M vs AMG GLE63
by OVERKILL. 01/15/19 01:48 PM
2001 dodge neon coolant reservoir
by mobilaltima. 01/15/19 01:38 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
105 registered members (1.8Tango, 71Chevyguy, 2003f7, 2015_PSD, 13 invisible), 1,599 guests, and 32 spiders.
Topics296,613
Posts4,955,838
Members66,950
Most Online2,577
Jan 14th, 2019
Correct ATF for 2016 VW Passat #4780133
06/07/18 12:13 PM
06/07/18 12:13 PM
PA
Vaca Offline OP
Vaca  Offline OP
PA
After doing a bit of research, here on BITOG and elsewhere, I have not found a definitive answer on which ATF should be used for a (US) 2016 Passat with the 1.8 liter EA888 Gen 3 engine with Aisin 09G automatic transmission (only transmission available on 2016 Passat 1.8t).
From what I have found, I THINK the proper fluid is VW G 055 540 A2. But, I read somewhere that the G 055 540 A2 was used through 2014, and then it was changed to something else for 2015 and later; I'm not convinced that is correct though.
I have also read that the G 055 540 A2 is either same as or very similar to Toyota WS ATF (which is same as Mobil 3324, Idemitsu Type TLS, etc).
Anyway, does anyone here know what VW part number fluid should be used on a (US) 2016 Passat 1.8T and whether or not Toyota WS, Mobil 3324 ATF are the same?
Thanks
Re: Correct ATF for 2016 VW Passat [Re: Vaca] #4780157
06/07/18 12:43 PM
06/07/18 12:43 PM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Correct ATF for 2016 VW Passat [Re: Vaca] #4780182
06/07/18 01:00 PM
06/07/18 01:00 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
The Aisin transmission uses Toyota WS aka 3324. AAP has Castrol ATF on sale right now for $5/qt. Get their Full Synthetic ATF. There is also Maxlife smile
Re: Correct ATF for 2016 VW Passat [Re: slacktide_bitog] #4780201
06/07/18 01:20 PM
06/07/18 01:20 PM
PA
Vaca Offline OP
Vaca  Offline OP
PA
Are we all sure the spec didn't change for 2015 and later?
Re: Correct ATF for 2016 VW Passat [Re: Vaca] #4780448
06/07/18 05:30 PM
06/07/18 05:30 PM
NJ
raaizin Offline
raaizin  Offline
NJ
I have use Mobil 3309 in my daughters 2008 Jetta which I believe has the same transmisssion. Its spec is VW G-055-025-A2, VW TL 52540-A. I changed it 75k miles ago with no ill effects
