How often to drive a car that sits in the winter?
by Corollaman. 02/17/19 08:49 AM
Top Off or Change it Early
by 99Saturn. 02/17/19 08:22 AM
Do your vehicles have a nickname?
by ZZman. 02/17/19 08:19 AM
Another work project thread
by mattd. 02/17/19 08:18 AM
Buzzing sound behind dash
by Spetz. 02/17/19 05:09 AM
Ain't stupid, but can't find Cummin Hist
by BrocLuno. 02/16/19 11:41 PM
Rethinking oil choices
by JLTD. 02/16/19 11:29 PM
coolster 150 cc atv 2019 new
by hyperscion. 02/16/19 10:37 PM
older gps - week counter rollover Apr 6 '19
by spackard. 02/16/19 10:32 PM
Thoughts on an old Lexus?
by JustN89. 02/16/19 09:50 PM
Understanding Fuel Trims for diagnostics.
by StevieC. 02/16/19 07:59 PM
book of matches for tune up?
by marine65. 02/16/19 07:53 PM
New Penrite 0w-30
by toyota62. 02/16/19 07:45 PM
New HID bulbs for the Cadillac
by 14Accent. 02/16/19 07:17 PM
2008 Prius - Water in oil
by cjolson140. 02/16/19 07:00 PM
Kitchen Faucet question
by reemoe2. 02/16/19 06:56 PM
Time for brakes again
by SilverFusion2010. 02/16/19 05:23 PM
Darn brake rotors
by Dave Sherman. 02/16/19 03:42 PM
looking @ a 2010 Escape Hybrid...
by earlyre. 02/16/19 03:24 PM
jpdeal, Snipeuout, DeltaWing, JRS3, krzyq
67252 Registered Users
105 registered members (53' Stude, Audios, berlyn, AdditiveOCD, alarmguy, 10 invisible), 1,603 guests, and 51 spiders.
Topics298,304
Posts4,989,185
Members67,252
Most Online2,548
Feb 16th, 2019
Oil change, now leaking 2015 5.7 Hemi #4779797
06/07/18 04:47 AM
06/07/18 04:47 AM
New Hampsha
Blue_Goose Offline OP
New Hampsha
Did an oil change last Saturday using Royal Purple 5W20 and a Royal Purple filter. Car was bought used and previous change at the dealer I bought it from used a Wix Filter, no idea on oil brand.
Got the car up on ramps, removed the plastic protector plate that Dodge users, drained oil and removed filter. The filer was only hand tight as I was a little surprised on how easily I was able to remove it. (Not loose but was able to remove without a filter wrench)
Put drain plug back in and filled the filter with bit of oil, lubed gasket and installed. Usually when I put a filter on it will make contact and I can turn it 3/4 to a full turn to snug it up. Withe the RP filter it seemed to make contact and that was it...didn't feel like I could turn it any more. My hands were slipping between the sweat and oil I had on them so I put a filter cap wrench on and turned it a bit more ( less that a full turn)
Filled up with 7 quarts, started and everything seemed fine. Didn't detect any leaks. Put everything back together and cleaned things up.
The other day I noticed a oil spot where I sometimes park my car at work. Didn't really think much of it. Yesterday while idling in my car I got a whiff of oil...hmmmm...go out and looked...didn't see anything.
This morning I back out of my spot at home and see about a basketball size stain under the car. Whoops....I shined a light underneath and I can see that there is oil all over the plastic cover that shields the below the engine bay. I turn the car off and can hear a faint drip, drip, drip....
At this point I'm running late for work so i put a drip plan under the car and hopped in the Honda to head to work.
My initial guess is the filter is leaking. A quick Google search pulled up some guys with Hemi's in the RAM Forums having leaking issues. According to Royal Purple's website I have the right filter on there. 20-820
I checked my oil and it is just a bit below the full line. I'm guessing what is leaking is pooling on the top of that plastic cover and when stopped it is draining out leaving the spot on my parking spot.
Half of me just want to bring it to the dealer and have them take a look and do another change and hopefully clean up that area. Living in a townhome complex I've already made a bit of a mess with the leak and who know how much of a mess I'm gonna make when I take that cover off.
Think the filter is the culprit??
2018 Honda Civic EX Hatchback 1.5T
2003 Honda Accord EX-L 2.4L 5MT
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779809
06/07/18 05:18 AM
06/07/18 05:18 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It could be leaking from anywhere. The filter and drain plug would be where I looked first. I've always hand tighten the filter and then give it a 1/4 to 1/2 turn with a wrench. I never settled for hand tight filters, although many people do just that and have no problems.
God Bless Our Troops
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779813
06/07/18 05:30 AM
06/07/18 05:30 AM
Georgia
MParr Offline
MParr  Offline
Georgia
The filter could be the culprit. The only way to know is get under there and take a look. Was the old filter gasket still on the WIX filter when you removed it? Two filter gaskets donít seal well. There could have been some trash or grit left on the mounting flange and that could cause problems. The new filter gasket may have come out of place when you put it on. If it is the filter, you need a new filter on hand to replace the old one. Youíll need some makeup oil, as well. You wonít lose much oil changing out the filter. Make that change with the engine cold, Finally, clean off all of the blown oil that you can. I almost forgot. Check your drain plug for tightness, torque to spec. The correct Royal Purple filter is the 20-820*FI.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779821
06/07/18 05:40 AM
06/07/18 05:40 AM
New Hampsha
New Hampsha
I made sure that the old gasket did not come off the previous filter and I wiped the seating area down.
I'm thinking I'm going to bring a ton of cardboard boxes home from work and place them under the entire length of the car to avoid any spill disasters. I'll probably stop and pick up a 57899 Wix filter as well as that didn't seem to have any issues or maybe even a Mopar OEM MO-899
I've never changed just a filter before without draining the engine oil first. Should I expect a lot more to come out with a full oil pan vs after being drained? Changing this filter is already a messy task based on where it is located...
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779824
06/07/18 05:46 AM
06/07/18 05:46 AM
NY
mx5miata Offline
mx5miata  Offline
NY
If the filter gasket come off intact with the old filter and itís not the new filter leaking. Check your drain plug for a washer if equipped they do tend to fall off and sometimes roll away from you I once found one halfway down my driveway. Also see if you can get another half a hand turn on that filter
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Oil change, now leaking 2015 5.7 Hemi [Re: mx5miata] #4779830
06/07/18 05:55 AM
06/07/18 05:55 AM
New Hampsha
New Hampsha
The drain plug on the Charger doesn't used a washer, it has a self contained rubber grommet (for lack of a better word) built into the plug.
When I took of the Wix 57899 that was on there, I literally was able to remove it with just my hand, no wrench needed. No leaks at all with that filter. When I put the Royal Purple Filter on it felt like once it made contact with the seating area it just stopped. I need a wrench to turn it extra. I can't remember ever having to do that before with an oil filter.
Then again if it was the filter shouldn't I have seen it leaking after I started it and did my check?
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779853
06/07/18 06:15 AM
06/07/18 06:15 AM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
You've done it now, putting a synthetic over a conventional. Let the leaks begin! JK
Sounds like it could be the filter. I have had that happen with a few filters myself.
2002 Silverado 5.3 0w-20 AMSOILģ
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779864
06/07/18 06:27 AM
06/07/18 06:27 AM
NY
mx5miata Offline
mx5miata  Offline
NY
Sounds like a filter prob for sure. Go pick up a Fram or if Wal-Mart still has OEM grab a Mopar filter and just top off the amount of oil you lost.
Wix air filter
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779891
06/07/18 06:56 AM
06/07/18 06:56 AM
US
JLTD Offline
JLTD  Offline
US
I seem to recall reading about a similar issue with a RP filter awhile back.
I'm a thickie; assimilate
But 20s have their place
Using AMSOIL‚ĄĘ
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779929
06/07/18 07:44 AM
06/07/18 07:44 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Did you make sure the gasket came off with the Wix?
2019 RAM 1500 Sport
2016 Grand Cherokee SRT
Re: Oil change, now leaking 2015 5.7 Hemi [Re: OVERKILL] #4779930
06/07/18 07:45 AM
06/07/18 07:45 AM
New Hampsha
New Hampsha
Yep! First thing I checked for
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779933
06/07/18 07:47 AM
06/07/18 07:47 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Could just be a chunk of dirt on the mating surface then, maybe remove the filter, check, and reinstall, see if it solves the problem?
2019 RAM 1500 Sport
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779942
06/07/18 07:52 AM
06/07/18 07:52 AM
socal
barkingspider Offline
socal
Thatís why I donít use RP oil/filters hide
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779950
06/07/18 07:56 AM
06/07/18 07:56 AM
New Hampsha
New Hampsha
Any idea how much oil will come out when I remove the filter? Will it be more than if I drained the oil from the pan first? Trying to prepare for how much is gonna spill out. It doesn't come off clean without a mess running down your arm etc.
And yes I did clean all that up before I buttoned things back so the oil leak I'm seeing is not from the mess of the initial change
Re: Oil change, now leaking 2015 5.7 Hemi [Re: Blue_Goose] #4779954
06/07/18 08:00 AM
06/07/18 08:00 AM
Ohio
hallstevenson Offline
Ohio
That definitely sounds like a problem (the problem ?).
As for replacing just the filter w/o draining the oil, it can definitely be done but it also depends on the location of the oil filter in relation to the sump. On my Infiniti G35, it's mounted high enough that when I removed it (had to replace the oil cooler gasket), I lost 250 ml of oil. If I hadn't measured it, I probably wouldn't have bothered replacing the same 250 ml but since I had a number, I did. On 2WD versions or older versions of this same car, apparently the filter is low enough that you lose A LOT of oil when the filter is removed so draining first is advised. On your vehicle - sorry, no idea. If you do drain it, use a clean pan and put it back in when done. There's nothing wrong with doing that.
Moderated by  ekpolk
