Hello all,
I'm posing this question to you guys as the authority on grease to see what you come up with as the one I should use for my suppressors. The grease needed will be used to lubricate the piston system in the suppressor, otherwise know as a Nielson Device or LID ( linear inertial decoupler. The grease will be subjected to the main blast from the muzzle of the pistol as well as reciprocating mechanical motion.
I called a couple of the manufacturers of suppressors to ask what they use and as I expected they didn't have the best reasons as to why they chose what they recommended. The reason always was, "That's what we've had the best luck with". Here's what I was recommended, in no particular order:
Lucas White Lithium Grease
Loctite Viper Lube
Mobil 1 synthetic chassis grease ( ? )
HAWG Grease
All but HAWG grease have MSDS sheets available and I have become weary of products who hold secret raw data like that as snake oil, I could be wrong though.
here is a link to the HAWG grease for reference:
https://randclp.com/product/hawg-grease-4oz/
HAWG GREASE
From a grease standpoint, in my application, what should I be looking for?
Should I be concerned with the highest melting point, boiling point and flash points? what do those even mean? Do I need synthetic? Is lithium automatically synthetic? Do I have to buy something specific that plays well with the Titanium, Stainless Steel, Inconel and aluminum that these things are made of? How bout the Viton O ring friendly?
I know whatever grease is used will only be good for maybe 100-200 rounds before it either burns off or looses effectiveness, so to some degree the cost of grease may be some what of a factor too.
Anyway, please let me know what you guys think and what I could potentially use. I'll leave a few pics for those who aren't familiar with what I'm talking about. In addition, I will post this in the firearms section as well for those members who may not reach this sub forum. Mods, if one thread must be deleted I'll leave it to you to decide where you think the topic belongs for the most help.
Thanks in advance,
RR
Here is the assembly laid out
Here is a close up of the pistons. the splines will make contact inside the suppressor bottom
here we are looking from the bottom of the suppressor, can you see the contact points the splines from the piston recess into?
Loctite Viper Lube
HAWG Grease
HAWG GREASE
Thanks in advance,
RR
