I need some replacement socket holders and am looking for suggestions. I started with a simple Craftsman "mechanics" set that came with 1/4", 3/8", and 1/2" ratchets, various standard and metric sockets, extensions, etc, etc. It works just fine for me. Problem is, the case never worked well at holding the pieces in place !! After a few years, if you'd pick up the case and hold it vertical (just like it's supposed to be carried), all of the [censored] pieces would fall to the bottom !!
I ended up getting a tool "box" that holds almost all of the stuff I use frequently and in order to hold the sockets, I tried the socket rails that Harbor Freight sells. For the cost, I won't complain, but they have to go now.... I've already snapped too many of the socket holders 'clips' just when simply removing sockets. They're sharp when they're broken too !
What do others use ? I have to say up-front, cost IS a factor. I need holders for 15-20 1/4" sockets, 15-20 1/2" sockets, and 20+ 3/8" sockets. I won't spend $50 on holders. Not interested in the ones that have the size labeled on them either - my OCD will drive me crazy if I have missing ones !
Some I've seen are these:
https://smile.amazon.com/dp/B0789DJSG1/ref=psdc_15709201_t3_B006GUUS5K (probably won't work for me with my toolbox but would be great for hanging)
https://smile.amazon.com/dp/B01N2NWZYQ/ref=psdc_15709201_t2_B006GUUS5K (aluminum, not plastic)
