Originally Posted By: JAG
Thank you emod and Tom! Most motor oils have a much smaller spike at 1735/cm than Red Line, so most motor oils’ additive packages contribute a small amount to the spike there. Suppose that the additive package is assumed to contribute nothing to that spike. Also suppose the esters consist of a blend of the following (assumption) in a proportion that yields a KV at 100C of 9 cSt (assumption), which applies to Red Line 5W-20. For these esters, that proportion of the first to the second ester is 2.23 to 1. Ratio comes from 69% and 31% amounts, relative to combination of the two esters.
Trimelllitate ester:
https://exxonmobilchemical.ulprospector....e=en-us&u=1
Polyol ester:
Tom, would you be willing to make the above assumptions, or those you think are better, and make estimates?
By the way, I looked at the Institute of Materials we sight and they seem to not have data on Red Line oils.
Well there are a few things wrong with your assumptions.
The additives contribute significantly to the oil's viscosity, so the base oil blend viscosity would likely need to be between 5-7 cSt @ 100°C depending on the formulation, not 9 cSt.
The trimellitate ester you reference would not be a good choice for motor oils due to its low VI and high pour point. I have only seen these used in motor oils once, back in the 70s, and then a lighter version. A better high viscosity blending base oil would be a small amount of 100+ cSt PAO, or a large amount of 8 cSt PAO. If the high blend component is to be an ester, a complexed POE or a dimerate would be better.
The POE you reference can be used but is also not the best choice due to the high content of C5 fatty acids in the ester. These can cause odor and possibly corrosion if hydrolyzed. A better and most common choice would be a C8C10 TMP which has a KV100 of 4.4 cSt, a VI of 140, a Noack of 3%, and a pour point of -54°C. Other choices for the ester could include PE or TMP esters with fatty acids C7-10, linear and branched, or complexed or etherized POEs.
Fact is there are many many combinations of different esters, PAOs, and Group IIIs that can be used to make a 5W-20 synthetic oil, and without knowing which choices are in the formulation they cannot be quantified by FTIR. Different esters give different absorbance at 1735 cm-1, and the FTIR cell sample thickness also affects relative absorbance. Just not a useful method for quantifying base oil compositions/ratios in unknown formulations. If you know the complete formulation except for the base oil ratios, then FTIR can quantify the ester portion through methods of addition.
