Originally Posted By: andyd
Wow, cool process,probably ancient. The peening is the final fix. From the looks of it, there is nothing here that couldn't done by a shade tree DIYer. Grade 2 screws could be easily substituted for the fancy shmancy self shearing screws. The jig could be made on a drill press.Once again, I walk away smarter. Thank you all.
Have done it with hardware store stuff, no jig just for giggles. No crack except for the one that I drew on a scrap head.
Did it another way, drilled the two "crack stops" (holes drilled to stress relieve crack ends...the Liberty Bell for e.g...the "flat" end of the crack loses it's intensity), then splitting the distance, one mid span, then mid span of those then mid span until they overlap.
It didn't hold penetrating oil...
