New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Need help d/l'ing vids from JVC GZ-MG27
by daves66nova - 02/26/20 10:18 PM
Need a riding mower
by FirstNissan - 02/26/20 08:32 PM
Just bot Quicken 2020 Premier for
by Ed_T - 02/26/20 08:31 PM
Corona Virus and Car Sales?
by Vern_in_IL - 02/26/20 07:34 PM
Emblem Adhesive Recommendation
by Fitz98 - 02/26/20 07:18 PM
Drain Plug Washer Frozen to Oil Pan
by CrackyWainwright - 02/26/20 06:31 PM
ams OE 0/20 6100 mi 14 KIA 2.4L GDI
by pair of Blazers - 02/26/20 06:17 PM
Any Exotic Brand Dealership Mechanics Here?
by john_pifer - 02/26/20 06:14 PM
Sentra no start
by Aredeeem - 02/26/20 06:07 PM
Sync Update 2016 Cmax
by borgward - 02/26/20 03:30 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
97 registered members (aircooled, 53' Stude, AandPDan, aba4430, advocate, 2015_PSD, 10 invisible), 1,692 guests, and 18 spiders.
Topics301,975
Posts5,206,732
Members70,808
Page 1 of 4 1 2 3 4
Alternate 4Runner Oil #4764323 05/21/18 07:54 PM
2
28gauge Offline OP
2
Have a 2017 4Runner. Manual recommends 0W20. I live in Tucson, AZ and would like to run a higher viscosity, like a 5W30 syn. Manual leaves no room for alternates under different conditions except, for Puerto Rico only. Higher viscosities OK. A little confused? Is the Puerto Rico engine of a different specification or is it just gas mileage/environmental? Any opinions on a higher viscosity causing potential harm?
Re: Alternate 4Runner Oil [Re: 28gauge] #4764333 05/21/18 07:59 PM
PimTac Offline
Still under warranty, I would stick with what Toyota says.
2017 Mazda CX5
Valvoline Advanced Synthetic 0w20
Roki OEM filter.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764334 05/21/18 08:01 PM
Bryanccfshr Offline
I have Mobil 1 0w40in my 2018 trd Pro 4 runner right now. The dealer installed it at my 6month service when I brought the oil and truck in. Had a discussion, pointed out the owners manual and they didnít have a problem with it.
I am going to change my 0w20 in my Tacoma to Castrol magnatec 5w30 @the 5k Service.
The manual specifically says higher viscosity may be better suited if you drive @ high speed or high load conditions.
2018 Trd Pro 4Runner
2018 Tacoma off-road
Dealer 0w20 to M1 0w40 FS -it depends
Re: Alternate 4Runner Oil [Re: 28gauge] #4764338 05/21/18 08:03 PM
Bryanccfshr Offline
The Puerto Rico, Aruba, Bonaire models are the same as the USA models.
Now. If the truck is the same, what is different?
Re: Alternate 4Runner Oil [Re: 28gauge] #4764344 05/21/18 08:06 PM
Zee09 Offline
Go for it.
"If I walked on water, they'd say I couldn't swim."
Re: Alternate 4Runner Oil [Re: 28gauge] #4764348 05/21/18 08:07 PM
R
Reddy45 Offline
R
Engine is a 4.0L 1GR-FE?
My 2015 has the same engine, and in 2015, it was spec'd for 5W30.
But stick with factory spec for warranty and then you can switch.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764366 05/21/18 08:19 PM
M
mx5miata Offline
M
Stick to the what the manual says for warrenty purposes. This is like Nissan Versa - Versa always called for 5w30 now Nissan says 0w20. No changes were reported to engine design.
NAPA FULL SYNTHETIC 0w20 Partsplus oil filter
Wix air filter
Re: Alternate 4Runner Oil [Re: 28gauge] #4764382 05/21/18 08:34 PM
J
jj51702 Offline
J
Yeah don't listen to the engineers that designed the motor...you obviously know better than them right?
Re: Alternate 4Runner Oil [Re: jj51702] #4764396 05/21/18 08:45 PM
cpayne5 Offline
Get out of here with that baloney. Have you read the owner's manual? Didn't think so.
I also have a 2017 4Runner. Toyota's requirements with regards to oil viscosity is not specific (recommends vs requires) and gives plenty of leeway to where you can run just about anything you find on the shelf at WalMart.
Mine will be getting 5w30 (coming up on its first oil change this week, actually), as that's what I have on my shelf. My 2005 (purchased new) has the same engine and has run flawlessly for 136k miles on Xw30s and 40s.
Here are the pertinent sections of the OM:
Re: Alternate 4Runner Oil [Re: jj51702] #4764397 05/21/18 08:45 PM
Bryanccfshr Offline
Thatís why I run 40 and 30 weights in the gr motors. thatís what they are engineered for.
Bunch of good workers in here.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764426 05/21/18 09:30 PM
A
aquariuscsm Offline
A
What I would be interested in seeing is the USDM fsm.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Alternate 4Runner Oil [Re: 28gauge] #4764434 05/21/18 09:46 PM
Snagglefoot Offline
Puerto Rico is well known as a center of engineering excellence so you should be doing what they do. It's a good thing they discuss the use of motor oil at extremely low temperatures in Puerto Rico because it may be so cold your engine might not start. Thank goodness Toyota has addressed this.
If you want the job done right......do it yourself.
Re: Alternate 4Runner Oil [Re: 28gauge] #4764438 05/21/18 09:55 PM
J
JeffKeryk Offline
J
I like 0w stuff. 5w stuff ain't that much different; flows a little less when cold.
My guess is, 5w30 use will result in slightly worse gas mileage.
Other than that... Nada.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Alternate 4Runner Oil [Re: 28gauge] #4764440 05/21/18 09:58 PM
A
aquariuscsm Offline
A
I was curious about my car. Shell Puerto Rico specs 0W20 with no alternates for my Accord just like in the US:
Accord Coupe EX-L 2.4 (Accord Coupe) (G) (2012)
Premium Helix Ultra SN 0W-20
Quaker State Ultimate Durability SAE 0W-20 Full Synthetic Motor Oil
Re: Alternate 4Runner Oil [Re: 28gauge] #4764445 05/21/18 10:10 PM
M
mx5miata Offline
M
Why don't you feel 0w20 will be suffice? confused
Wix air filter
Page 1 of 4 1 2 3 4
