storm door installation question
by FirstNissan - 02/22/20 12:13 AM
Kirkland VS M1
by A_Spruce - 02/21/20 11:24 PM
Ryan Newman bar
by P10crew - 02/21/20 10:16 PM
Good aftermarket shocks and struts?
by Micahmcmeen - 02/21/20 09:49 PM
Oil Marketing
by Mathew_Boss - 02/21/20 09:45 PM
run to your walmart NOW!
by willow - 02/21/20 09:39 PM
When redundancy goes out the window
by Exhaustgases - 02/21/20 08:34 PM
Please help me decide....
by ecureed - 02/21/20 08:03 PM
Flywheel pic
by Chris142 - 02/21/20 07:49 PM
Rislone Hyper Fuel
by rrretiree7 - 02/21/20 07:40 PM
Bosch Brakes
by ChiTDI - 02/21/20 07:16 PM
Which 15W40 for an Onan generator?
by atikovi - 02/21/20 06:39 PM
Valvoline Advanced 5W40 MST
by BurntMusic - 02/21/20 06:04 PM
2014 F250, 6.7L 13,000 OCI Amsoil AME 15w40
by claluja - 02/21/20 05:43 PM
What Are These On My Caliper Pistons?
by Fitz98 - 02/21/20 05:37 PM
Gun carry insurance
by Colt - 02/21/20 05:25 PM
drywall crack. how do i fix it?
by WhyMe - 02/21/20 02:55 PM
Yokohama AVID Ascend GT
by Bottom_Feeder - 02/21/20 02:53 PM
Getting my Chevy 4.3 to 300k
by CharlotteB - 02/21/20 02:16 PM
Hubbs1982, AW4BYT, YOUSSEF, b3e3, Bogdon
70775 Registered Users
47 registered members (Blkstanger, c502cid, blufeb95, bbhero, Bogdon, BusyLittleShop, 3 invisible), 1,385 guests, and 18 spiders.
Topics301,768
Posts5,202,386
Members70,775
Oil accumulator + Bypass Filter = Best Protection? #4763903 05/21/18 11:50 AM
Diesel_Mercedes Offline OP
I want the absolute best protection for my engine , oil accumulator will significantly reduce cold start wear, and will provide a bathed cooling once the engine is shut off.
A bypass filters remove harmful wear materials from the oil.
An oil cooler will reduce will effectively increase the oil's life span and will reduce engine wear because of overall cooler temps.
Anyone have before and after oil analysis of a stock setup vs one with the two devices mentioned above?
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4763906 05/21/18 11:53 AM
J
jj51702 Offline
J
Sounds like a huge waste of time and $
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4763930 05/21/18 12:19 PM
CT8 Offline
Not to dispute any of the claims but how many people have worn out a properly maintained vehicle engine?
2015 F150 2.7
2018 F350 6.2
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4764159 05/21/18 04:34 PM
I
Imp4 Offline
I
Please provide data that justifies your general position that a well cared for engine that is serviced at the manufacturer interval and specification will not provide excellent service over 250k+ miles.
The short answer is that you can't provide this data because nearly any engine from a well known manufacturer will last 250k+ miles with proper maintenance.
If what you're doing is for the benefit of tinkering and personal enjoyment, then by all means proceed.
If you are doing it because of a notion that it is what is required for long engine life and performance, then you're running a fools errand.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4764165 05/21/18 04:41 PM
J
Johnny2Bad Offline
J
I am not generally of the "won't make a difference" camp when it comes to upgrades in almost any system (your engine included) but generally it is true that there is a point of diminishing returns. If you drive more than the average driver (25K or less a year) it may pay off. If not, maybe you just sleep better, or like to experiment and are a hands-on tinkerer who wants to see his own results.
Compared to a single month's car payment, it's actually pretty cheap to do both.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4764332 05/21/18 07:58 PM
slalom44 Offline
I installed what youíre asking about back in 2004. It has worked well for me. I currently have 389,000 miles on my Ď03 Honda S2000 with an Amsoil Dual Remote bypass filter and an electric prelube pump. Most of my OCIs have been 40,000 miles.
Here is my latest UOA:
https://www.bobistheoilguy.com/forums/ubbthreads.php/ubb/showflat/Number/4189775/Searchpage/1/Main/258415/Words/slalom44/Search/true/Amsoil_0W-30_Honda_S2000_40,25#Post4189775
Here is my original post on my setup: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Board=34&Number=762080
Sure, itís overkill for most car owners. And I have no proof that itís saving my engine from wear. But it certainly hasnít hurt me and Iím spending far less time doing oil changes. And based on what I have seen online I believe I have the highest mileage Honda S2000 in the world.
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4764477 05/21/18 10:52 PM
B
BrocLuno Offline
B
What car, what motor? If there is an inherent design flaw, or design weakness (say marginal timing chain lubrication), OR the metallurgy is not there, you won't be going as far as you think...
Getting an all OEM big block Chevy out beyond maybe 250K is not really doable, in most cases. Even worse for many 1980's small blocks.
On the other hand, some Mercedes engines can go 500K and some Hondas can prolly go that far. I would not try going that far with a stock Fiat ...
I don't think there is a Ferrari engine that will go 200,000 w/o an overhaul ... But a Peugeot Diesel might go the distance ...
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: Diesel_Mercedes] #4764505 05/22/18 12:17 AM
That's promising results from the S2000.
Also my engine is the OM603 turbo diesel.
Re: Oil accumulator + Bypass Filter = Best Protection? [Re: slalom44] #4764605 05/22/18 06:03 AM
B
Bxnanaz Offline
B
Just read your your post, that setup you have is sweet! Lots of thought went into it, and it shows.
