Trooper recommends dash cameras
by FordBroncoVWJeta. 01/22/19 07:14 AM
New Harley synthetic 80w-140 gear released
by shanneba. 01/22/19 06:43 AM
Registering a Vacation Car
by ssamaroo01. 01/22/19 06:23 AM
Starter cross reference?
by dlundblad. 01/22/19 05:11 AM
Barkeepers Friend
by jerseyguy123. 01/22/19 02:23 AM
Bag-in-a-box motor oils
by jtr990. 01/22/19 02:10 AM
Inventions of the 1950's - 1970's
by StevieC. 01/21/19 10:26 PM
Fireplace cleaners and price
by 97prizm. 01/21/19 10:23 PM
M1 0w40 extended oci??
by Pinoak. 01/21/19 09:46 PM
Best propane fireplace insert?
by SOHCman. 01/21/19 08:51 PM
Save 1/4 on gas!! Guaranteed!!
by Linctex. 01/21/19 08:50 PM
Funny names
by Chris142. 01/21/19 08:45 PM
Kendall vs Total Qaurtz
by zeke1985. 01/21/19 08:32 PM
Got a weird one - Helping a friend
by StevieC. 01/21/19 08:32 PM
Thanks 14Accent
by clinebarger. 01/21/19 08:07 PM
Mobil 1 5W30 C7 Z06
by PLRX. 01/21/19 07:40 PM
How cold is it? (Humor)
by StevieC. 01/21/19 07:13 PM
Slight performance decrease
by A_User55555. 01/21/19 06:54 PM
Binco, Coolbreez1973, jmcast1127, DF8005, FT86dude11
67009 Registered Users
112 registered members (53' Stude, 4WD, alteredtuning990, 2strokeNorthstar, AandPDan, 9 invisible), 1,718 guests, and 30 spiders.
Topics296,966
Posts4,962,521
Members67,009
Most Online2,821
Yesterday at 01:32 PM
Non HM Oil for 2010 Prius #4753111
05/10/18 01:34 PM
05/10/18 01:34 PM
N. Calif - State of Jefferson
Greg L Offline OP
Greg L  Offline OP
Just traded our 2007 Prius in for a 2010 model. No major issues yet, and slight oil consumption from what I can see.
Question: Since I have run out of my HM oils (in lower weight) from the stash, I plan on just using the remaining 0w40 and 5w30 that I have left.
Engine has 150k miles, and being that it is high mileage...what do you suggest as an Additive for HM suppliment?
I figure that I wont be buying more HM oil until next December at AZ. Maybe now is a time for a trial of HM suppliment, like Berryman B-60, Lucas, etc.
Thoughts?
1951 GMC 1/2 Ton 270ci
2008 Jeep Compass 2.4
2010 Toyota Prius 1.8
2011 Dodge Ram 1500, 5.7 Hemi
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753150
05/10/18 02:23 PM
05/10/18 02:23 PM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
Can you first confirm you have (or Not) one of the oil eating Prii?
Like check the dipstick every week?
Do you drive at high-speed or high-elevation/tall hills?
Also, do you know any history about the car?
any maintenance/dealer/etc?
Oil, use what you want. I think some people said they had less mpg with the Xw40 oils...
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753157
05/10/18 02:35 PM
05/10/18 02:35 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted By: Greg L
... No major issues yet, and slight oil consumption from what I can see.
... Engine has 150k miles, and being that it is high mileage. ...
How much consumption do you mean by "slight"? Some Prii of that generation apparently turn into serious oil guzzlers, well before that moderate mileage, even if supposedly well maintained. Some don't. What makes the difference isn't clear. Coking of rings is suspected.
Mine is ok, so far.
2011 Toyota Prius now at 95K
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753170
05/10/18 02:52 PM
05/10/18 02:52 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Depends how itís consuming oil. If itís rings, thereís not much you can do. If itís valvestem seals, recommend ATP AT-205 Re Seal.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: EDGE 0W-30
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753174
05/10/18 02:56 PM
05/10/18 02:56 PM
Greg L Offline OP
Greg L  Offline OP
Had it one week, dipstick went down about 1/8". Carfax was good; original owner regularly maintained it by dealer or lube shops.
Mostly hill driving (80%) and freeway (20%).
Never heard of ATP AT-205...will look into it.
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753204
05/10/18 03:29 PM
05/10/18 03:29 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I wouldn't worry about it for a few oil changes.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753310
05/10/18 05:33 PM
05/10/18 05:33 PM
Virginia
mattwithcats Offline
Virginia
The Prius is known to be tough on oil.
A full synthetic 5W-30 or 10W-30 would be my choice.
I am adding one cop (8 ounces) of Mobil 1 Racing 0W-30 as an additive,
has double the add pack of normal oil...
https://www.walmart.com/ip/Mobil-1-Racing-Synthetic-Motor-Oil-0W30-1-Quart/55502854
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753328
05/10/18 05:47 PM
05/10/18 05:47 PM
MN
oil_film_movies Offline
MN
The chief difference between an HM oil and a regular oil for newer engines is the extra seal conditioners. LiquiMoly Motor Oil Saver since it's mosty just seal conditioner.
https://products.liqui-moly.com/media/ca...95/1/8/1802.jpg
"Regenerates rubber and plastic engine seals such as shaft seals and valve stem seals and prevents oil stains under the vehicle. Counteracts oil dilution. Reduces engine noise and oil consumption through piston rings and valve guides."
Amazon, NAPA auto parts stores.
matwithcats, Using Mobil1 Racing 0w30 should only be used as top-off oil in the last half an oil change interval after the original oil's additives are degraded somewhat. New oil doesn't need anything yet, and more may not be better. Last half of the OCI, maybe yes, a small additive boost wouldn't be bad I'd think.
Re: Non HM Oil for 2010 Prius [Re: mattwithcats] #4753359
05/10/18 06:19 PM
05/10/18 06:19 PM
Rabbit Creek, Alaska
jayg Offline
jayg  Offline
If you've just noticed it dropped slightly in a week 1/8" on the dipstick, that could be anything. I would change it was a fresh 5w30 HM Full Syn oil and then run it for a full 10k mile OCI to see where you're at. Those 1.8 engines of that vintage were spotty with oil burning and doesn't apply to even all of those. Our 1.5 has been 100% perfect since new on whatever the cheapest full syn 0w20 I can find at the time of the OCI.
2018 Ford Ecosport AWD- Napa 0w20
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
1973 Triumph Bonneville 750- M1 5w50
1967 BSA 441 Victor Special- M1 5w50
Re: Non HM Oil for 2010 Prius [Re: mattwithcats] #4753408
05/10/18 06:56 PM
05/10/18 06:56 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
Good find. Sounds like a plan Stan.
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753753
05/11/18 04:51 AM
05/11/18 04:51 AM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
You do realize that car calls for 0w20, don't you? We have a similar 2010 Prius with over 165k on the clock. It sees a 10k OCI at the dealership and doesn't require any makeup oil. Then again, we are not driving on hilly terrain here in SE Pennsylvania.
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4753934
05/11/18 08:01 AM
05/11/18 08:01 AM
Maricopa, Arizona
dave1251 Online happy
dave1251  Online Happy
Maricopa, Arizona
Use whatever you have and keep it topped off.
don't use.
Re: Non HM Oil for 2010 Prius [Re: Astro_Guy] #4753956
05/11/18 08:11 AM
05/11/18 08:11 AM
jayg Offline
jayg  Offline
2010 was the switch over year and itís funny that so many people were hesitant to run the ďexpensiveĒ 0w20 at the time so many , including dealers still put 5w30 in them. Either way wonít kill it but I think he needs to do a full 10k to see if he even has a problem.
Re: Non HM Oil for 2010 Prius [Re: Greg L] #4754243
05/11/18 01:01 PM
05/11/18 01:01 PM
California
nthach Offline
nthach  Offline
California
I'd run the 5W-30 you have. Then work on stocking up on xW-20.
Prii are known for coked rings, at least on the 2nd gen cars. My 09 was starting to drink oil but I've been running MMO for 1000 miles before an OCI to try to clean things up a bit. I recently added a little Neutra to my oil at 500 miles out. Jury's out on that one.
Re: Non HM Oil for 2010 Prius [Re: nthach] #4754278
05/11/18 01:27 PM
05/11/18 01:27 PM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
2010 was the first model year of the 3rd generation Prius. They have a different and larger engine than your 2009.
