Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
25 registered members (Char Baby, ABN_CBT_ENGR, 87sammy, 77GrandPrix, Amkeer, 5 invisible), 898 guests, and 58 spiders.
Topics306,080
Posts5,286,981
Members71,596
Lucas Marine Grease Formula Change #4748115 05/04/18 10:29 PM
R
racerdude321 Offline OP
R
Hi All,
Great forum, I've lurked for awhile but just now joined up.
I've been using Lucas Marine grease as my go-to for years. I use it in everything from my Volvo boat outdrive, Craftsman riding lawn mower spindles, Dexter EZ-lube trailer wheel bearings, to my New Holland tractor backhoe pins, etc. I went to grab a new tube today and noticed that is was now an OBCS (Overbased Calcium Sulfonate) rather than the lithium-complex I've been used to using. I'm worried because the 4 ball wear and the timken load lb ratings have gone down. Will it be okay for the shock loads in the backhoe pins and boat outdrive anymore?
So should I use the new formula or should I look into a different grease? Or am I overthinking it? I'd really like to continue using just one grease for everything.
Current Tech Sheet:
https://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Wayback showing the old Tech Sheet as of 2/2/18:
https://web.archive.org/web/20160413034512/http://lucasoil.com/pdf/TDS_Marine_Grease.pdf
Thank you.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748135 05/04/18 11:02 PM
MolaKule Offline
Global Moderator
Global Moderator
Nope, the OBCS/polymer greases are the big deal today.
Amsoil uses a similar formula.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4748236 05/05/18 07:03 AM
N
njohnson Offline
N
In the case of the Timken load lb rating, higher is better. For the 4 ball wear number, lower is better. It means the wear scar being produced is lower. I think that is the way the numbers work. I could be wrong.
Re: Lucas Marine Grease Formula Change [Re: racerdude321] #4784986 06/12/18 03:27 PM
M
monster1 Offline
M
It's been this new calcium based formula for at least a few years now as that's the stuff I bought a few years ago when I replaced an axle with a damaged spindle.
