Originally Posted By: spasm3
No experience with that brand, never heard of them. 4 O2 sensors for $59? And he has make an offer??
Too cheap to be a quality part.
I have used denso 02 sensors with no problems.
Denso upstream, not that much more.
https://www.amazon.com/Denso-234-4045-Ox...s=DENSO+2344045
Denso down stream sensors
https://www.amazon.com/Denso-234-4127-Ox...s=DENSO+2344127
Do you have codes? Down stream sensors rarely fail. I'd buy quality upstream sensors and leave the down stream. If the front 02 sensors have been bad for a while, the cat may already be bad, and the downstream sensors are fine , just the cat isn't.
Ditto the above although you could also get them from Rockauto.com. Might be slightly cheaper with the 5% off code and especially if you have other minor items to add to the order.
I used Denso's in a Ford Taurus, never changed the downstream ones and the car had over 200k on the originals when I got rid of it. Technically it's a little more money because they're about $25 each instead of $15 each for 4 of them, but if you just get 2, it's still cheaper than $60 for 4. But yeah, I'd rather get a name brand part. I think my Denso's even came with a tube of lube.
