Using a d1G2/SN Plus oil in a TGDI engine is a good idea, but it won’t make much of an LSPI difference until engine programming is adjusted to assume it is in the crankcase.
For non-GM makes at least, engines exit the production line assuming the engine will be using a traditional, non LSPI-preventing oil and will be programmed to enrich mixtures under any throttle/rpm combination that conceivably could create LSPI. Merely putting in a d1G2/SN Plus oil won’t change this.
Once reformulated oils are dominant or required, programming can be changed and lower fuel dilution and better fuel economy will likely result. A reasonable question is what OEMs will do for owners of legacy TGDI platforms when this time comes.
