Post your latest oil change
Originally Posted By: NormanBuntz
Originally Posted By: Elijah1
Changed the oil in my gf’s 2002 Honda Odyssey. It has 212,000 miles.
Out: two and a half quarts of some thick and nasty sludge
In: Quaker State high mileage 5w30 and a NAPA gold filter.
Also changed spark plugs, air filter, and PCV valve while the oil was dripping.
Not bad for an hour’s work.
Out came 2.5 quarts? So it was two quarts low? Oh no.
Affirmative. When it stopped dripping after 2.4 seconds, my sphincter got tight. Poor neglected van. Hopefully she’ll let me continue to look after maintenance.
2014 Toyota Sienna L (3.5L V6), ~71k miles on car, ~6300 miles on oil
out: whatever the dealer put in there
in: 6qt Mobil 1 0w20 AFE + ~0.7qt Mobil 1 5w30
I would have replaced the cartridge filter with a Toyota OEM cartridge, but I could not get the dang thing off. Wouldn't budge at all when I just yanked on the wrench unassisted, and when I got a makeshift cheater bar I sheared the drive socket of a cast aluminum cartridge filter wrench trying to break it loose. I suspect that the dealer installed the cartridge filter before screwing the filter drain plug back in, resulting in the canister body getting grossly over-torqued. I think I'm going to try and find a sturdier (steel?) filter wrench and give it another go at a ~5k OCI, as Toyota specs a 10k OCI for regular service and a 5k OCI for severe service. The oil pan drain plug was also a bear to get loose, but I was able to get it off using the cheater bar without breaking anything.
2017 Subaru Crosstrek Limited, 6047 miles on car, 4000 on oil
out: Dealer bulk Mobil 1 0w20, Subaru filter (1st Oil change)
in: Dealer bulk Mobil 1 0w20, Subaru filter
next change at 12000: QSUD 0w20, wix 57055 filter
You probably know there are canister removal caps that have slots for the ridges in the plastic canister.
Mine has a large hex bolt cast into the cap as well as a 1/2" drive.
Get out your long breaker bar and get that canister off.
I have heard some use an impact with short bursts.
You know, I believe the proper torque is something less than 20 pound/feet.
Good luck and please post your results.
That's what I was referring to when I talked about shearing a filter wrench trying to get that canister off. One of these guys, specifically: https://www.amazon.com/gp/product/B073XF45NF/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 . The part where you put the 3/8" drive in isn't a square any more (it sheared rather than getting stripped - the sides look like an earthquake fault line) and the canister didn't budge. I'm considering finding somebody who makes a steel one for attempt #2.
When I did the oil on my friend's cobalt, the canister was very hard to remove as well. I didn't have the proper tool as I don't own a vehicle with one. Ended up using an adjustable wrench very carefully. Will buy the tool for next time! I have a 32mm socket but the angle of the canister made it impossible to use.
So anyone get their oil changed recently?
If you saw my C&p from Monday you will see I changed oil in my Corolla
Neighbor's 2010 Honda Accord w/93,800 mi.
IN: 4.75 qt. of Castrol 0W-20, Castrol filter
Installed my first Fumoto valve.
Big report come Oct./Nov.
The Fumoto landed in what looks like an optimal angle.
I used oil resistant sealer
2011 200:
Mileage 55679
In: 3qts Pennzoil Euro syn 5w30
3 qts Castrol Magnatec 5w30
STP cartridge filter
Also today:
Rotate, balance tires
Alignment
New rear brake pads & rotors
2017 Buick Regal GS 2.0T
Mileage 2020
In/Out Pennzoil Platinum 5w30
Napa Platinum 47045 filter
2005 Subaru Baja in signature (94,006 miles)
Out -- PHM 5W30 & ST filter (3202 miles)
In -- Shell Rotella T6 5W30 Multi grade -- 4.5 quarts & ST filter
2007 Toyota Yaris, 128,358 km
out: 2L mobil 1 5w30 + 1.7L mobil super 1000 5w30, pronto oil filter, 8249 km oci
in: 3.7L valvoline synpower 5w30, fram tough guard oil filter
'17 Subaru Forester, 12,152 car, about 6300 oil, oil run 11/2/17 to 4/21/18.
Out: M1 0W-20 AFE, Fram Ultra
In: MSS 0W-20, Fram TG
Subaru backed the drain intervals down to 6K from 7.5K on these engines and since I have warranty out to 100K on the engine, I'll be using 0W-20 and doing 6K drains for some time to come.
