New car wax score
by Marco620. 01/16/19 02:42 PM
Bought a used Cherokee Trailhawk
by Sunnyinhollister. 01/16/19 02:34 PM
Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
113 registered members (aircooled, 28oz, 4WD, advocate, 2002 Maxima SE, 9 invisible), 2,200 guests, and 33 spiders.
Topics296,645
Posts4,956,535
Members66,950
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Is there a difference between ceramic pads? #4728239
04/15/18 07:19 PM
04/15/18 07:19 PM
Connecticut
cheesepuffs Offline OP
Connecticut
Looking at ceramic pads, there is a range of prices across the major brands. Is paying a premium for a ceramic Akebono worth the money over a cheaper ceramic pad from Bendix or anybody else? Or is it a situation like API certified oils where say each SN oil is made within a tiny window anyway, to the point where it hardly even matters which one you choose? Iím ok with ponying up a few more bucks if itís going to really be better, but I donít want to throw money down the drain if itís just paying for a name. What brands have you guys used and liked yourselves?
2008 Honda Accord Coupe V6
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728250
04/15/18 07:27 PM
04/15/18 07:27 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Any specific reason you want ceramic pads?
I know they tend to run cleaner but for general driving purposes, I've felt like semi metallic had better bite when stopping.
I would go off reviews about the particular line of brake pad you are thinking about rather than try and make a brand to brand comparison. Certain brands do command a premium like EBC, but at a low enough price point with brands like Raybestos, you're just picking a name.
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728257
04/15/18 07:31 PM
04/15/18 07:31 PM
CA
The Critic Online crying
The Critic  Online Crying
CA
Yes. Some have poor brake performance when cold, some tend to be noisy, some are very intolerant of high brake temperatures and will leave very heavy pad deposits on the rotors which causes premature vibration issues.
Many of these pads were never tested in the applications they are recommended for. Aftermarket companies generally have very little or no R&D capabilities. Pad lines often use only a handful of formulations for the entire lineup.
I am not saying that dealer pads will always be the best option out there, but they tend to provide the most consistent results.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: Is there a difference between ceramic pads? [Re: Reddy45] #4728261
04/15/18 07:35 PM
04/15/18 07:35 PM
Connecticut
Connecticut
Yeah I want the low dust properties of a ceramic. I know itís a sacrifice, but how much worse have ceramics been in your experience in terms of bite? I donít want to completely ruin my braking response either
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728264
04/15/18 07:40 PM
04/15/18 07:40 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I can't comment on premium pads but I bought some AC Delco Advantage Ceramics a few years ago for $27 and probably have 100k on them and they work great. I'll probably buy them again when these wear out.
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728269
04/15/18 07:46 PM
04/15/18 07:46 PM
Outer Banks, NC
NormanBuntz Offline
NormanBuntz  Offline
Outer Banks, NC
I put Sangsin brand ceramic pads on my Ridgeline and am very happy with them. They were $36 (now $42) and are a South Korean brand. Bosch may be a moderately priced brand you can buy to save a few bucks. I'd stay away from cheap ceramic pads that are $20-$25--you usually get what you pay for. Also, forget about machining your rotors. Not worth it.
2017 Honda Odyssey SE, 17K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728274
04/15/18 07:48 PM
04/15/18 07:48 PM
New England
gathermewool Offline
New England
Better is relative. How do you drive (I.e., how do you brake)? I had OE pads last > 60k miles in an STI. I like to anticipate and engine-brake as much as possible. Most of the other people I see on the road seem as if the accelerator/brake pedal are more of an on/off switch than anything. Still again, others are smart albeit aggressive drivers.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Is there a difference between ceramic pads? [Re: NormanBuntz] #4728282
04/15/18 07:54 PM
04/15/18 07:54 PM
Connecticut
Connecticut
Oh Iím totally with you regarding rotors. Theyíre so cheap now that thereís no point in turning rotors anymore and I expect parts stores and shops will soon be scrapping their brake lathes if they havenít already.
Re: Is there a difference between ceramic pads? [Re: Warstud] #4728285
04/15/18 07:55 PM
04/15/18 07:55 PM
Connecticut
Connecticut
Thatís what I like to hear. Iíve read that ceramics are very easy on rotors and last a long time, and 100k miles is quite the feat!
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728290
04/15/18 07:59 PM
04/15/18 07:59 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I put ceramic TRW ceramic brake pads front and rear on a former neighbors Hyundai Sonata. They are an OEM supplier of brake pads for some vehicles.
They were priced good on Amazon.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728296
04/15/18 08:03 PM
04/15/18 08:03 PM
Illinois
wymi516 Online content
wymi516  Online Content
Illinois
2016 KIA Forte SX 1.6L T-GDI Daughter
2013 Chevy Impala LT 3.6L GDI Mine
2014 Chrysler 200S 3.6L PFI Wife
Re: Is there a difference between ceramic pads? [Re: wymi516] #4728301
04/15/18 08:10 PM
04/15/18 08:10 PM
Connecticut
Connecticut
Akebono is what Iím leaning toward, but are they really better than others like Bendix or PowerStop these days?
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728317
04/15/18 08:31 PM
04/15/18 08:31 PM
NY
Kage860 Offline
Kage860  Offline
NY
Generally more expensive brakes pads will be better. In the grand scheme of things though the best brakes in the world wont matter if you have cheap or worn tires. Rotors donít matter as much.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728365
04/15/18 10:10 PM
04/15/18 10:10 PM
It's hard to put a number on it, but I felt like the brake pedal needed about 35% more effort to make a panic stop with ceramic pads. (compared to semi-metallic)
Basically you can feel that there is less friction with the ceramics.. but yes they were a TON cleaner.
Re: Is there a difference between ceramic pads? [Re: cheesepuffs] #4728445
04/16/18 04:17 AM
04/16/18 04:17 AM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
Yes, there are differences in ceramic pads. I put akebonos on my Intrepid, which is large and fairly heavy, and braking improved significantly.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Page 1 of 3 1 2 3
