Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
111 registered members (1WildPig, ABerns, 2012AccentSE, 2K2AcuraTL, 69Torino, 1leater, 9 invisible), 2,182 guests, and 171 spiders.
Topics286,196
Posts4,904,009
Members67,576
Most Online2,967
Mar 10th, 2019
Need suggestions for a gear oil that has clutches #4728004
04/15/18 04:53 PM
04/15/18 04:53 PM
Missouri
fnbrowning Offline OP
Missouri
Iím curious if anyone could make a suggestion for me. There is this machine that has a gear box that is driven by a 3ph motor. The gear box itself has standard cut gears and its selectable for range speeds. Thereís also a DC electromagnetic clutch pack and engages and disengages for the final drive. RPMS are relatively low. Bushings/Bearings are all bronze.
I donít have any details on the manufacturer of the gear box, as it is a French made 1970's milling machine that has very little to no technical support. What little documentation is a torn and tattered machine equipment brochure and 1/4 of the electrical schematics, in French.
It does not get hot, it will get "warm" but nothing near hot. Slightly above room temp and thatís if its running for hours and its not. It gets switched on and runs for 30 seconds to a minute then cuts off. on an "as needed" basis.
Any suggestions?
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728016
04/15/18 05:05 PM
04/15/18 05:05 PM
Somewhere in time
Imp4 Online sleepy
Imp4  Online Sleepy
Somewhere in time
I understand that it is French.
What is the name on the torn and tattered brochure?
2001 Mitsubishi Galant 2.4 - 162k+
Grandma's creampuff...
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728031
04/15/18 05:18 PM
04/15/18 05:18 PM
Missouri
Missouri
It's French built, but branded Cincinnati Toolmaster. which normally would be a blessing because Cincy TM's are all over the place and well supported. But Milicron made this abomination of 3hp 40 taper VS monster with a powered 56" table! Metric hardware on the entire machine, but imperial screws and dials!
I'm your biggest fan, Ms Blake. .
Well, the most heavily armed anyway
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728040
04/15/18 05:24 PM
04/15/18 05:24 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
From that description it seems an ATF would fit the bill, Maxlife.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728068
04/15/18 05:43 PM
04/15/18 05:43 PM
Virginia
mattwithcats Offline
Virginia
Either GL-4, which is thick, (50 weight oil)
Or Dexron III, which is thin. (10 weight oil)
How much do you need?
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728073
04/15/18 05:46 PM
04/15/18 05:46 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
sounds like you dont want anything resembling automotive gear oil.
I'd find a similar type of machine and use whats recommended there.. its probably some obsolete fluid you cant find anyway.
Re: Need suggestions for a gear oil that has clutches [Re: Rand] #4728097
04/15/18 06:13 PM
04/15/18 06:13 PM
Missouri
Missouri
As for similar, the best I can do is hearsay from someone who used to have one of these machines, but he's not sure if it was the same model. His was a French made Cincinnati Milacron. Just from memory he couldn't state the specific oil for the gear box but remembers it was very light viscosity, maybe as light as 10W?
I just came here hoping I'd run into someone who deals with more technical questions daily on the industrial side of oil.
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728117
04/15/18 06:33 PM
04/15/18 06:33 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would try a 20wt or 30wt non-detergent oil...but if it never gets warm as you say.. thinner should be fine.
But that is just a guess of course.
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728121
04/15/18 06:38 PM
04/15/18 06:38 PM
Somewhere in time
Imp4 Online sleepy
Imp4  Online Sleepy
Somewhere in time
So is it 0.200" per turn on the table handle or something metric???
Re: Need suggestions for a gear oil that has clutches [Re: Dyusik] #4728147
04/15/18 07:02 PM
04/15/18 07:02 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Check. Relatively low viscosity, normally used with gears and internal clutches, widely available.
And relatively cheap
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728155
04/15/18 07:08 PM
04/15/18 07:08 PM
Somewhere in time
Imp4 Online sleepy
Imp4  Online Sleepy
Somewhere in time
Here's an operators manual in English. Have a look at pages 12 & 13.
They state P-37, P-43 & P-55 lubricants as Cincinnati spec numbers.
Cincinnati Toolmaster Operators Manual
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728172
04/15/18 07:21 PM
04/15/18 07:21 PM
Somewhere in time
Imp4 Online sleepy
Imp4  Online Sleepy
Somewhere in time
Here's the P-55
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728213
04/15/18 07:55 PM
04/15/18 07:55 PM
Northern, NY
Rob_Roy Offline
Rob_Roy  Offline
Northern, NY
Universal Tractor Fluid (e.g. JD Hy-gard) would be my choice.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Need suggestions for a gear oil that has clutches [Re: fnbrowning] #4728287
04/15/18 08:56 PM
04/15/18 08:56 PM
Virginia
Virginia
2009 Smart Pure
Re: Need suggestions for a gear oil that has clutches [Re: Rob_Roy] #4728289
04/15/18 08:58 PM
04/15/18 08:58 PM
Missouri
Missouri
Thanks to all; I believe I have the answer I need.
Thanks also to Imp4 for going afield to find and post copies of the manual and lube page.
Goodnight all!
