CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
62 registered members (4WD, antik, 87sammy, Anthony, 2015_PSD, A1O, 8 invisible), 768 guests, and 26 spiders.
Topics287,674
Posts4,932,037
Members67,838
Most Online2,967
Mar 10th, 2019
Deciphering Alternator wires #4727522
04/15/18 09:12 AM
04/15/18 09:12 AM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Hi everyone,
My ECU is storing an alternator FR terminal code.
It is a 4 pin alternator and just wonder what the 4 wires would be for and how to decipher which one each is?
Of the 4 pins/wires I know only which one the FR signal is and for testing purposes I'd like to know what the other 3 are.
2003 Mitsubishi Diamante 6G74 3.5L. 5 Speed auto. 160,000 miles. Shell Helix Ultra 5W40 at 6k OCI
Re: Deciphering Alternator wires [Re: Spetz] #4727589
04/15/18 10:04 AM
04/15/18 10:04 AM
MN
14Accent Offline
14Accent  Offline
MN
I'm only seeing a 2-wire connection on the alternator diagram for an '03 Diamante.
The RD/WT wire comes from fuse 8 in the engine compartment relay box, and the WT wire comes from the generator relay in that same box. The generator relay passes power from fuse 12 in the interior fuse box.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Deciphering Alternator wires [Re: Spetz] #4727612
04/15/18 10:22 AM
04/15/18 10:22 AM
ME
eljefino Offline
eljefino  Offline
ME
Usually it's field pos, field neg, +12V voltage sense (to cover for loss on the big wire), dash warning light, and big-lug positive out.
Re: Deciphering Alternator wires [Re: Spetz] #4728111
04/15/18 06:27 PM
04/15/18 06:27 PM
Australia
Spetz Offline OP
Spetz  Offline OP
Australia
Thanks guys,
It's not for my Diamante, it's for a Mitsubishi Mirage with a 6A12 engine swap from an FTO.
It is throwing an "Alternator FR Terminal" error and has a 4 pin type plug.
I've replaced the alternator and tested a different ECU but the error still shows up.
So to do more testing I am trying to figure out which wire is which
