2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
79 registered members (advocate, alcyon, bbhero, 4WD, 555, 2015_PSD, 9 invisible), 1,699 guests, and 108 spiders.
Topics286,477
Posts4,909,138
Members67,635
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
WIX 51516XP Cut Open #4726785
04/14/18 01:58 PM
04/14/18 01:58 PM
TN
HX520W Offline OP
HX520W  Offline OP
TN
This filter was used on a 1997 Saturn SL1 SOHC for 3,500 miles and nine months. The car has 151,000 miles on it and is averaging 1qt every 1,000 miles. The car has been neglected in the past and even run with the oil level so low that the oil pressure light flickered up hills...
The filter has ~131.5 square inches of media (~848 square centimeters).
Notice how much debris is caught between the pleats on the right side of the picture.
Close-up of media
Bypass valve components
I'm not a huge fan of the way that the spacer that holds the ADBV mounts to the filter cartridge. I'd prefer it if there was some sort of gasket between the two parts instead of having metal on metal contact. Either way, I doubt it makes much of a difference.
Close-up of the media after it was removed from the end caps
The wire mesh behind the media is coated.
This is what I was able to scrape out of a few of the pleats. The debris is mostly made up of solid pieces of carbon.
This is what the top of the engine looked like when I replaced the valve cover gasket yesterday.
Re: WIX 51516XP Cut Open [Re: HX520W] #4726790
04/14/18 02:09 PM
04/14/18 02:09 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Oil filter did its job but that engine has seen better days..
Re: WIX 51516XP Cut Open [Re: HX520W] #4726791
04/14/18 02:10 PM
04/14/18 02:10 PM
Alberta
BigJakeChevy Offline
Alberta
Fantastic post! Thank you!
2007 Silverado Classic 1500 Crewcab 5.3L 470,000KM
Engine oil Mobil 1 0w40fs
Oil Filter Fram Ultra 10575
Trans Oil Amsoil Torque Drive
Front Diff Amsoil SG75w90
T-Case Autotrak II
Rear Diff Amsoil SG75w110
Re: WIX 51516XP Cut Open [Re: HX520W] #4726798
04/14/18 02:20 PM
04/14/18 02:20 PM
Maricopa, Arizona.
dave1251 Offline
dave1251  Offline
Maricopa, Arizona.
Thank you. Great detail in the photos.
don't use.
Re: WIX 51516XP Cut Open [Re: HX520W] #4726799
04/14/18 02:22 PM
04/14/18 02:22 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
Thanks for the cut and post. Motor hasn't seen much love. Did you try to remove that gunk from under the valve cover?
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: WIX 51516XP Cut Open [Re: HX520W] #4726874
04/14/18 03:31 PM
04/14/18 03:31 PM
Toronto Canada
WobblyElvis Online content
WobblyElvis  Online Content
Toronto Canada
I supposed that carbon is the result of a great deal of blow by. I think you will find more carbon built up at the end of the filer where the by pass valve is. When it goes into bypass, the oil must flow in that direction and carry the debris with it. Maybe run a cheap filter and change it often. Nice Pics!
Re: WIX 51516XP Cut Open [Re: HX520W] #4726877
04/14/18 03:33 PM
04/14/18 03:33 PM
USA
oldhp Offline
oldhp  Offline
USA
That's one well built oil filter. Thanks for the C & P!!!!!
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: WIX 51516XP Cut Open [Re: HX520W] #4726879
04/14/18 03:36 PM
04/14/18 03:36 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Filter looks great imo. Engine meh, not so much. However, I've seen worse.
As for the metal on metal spacer, coil compression spring exerts substantial pressure for seal as opposed to a leaf spring IME. In majority Wix/NG the thread end bypass fills that space, however all XP's use dome bypass so spacer used. I suspect after all these years using the design, they have tested it a time or two.
Thanks for c&p.
Re: WIX 51516XP Cut Open [Re: HX520W] #4726914
04/14/18 04:02 PM
04/14/18 04:02 PM
Texas
Irishman Offline
Irishman  Offline
Texas
Very good cut and post, excellent photo's and I appreciate everyone's comments. I have a pretty new '18 Kia Sorento with the 2.4 L engine. I am seriously considering the WIX XP or the Fram Ultra filter for this car.
Re: WIX 51516XP Cut Open [Re: HX520W] #4726940
04/14/18 04:46 PM
04/14/18 04:46 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
Just kind of curious I didn't see what kind of oil you're using in that Saturn?
2004 Corolla 130107
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: WIX 51516XP Cut Open [Re: HX520W] #4726974
04/14/18 05:49 PM
04/14/18 05:49 PM
Great White North.. eh
webfors Offline
webfors  Offline
Right filter for the application IMO. Great C&P.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Mopar MO-349
15 DL650, Rotella T6 5w40, KN-138
Small engines; RT5 10w30
Re: WIX 51516XP Cut Open [Re: HX520W] #4726985
04/14/18 06:08 PM
04/14/18 06:08 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
Great looking filter. Really like the bypass valve design.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: WIX 51516XP Cut Open [Re: HX520W] #4727003
04/14/18 06:30 PM
04/14/18 06:30 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Wow i'd do a lot short oil changes...
Thanks for the pics...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: WIX 51516XP Cut Open [Re: HX520W] #4727013
04/14/18 06:44 PM
04/14/18 06:44 PM
Boston
sgtrockjoe Offline
sgtrockjoe  Offline
Boston
Good job. Thanks for posting.
Re: WIX 51516XP Cut Open [Re: HX520W] #4727093
04/14/18 08:12 PM
04/14/18 08:12 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It looks like a good well built filter, thanks for the C&P.
Page 1 of 3 1 2 3
