Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
30 registered members (billt460, Bailes1992, ArrestMeRedZ, 4WD, 2015Corolla, alcyon, 3 invisible), 492 guests, and 57 spiders.
Topics286,442
Posts4,908,271
Members67,622
Most Online2,967
Mar 10th, 2019
Old washer change torque? #4722797
04/10/18 02:08 PM
04/10/18 02:08 PM
New England
pda1122 Offline OP
pda1122  Offline OP
New England
Just wondering if reusing your old drain plug washer has any effect on torque values. Iím guessing itís very minimal but something to think about
‚Äė19 Grand Caravan- factory fill
'13 Toyota Tundra 5.7-Idemitsu 0w-20/OEM
'08 Hyundai Elantra-Havoline 5w-30/Fram 9688
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
‚Äė01 Kawasaki KDX 220r
Re: Old washer change torque? [Re: pda1122] #4722827
04/10/18 02:57 PM
04/10/18 02:57 PM
Ontario, Canada
newbe46 Offline
newbe46  Offline
Ontario, Canada
I have re-used old drain plug washer on a few occasions. I don't recommend it but if I must do it, I won't lose sleep over it either. Assuming my torque wrench is calibrated spot on, then I might just put another lb-ft more than what's called for. As long as I don't see any drips of oil from the drain plug, I'll call it a day.
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: Old washer change torque? [Re: pda1122] #4722837
04/10/18 03:08 PM
04/10/18 03:08 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I've used the same combo wrench for years on my drain plugs so I have a good feel for when everything is tight enough. I reused a crush washer once and it caused a leak. I had to go back and snug up the plug an extra 1/16th of a turn to stop the leak. A new crush washer wouldn't have needed that extra snugging up.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Old washer change torque? [Re: pda1122] #4722849
04/10/18 03:30 PM
04/10/18 03:30 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Why would you reuse a crush washer?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Old washer change torque? [Re: pda1122] #4722881
04/10/18 04:09 PM
04/10/18 04:09 PM
USA
mk378 Offline
mk378  Offline
USA
The torque spec is based on not stripping the threads. If it leaks when properly torqued, you need a new washer.
Re: Old washer change torque? [Re: pda1122] #4722907
04/10/18 04:51 PM
04/10/18 04:51 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
When I have reused them I just flip them around. When you have to pry them off the plug threads then I change them.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Old washer change torque? [Re: pda1122] #4722932
04/10/18 05:45 PM
04/10/18 05:45 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've reused them. Never used a torque wrench. Just get it good and snug.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Old washer change torque? [Re: pda1122] #4722965
04/10/18 06:25 PM
04/10/18 06:25 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
I have never replaced my washers....ever. And I use my arm for my calibrated torque wrench. Never have had a leak.
Re: Old washer change torque? [Re: SHOZ] #4722987
04/10/18 06:47 PM
04/10/18 06:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Same here... still serviceable = still in service!
I have never "torqued" an automotive drain plug in my life.
I know when to stop - most jiffy shops stops when it's about 3% away from stripping the threads out!
Re: Old washer change torque? [Re: pda1122] #4723445
04/11/18 09:39 AM
04/11/18 09:39 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
Flip the washer around... or if its copper, heat it (dull red glow) and let it cool slowly. I always replace them (have a huge assortment), but for the odd size I don't have and in a pinch... I'll try and reuse.
Re: Old washer change torque? [Re: Leo99] #4724280
04/12/18 03:22 AM
04/12/18 03:22 AM
California
Loopie Offline
Loopie  Offline
California
I just keep on reusing them and no torque wrench needed.
09 Hyundai Sonata 140K - Fram Ultra with 5W30 Mobil HM synth
07 Mazda5 165K- Fram Ultra with 5W30 Mobil EP
Re: Old washer change torque? [Re: pda1122] #4724290
04/12/18 04:14 AM
04/12/18 04:14 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Just snug it up, no rocket science here.
The "thinking" man's friend.
