Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
131 registered members (4WD, 69Torino, 2009Edge, 209paulc, advocate, 9 invisible), 1,647 guests, and 48 spiders.
Topics296,751
Posts4,958,222
Members66,964
Most Online2,577
Jan 14th, 2019
2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil #4722623
04/10/18 09:59 AM
04/10/18 09:59 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
2011 Ram 5.7 Hemi, towing 6,000lbs most of the time, I sampled half way through the interval, but the filter was never changed
trucks currently at 297,443km went 30,000km on this oil change its the longest we have gone so far
Truck was running Amsoil 5w20 Signature Series, and A EaO 11 fiter for 30,000km
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722652
04/10/18 10:32 AM
04/10/18 10:32 AM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Not too bad for the usage. The TBN is fantastic for the time/distance; how much make-up oil was added (if any)?
Anything you can do for the silicon? Looks like it runs a bit high in each sample. I would assume it's another oil patch truck and maybe lots of dust in the air, and you most likely keep watch of air intake; but maybe there's another air filter to try?
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722676
04/10/18 11:00 AM
04/10/18 11:00 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Silicon seems like its always high for some reason, but If you look at the sample I took half way through the silicon doesn't climb much so maybe its a additive in the oil?
currently using a Napa Gold air filter I am going to try OEM for the next OCI
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722683
04/10/18 11:03 AM
04/10/18 11:03 AM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
and 3 or 4 liters were prob used for top ups
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722701
04/10/18 11:19 AM
04/10/18 11:19 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
Oxidation and Sulfation is high and thickened a bit. I'd get an oil and stick to 10,000 miles max.
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + M1-110 oil filter)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722795
04/10/18 01:04 PM
04/10/18 01:04 PM
Finland
Bjornviken Offline
Bjornviken  Offline
Finland
Why not 5w-30 ? you got high iron
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4722898
04/10/18 03:36 PM
04/10/18 03:36 PM
WA
John_Dude Offline
John_Dude  Offline
WA
TBN is great. Since you are towing, you definitely need to switch to a 5w30, since iron is high.
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: deven] #4723151
04/10/18 08:37 PM
04/10/18 08:37 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
This oil has high Sulfation and Oxidation numbers out of the jug. You'd get an oil? confused
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: John_Dude] #4723155
04/10/18 08:39 PM
04/10/18 08:39 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
Yeah I think I will be switching to a 5w30 diesel oil down the road to test out.
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4723223
04/10/18 09:47 PM
04/10/18 09:47 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
5W20 inadequate for towing ?
Yep, xW30/40 could be more appropriate here.
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4723229
04/10/18 09:54 PM
04/10/18 09:54 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
A similar run with Amsoil SS 5w30 would be a worthy comparison
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4723400
04/11/18 07:42 AM
04/11/18 07:42 AM
Massachusetts
deven Offline
deven  Offline
Massachusetts
k
You have a VOA with sulfation and oxidation that says it has high values for both? Anything over 50 is considered too high according to a former member here who translates UOA for a living. Choose a particular oil but IMO would not go over 10,000 miles.
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4723929
04/11/18 04:56 PM
04/11/18 04:56 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Yeah the second half of the latest oci shows an enormous improvement in silicon (PPM/hour in use). Any chance the filter has been in awhile and is now much more efficient? If that air filter has some life left in it (allowing continued use) you may see much lower silicon and iron in future reports.
Regardless of the grade of oil used, if you could lessen the sand paper effect of the silicon, the results should look much better. Maybe some sort of pre-filter could be put in? (Like a piece of foam air filter stuffed in under the standard paper). Don't know if that could be done, but it could be helpful if so.
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: deven] #4724951
04/12/18 04:43 PM
04/12/18 04:43 PM
Northern Alberta
DustinC Offline OP
DustinC  Offline OP
Northern Alberta
k
Yes the VOA was over 50, its just this signature series oil that seems to read like that, the lab says its nothing to worry about, wear treads are no better or worse the longer the oil is ran so I see no benefit in doing 10k oci
Re: 2011 Ram 1500 5.7 297,443km 30,000km OCI Amsoil [Re: DustinC] #4725026
04/12/18 06:15 PM
04/12/18 06:15 PM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
Oxidation in the VOA is mostly from the ester content. The towing and viscosity increase shows tell me that the oil experienced a lot of heat. Do you have an oil temp. gauge?
