Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
115 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 11 invisible), 2,033 guests, and 182 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
Trying Shell V-Power #4719424
04/07/18 12:10 PM
04/07/18 12:10 PM
Ontario, Canada
bumpasmerc Offline OP
Ontario, Canada
I started scanning the 200+ posts on this fuel and additives topic looking for some answers to my questions but gave up. So at the risk of opening up a well beaten subject here goes:
I will be running Shell V-Power in my 95 Mercury 4.6 2V for the next while. The questions I hope to answer are:
1. Will gas mileage improve (even slightly) because the car's engine control computer will make adjustments for the higher octane 91 (was running 87) ? The thinking here is that more volatility equals less volume of fuel required. Does the computer have this capability or does it just adjust only when it gets a knock signal ?
2. My go to gas was Pioneer which is not on the "Top Tier" list whereas Shell is. Shell and all Top Tier fuels, have more detergents which should help clean injectors, intake valves, comb. chambers, spark plugs, etc. Should I expect easier starts, smoother idle, better acceleration and the like ?
3. Probably the most compelling reason to try a 91 octane fuel is to eliminate ethanol use for my (older) car in particular. Much has been written on the pros and cons of ethanol and I am in the cons camp, mostly because of it's negative effects on fuel systems and engines. This is not really a question that can be readily answered by trial and observation. However, my research indicates that ethanol was introduced as a fuel supplement around 95/96. So my 95 car was not designed to use it. I don't know what design changes were made for E85 cars, so I don't know if ethanol is doing harm to my non-E85 vehicle. I guess that is kind of a question.
95 Mercury Grand Marquis 4.6 SOHC, 134k, M1 5w30 , Fram Ultra.
Re: Trying Shell V-Power [Re: bumpasmerc] #4719430
04/07/18 12:18 PM
04/07/18 12:18 PM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
Try it out. My old Explorer showed no benefit for my buying 93 as opposed to 87 at Costco. But my 2016 Edge 2.0 comes alive on 93 octane. Some vehicles seem to benefit while others don't.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Trying Shell V-Power [Re: bumpasmerc] #4719447
04/07/18 12:38 PM
04/07/18 12:38 PM
CA
raytseng Offline
raytseng  Offline
CA
I would say yes but for none of the reasons you state.
I believe shell has a ucl in their additive which will give you the differences indicated but mainly the smoothness is noticeable .
One of my cars is sensitive and I can tell the differences in fuels. where shell is slightly smoother than others.
I notice the similar smoothness when using a maintenance dose of si1 for a tank or even the second diluted tank so it is not something special to shell, its just ucl.
Ultimately be a scientist and just try it for a few tanks. Write down your hypothesis and how you intend to evaluate.
As far as fuel economy, it may technically also improve but at such a small value that it won't be measurable. like 1% or less (assuming only vpower change not ethanol %)
Re: Trying Shell V-Power [Re: bumpasmerc] #4719450
04/07/18 12:40 PM
04/07/18 12:40 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I use it in my Briggs Sears mower, STIHL chainsaw and my Shindaiwa string trimmer. Works great and I have no start issues with it.
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Trying Shell V-Power [Re: bumpasmerc] #4719459
04/07/18 12:49 PM
04/07/18 12:49 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
If your 91 is ethanol free, you'll see better mpg due to the pure gas. I highly doubt the computer in your '95 4.6 will advance timing to take advantage of the higher octane fuel though.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: Trying Shell V-Power [Re: bumpasmerc] #4719465
04/07/18 12:58 PM
04/07/18 12:58 PM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Been using V-power 98 nitro for 3 years. And its works good smile BTW do you have any higher than 91 octane in US?
Re: Trying Shell V-Power [Re: Bjornviken] #4719481
04/07/18 01:26 PM
04/07/18 01:26 PM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
European octane ratings are calculated slightly differently. Yielding a higher number. I can get 93 here or Sunoco 100 racing gas.
2016 Ford Edge 2.0
2006 Explorer SOLD
Re: Trying Shell V-Power [Re: bumpasmerc] #4719504
04/07/18 01:44 PM
04/07/18 01:44 PM
Nashville, TN via Memphis
john_pifer Offline
john_pifer  Offline
You’re not going to notice a difference.
16 WRX - PPPP
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 208K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Trying Shell V-Power [Re: Bjornviken] #4719526
04/07/18 01:59 PM
04/07/18 01:59 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
Euro 98 (RON) is equivalent to 93 here (RON + MON/2).
Re: Trying Shell V-Power [Re: umungus1122] #4719634
04/07/18 03:47 PM
04/07/18 03:47 PM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Yes it is =), so you get 93 V-Power then in US?
Re: Trying Shell V-Power [Re: umungus1122] #4719642
04/07/18 03:52 PM
04/07/18 03:52 PM
Ontario, Canada
Ontario, Canada
Thanks for the responses. We can get 93 octane here from Petro Canada for one, possibly others.
Re: Trying Shell V-Power [Re: Bjornviken] #4719654
04/07/18 04:08 PM
04/07/18 04:08 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
Yes, the Eastern US usually has 93 for high test. Out West they usually have 91 or 92 as standard high test.
Re: Trying Shell V-Power [Re: bumpasmerc] #4719677
04/07/18 04:38 PM
04/07/18 04:38 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Originally Posted By: bumpasmerc
my research indicates that ethanol was introduced as a fuel supplement around '95/'96.
Maybe where you are!
10% ethanol blended gasoline has been available in Iowa/Nebraska since the late 1970's.
No..... I often add 5-7 gallons of E-85 to my 1996 Mustang GT 4.6 to stop pinging.
It runs the same... just gets much worse MPG when I do.
EXACTLY!!!
Re: Trying Shell V-Power [Re: bumpasmerc] #4719735
04/07/18 05:26 PM
04/07/18 05:26 PM
Ohio
Dorian Offline
Dorian  Offline
Ohio
The 99 Camry had worse fuel economy. About 2 mpg less. I only did it to lock myself into Shell's Gold fuel reward status. I want to see if the 14 would have any increase with the 10.4:1 compression and Dual VVT.
15 Camry Hybrid SE 48K 0W20 Kendall bulk
14.5 Camry SE 2AR 0W20 M1 AFE 44K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 148K (Brother's)
Re: Trying Shell V-Power [Re: bumpasmerc] #4719938
04/07/18 08:30 PM
04/07/18 08:30 PM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
I tried both 87 and 93 and didn't notice any difference in power or economy only thing i really noticed is weight reduction of my wallet. Shell gas in my state is lack luster anyway and can contain up to 20% ethanol on the regular pump.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
