Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
114 registered members (AITG, A310, addyguy, 69GTX, 2009Edge, 10 invisible), 2,148 guests, and 51 spiders.
Topics296,735
Posts4,957,909
Members66,960
Most Online2,577
Jan 14th, 2019
'93 E36 BMW - Differential Carrier Bearing #4716632
04/04/18 08:32 PM
04/04/18 08:32 PM
Australia
B320i Offline OP
B320i  Offline OP
Australia
Perhaps only two weeks ago, I started noting a 'melodic' sort of whine at speeds from around 60km/h (37mph). I took the vehicle to a mechanic I trust (who I know through a friend) and the verdict, after some investigation, was a carrier bearing in the differential. He suggested I drive it till it sounds properly knackered before getting it rebuilt, as the cost would amount to AU$1000.
For the past 50,000km (31,000 miles) of ownership, I've always noticed a slight whine at highway speeds if you back off the accelerator slightly. The differential fluid was replaced with a good synthetic product of the correct grade/spec for my 320i 2yrs & 25,000km ago. Fluid that was drained did not smell bad, was of a good colour and didn't seem to be full of metal.
I've never heard much talk of differentials in BMWs of this era going bad. So for now, I'm just investigating my options... Would it be better just to source a good, secondhand, low miles unit from a junked vehicle, or would the rebuild be the better option (peace of mind of no failure and that sort of thing)?
'93 BMW 320i 217,000km - Valvoline Engine-Armour 15w40, Mann Filter.
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4716642
04/04/18 08:38 PM
04/04/18 08:38 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I would trust a factory assembled low mileage used unit if you can get it for a car that old. Rebuilt is cool, but there are so many things that can go wrong.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4716803
04/05/18 03:13 AM
04/05/18 03:13 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Go used. It'll be a fraction of the cost and may be better than a rebuilt unit.
That whine you've been hearing is fairly common in an older differential - but you may have started to hear it because you need a new mount.
"Zed's dead baby, Zed's dead."
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4716850
04/05/18 05:37 AM
04/05/18 05:37 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
What's viscosity grade in use?
... what grade is called for in the manual ?
I prefer a rebuilt by a reputable guy including oneself.
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4717007
04/05/18 08:07 AM
04/05/18 08:07 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Go to mye28.com and ask the Aussies where to get a good one.
Thick oil is better grin2
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4717095
04/05/18 09:40 AM
04/05/18 09:40 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Its a fairly easy diff to set up once its got all its new parts but there are a few special tools needed. I have the BMW set somewhere but haven't done one in many years.
Look for a shop that race preps these, they can do it no problem.
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4719869
04/07/18 06:35 PM
04/07/18 06:35 PM
Australia
B320i Offline OP
B320i  Offline OP
Australia
The manual specifies "Your BMW Service Station is familiar with the grades used for servicing." Research I did at the time indicated it was SAF-XO, which is equivalent to 75w-90, and is thus what I used. Cars with an LSD would use SAF-XJ, 75w140. None of the information I have on my car indicates an LSD is fitted, so 75w90 it was.
Re: '93 E36 BMW - Differential Carrier Bearing [Re: B320i] #4720162
04/08/18 03:45 AM
04/08/18 03:45 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Sorry, not trying to burst your air for your choice of 75W90 which is of inadequate viscosity grades, corelates with the whining gear noise phenomenon you encounter presently , IMO.
A 1993 SAE xW90 gear oil were equivalent to today's ISO 150/220 and ISO 320 gear oils with a [email protected]*C ranging from 135 cSt to 320 cSt.
However, a current 75W90 typically of [email protected]*C 100 cSt or thereabout is thinner at ISO 100 gear oil grades ......
and it doesn't meet OEM requirements then, not saying one can't use 75W90 if you so desire.
A modern day 75W140 of typically [email protected]*C 170 cSt would be a safer bet in your E36 differentials.
75W140 @ 4.22
No, don't .
Dump the 75W90 soonest, and replace it with a 75W140 or any ISO 220/320 GL5 gear oils for mitigating whining gear noise turning around the bad situation you're in today.
It's cost is negligible.Just my 2cents
Re: '93 E36 BMW - Differential Carrier Bearing [Re: zeng] #4720359
04/08/18 08:47 AM
04/08/18 08:47 AM
Australia
B320i Offline OP
B320i  Offline OP
Australia
I have to respectfully disagree (although I appreciate the discussion, don't get me wrong), based on the evidence discussed below, as well as anecdotes from fellow owners. If 75w90 oils were such an issue for these non-LSD examples, it would be widely discussed among E36 owners and enthusiasts, particularly among those who've run their E36s to higher mileages.
A Castrol datasheet I've found just now on the SAF-XO and XJ products doesn't seem to stand with your claims; if this is the factory fluid, or what was used predominantly for a period, how is it the viscosity fits in with the 'modern' figures you quote as being entirely unsuitable?
I searched BITOG, and returned with a link to Castrol (in 2012) stating replacements for the SAF products; note the specific mention against 75w90 of "BMW Approved for used in conventional differentials."
The only evidence I have on 75w140 being recommended was for the LSD-equipped vehicles.
As an aside, the datasheet for the 75w90 indicates a KV40 of 116, and KV100 of 16.1; slightly thicker than the Castrol SAF-XO.
