Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
103 registered members (2015_PSD, Anduril, Astro14, Avelectro, b1amgm47, ABCarr, 13 invisible), 2,193 guests, and 28 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
Help! Water leak under slab #4715958
04/04/18 09:31 AM
04/04/18 09:31 AM
Jupiter, Florida
Cujet Offline OP
Cujet  Offline OP
Jupiter, Florida
FL acreage property, concrete block home with a monolithic slab. Pipes under slab.
Yesterday, walking barefoot I notice a hot section of tile floor. Sure enough, its where I remember the water pipes being. Turn off the water heater inlet overnight and the floor cools. Turn on the water heater inlet and a rush of water is heard. Rinse-repeat. Yup, I've got a substantial leak.
The hot-spot is about 13-14 feet in from the wall. I suppose one could tunnel underneath in wintertime, when the water table is low. As my house is on a bit of a mound.
I'd really hate to break up the tile floor and destroy the slab. As of right now, I don't have any known or major slab cracks, or any water in the home.
Of course, the hot spot may not be where the leak is. As some of the pipes have insulation.
Suggestions? I have zero idea how to deal with this, other than to tunnel under and solder in a new section.
Installing new plumbing in the attic is prob exceptionally difficult.
Re: Help! Water leak under slab [Re: Cujet] #4715968
04/04/18 09:37 AM
04/04/18 09:37 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Copper pipes? I don't know if they make pipe cameras that work with that size of pipe, but if they do having a look to see where the problem is would be a good start.
Also for hot water, pex in the attic might be surprisingly easy to install even down into the walls. You'll get instant hot water in the summer too!
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Help! Water leak under slab [Re: Cujet] #4715973
04/04/18 09:40 AM
04/04/18 09:40 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'm sure they have scope cameras that can find the leak. Just saw an ad for one yesterday. They can even sometimes repair the leak without breaking everything up.
http://www.leakdoctor.com/blog/How-to-Detect-a-Plumbing-or-Slab-Leak-in-Central-Florida-_AE21.html
Re: Help! Water leak under slab [Re: Cujet] #4715983
04/04/18 09:49 AM
04/04/18 09:49 AM
socal
barkingspider Offline
socal
If you do not want to break the slab to fix the leak, your only other option is to re route the pipe. This will save your floors but u will have holes in the drywall to patch and paint. Re route is a better option as u now have new pipe vs new patched old
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Help! Water leak under slab [Re: Cujet] #4716004
04/04/18 10:11 AM
04/04/18 10:11 AM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
My mother's house had that problem twice with cold-water pipes. Solved once by rerouting around the outside of the house, underground. The second time by slipping a special plastic pipe inside the copper pipe for the whole distance---a more elegant and less expensive solution. Some plumbers in your area should know how to do that if the problem is not rare there.
2011 Toyota Prius now at 97K
Re: Help! Water leak under slab [Re: barkingspider] #4716098
04/04/18 11:34 AM
04/04/18 11:34 AM
Connecticut, USA
bmwpowere36m3 Offline
Connecticut, USA
I would agree...
Depends on what's currently buried and its age. It might be possible to use a thermal camera to pinpoint the leak. The risk, not knowing why the pipe burst, is after the fix other leaks may sprout.
I think abandoning and rerouting is likely the better option.
Re: Help! Water leak under slab [Re: Cujet] #4716111
04/04/18 11:51 AM
04/04/18 11:51 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
My mother in laws house was built in 1980 in Florida. She had the same problem. They re-plumbed the entire house through the attic. You could dig up the concrete but that would be substantially more money. Get a few quotes from plumbers, they will likely qoute the same thing..
Plumbing through the attic can be annoying because your water is HOT coming through the pipes for the first minute, even the cold water. The cold water for the first minute, will be 110 degrees or so, until it flushes out all the water and cools down to normal ground water temp, 72ish.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Help! Water leak under slab [Re: Cujet] #4716121
04/04/18 12:02 PM
04/04/18 12:02 PM
Jupiter, Florida
Cujet Offline OP
Cujet  Offline OP
Jupiter, Florida
Thanks guys,
Yes, copper pipe. House is 15 years old. 3300 square feet total, including the 3 car garage, 2400 under air.
Re: Help! Water leak under slab [Re: Cujet] #4716128
04/04/18 12:11 PM
04/04/18 12:11 PM
New England
madRiver Online content
madRiver  Online Content
New England
You have to way out rerouting the section of piping inside the home somehow like walls or attic. What are the walls made of?
Re: Help! Water leak under slab [Re: bubbatime] #4716135
04/04/18 12:20 PM
04/04/18 12:20 PM
Chicago,IL,USA
pandus13 Offline
pandus13  Offline
Chicago,IL,USA
Here in the cold, they sometimes use re-circulation pumps to keep the water warm for a long run.
Would that be feasible for OP for cold water circuit?
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Help! Water leak under slab [Re: pandus13] #4716143
04/04/18 12:28 PM
04/04/18 12:28 PM
New England
New England
Funny thing. Growing up in Kuwait before they had a water distribution system they delivered water via truck to house and pumped to tanks on roof. In winter we used the hot water tank inside house. In summer we reversed and the tanks on roof were the hot water(solar) and the inside water heaters shut off were cold water.
Re: Help! Water leak under slab [Re: madRiver] #4716166
04/04/18 12:39 PM
04/04/18 12:39 PM
Jupiter, Florida
Cujet Offline OP
Cujet  Offline OP
Jupiter, Florida
The home is concrete block, bathroom walls are tile. The drywall has very little room underneath. As the wood mounting strips are only about 1/2 inch. And that is where the wires are.
The plumbing comes up from under the slab. Does not go behind the wall
Re: Help! Water leak under slab [Re: Cujet] #4716170
04/04/18 12:41 PM
04/04/18 12:41 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
My great-aunt has this happen to her house. Home-owners insurance paid for it.
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Help! Water leak under slab [Re: Cujet] #4716178
04/04/18 12:47 PM
04/04/18 12:47 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
How about renting a thermal camera to detect where the leak is underneath and the location of the pipe? As for a solution, it's difficult to add anything without being on site. Do you have any photographs of your foundation before concrete was poured?
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
Re: Help! Water leak under slab [Re: Cujet] #4716214
04/04/18 01:25 PM
04/04/18 01:25 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
With lime erosion being a serious problem in FLA don't hesitate to fix that. I had this problem in my last house. Rent a concrete saw or pay someone to cut out the section of concrete. Replace the bad pipe. throw in stone base. pour a patch.
06 Escalade 6.0L LQ9 AWD 167k M1 0w40
03 Maxima 3.5L POS 170k ST HM 10w30
05 Malibu Classic 109k Unk
