Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
31 registered members (billt460, Bailes1992, Brad_C, bbhero, 5 invisible), 520 guests, and 59 spiders.
Topics286,442
Posts4,908,265
Members67,622
Most Online2,967
Mar 10th, 2019
What filter for a 48re #4715644
04/03/18 10:55 PM
04/03/18 10:55 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
What do you guys recommend? It's in a 2004 dodge ram 5.9l cummins.
Thanks
Re: What filter for a 48re [Re: monster1] #4715791
04/04/18 07:09 AM
04/04/18 07:09 AM
ca
monster1 Offline OP
monster1  Offline OP
ca
Also, I'm thinking of adding a remote filter to the transmission to keep the fluid extra clean as from what I'm understanding the filter in the pan doesn't filter down like an oil filter. The truck has 75k on the odometer. I've only changed the transmission fluid once at 50k. I'm getting ready to do it again as the fluid is dirty. Am I overthinking this with wanting to add a remote filter kit? I only drive the truck about 7500 miles a year while towing a 5000 pound boat. I also have oversized 35 inch tires on it so it constantly sees a load from the tires. But I dont drive like a bat out of [censored] tearing up the truck. Better fluid change intervals or install a remote filter?
Thanks as always
Re: What filter for a 48re [Re: monster1] #4717781
04/05/18 10:33 PM
04/05/18 10:33 PM
ca
monster1 Offline OP
monster1  Offline OP
ca
Ended up going with an OEM Mopar filter.
Re: What filter for a 48re [Re: monster1] #4735781
04/23/18 12:11 AM
04/23/18 12:11 AM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
You did fine with the OEM filter.
Regarding the remote filter, you'll get responses all over the map. I will say that if you're going to do it, you should consider a bypass filter teed into the output line to the cooler, instead of a full flow filter (where all fluid in the line is forced to go through the filter). Any add-on full flow filter has the potential to reduce flow, and that's a very bad thing. A bypass type filter installed by teeing into the output line has no potential to reduce flow at all.
That said, a cooler is probably more important than another filter. Unless you live in an arctic environment, it's almost not possible to cool transmission fluid too much. Do you have a transmission fluid temp gauge? If not, install one--it'll be an eye opener.
