Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
72 registered members (Anduril, badduxx, bmwpowere36m3, ARCOgraphite, biodiesel, bbslider001, 8 invisible), 1,775 guests, and 55 spiders.
Topics296,775
Posts4,958,671
Members66,969
Most Online2,577
Jan 14th, 2019
Snapper Garden Tractor won't start #4712599
03/31/18 05:15 PM
03/31/18 05:15 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
my Snapper GT300 with 24HP Briggs won't start. Shut it off last fall under deck covered with a tarp to minimize water and snow. Shop i bought it from stores them outside. Battery went dead but took a charge and holding it fine. I hear 1 click when i turn key. Starter does not spin. I am thinking it should be something simple and hoping someone here has suggestions. Less than 270 hours on motor. Ran great when I shut it off. Expect it will run great once I get it going.
Thanks
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712610
03/31/18 05:31 PM
03/31/18 05:31 PM
Georgia
MParr Online content
MParr  Online Content
Georgia
Are you sitting in the seat?
Is the machine in neutral and the parking brake engaged?
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Mobil 1 5W30 & NAPA Gold 1348
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712614
03/31/18 05:35 PM
03/31/18 05:35 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Yes I was sitting in the seat and it has parking brake on. Hydrostatic pedals automatically return to neutral. Oh and I should add the mower drive belts or PTO is down for off. All good questions I should have added that detail.
Thanks
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712622
03/31/18 05:46 PM
03/31/18 05:46 PM
Georgia
Georgia
In that case, there are a couple of other things to check. One is the ignition switch and the other is the starter solenoid. Check and see if your wiring is tight and you have a good ground. The seat safety switch is another possibility. If you know how to check things with a multimeter, that will narrow things down.
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712637
03/31/18 06:05 PM
03/31/18 06:05 PM
MA
AandPDan Offline
AandPDan  Offline
MA
The battery is likely bad. Lead acid batteries don't like going dead. It may take a charge but it probably can't supply enough current to turn over the starter.
Can you load test the battery?
Try to jump start the tractor.
Re: Snapper Garden Tractor won't start [Re: AandPDan] #4712652
03/31/18 06:21 PM
03/31/18 06:21 PM
New England
gathermewool Offline
New England
+1
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712689
03/31/18 07:09 PM
03/31/18 07:09 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
If the battery is actually good, you may have a bad battery cable or connection.
All the "safety switches" everywhere are very likely the culprit.
NEVER EVER EVER jump from a running car or truck!
You'll fry the voltage regulator in the lawn tractor!
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712706
03/31/18 07:31 PM
03/31/18 07:31 PM
out there
spasm3 Offline
spasm3  Offline
out there
I have seen the solenoid go bad, but you heard a click. You can test by using a jumper from the hot side of the battery to the starter post, with the switch on. Depending on safeties you might have to be sitting on the seat to keep it running.
Unless you have measured the battery voltage , its suspect. Lead acid batteries won't sit long discharged and still be salvageable
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712939
04/01/18 06:11 AM
04/01/18 06:11 AM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
I tried jump starting it using the battery charger and still nothing but the same click. it is a single click that seems to be coming from the ignition switch. I will try checking the seat safety switch next. To me those seem to be very problematic with many older mowers having them by passed. Mowing on my hill it is really probably quite a good thing to have just in case of run away mower.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper Garden Tractor won't start [Re: spk2000] #4712943
04/01/18 06:15 AM
04/01/18 06:15 AM
out there
spasm3 Offline
spasm3  Offline
out there
How do you know the battery is good? Unless you have a charger made for starting, you should not try that. You at least need to check the resting voltage of the battery. If the battery is ok, try bypassing the starter solenoid.
Re: Snapper Garden Tractor won't start [Re: spk2000] #4713050
04/01/18 07:34 AM
04/01/18 07:34 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
The click is more than likely the relay kicking in. This should be passing high current to the starter. So I would say the problem is not any switches but either the starter or wiring between the relay or wiring from battery to relay.
I could be the battery is so bad that once the relay kicks in the voltage drops to below what it takes to spin the motor. Taking a voltage reading while holding the key in start would tell the tale.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Snapper Garden Tractor won't start [Re: spk2000] #4713453
04/01/18 04:57 PM
04/01/18 04:57 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Ok Thanks.
I will try and it is a smart charger and does have a start function on it. Problem is still not even attempting to turn over. It does have a battery test function that I have not tried yet.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper Garden Tractor won't start [Re: spk2000] #4713457
04/01/18 05:04 PM
04/01/18 05:04 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
I wish I had a dollar for every time I give out this advice, but....
Get yourself a $5 test light and see exactly how far your electricity is getting.
Re: Snapper Garden Tractor won't start [Re: spk2000] #4713476
04/01/18 05:26 PM
04/01/18 05:26 PM
Prospect, KY
spk2000 Offline OP
spk2000  Offline OP
Prospect, KY
Got one of those and didn't think of that. Great idea and why I ask on here to help me analyze the potential problem
Thanks Everyone
smile
96 Grand Marquis
01 Sable LS
02 Montero
Re: Snapper Garden Tractor won't start [Re: spk2000] #4713504
04/01/18 06:09 PM
04/01/18 06:09 PM
out there
spasm3 Offline
spasm3  Offline
out there
Still one of the quickest tests is to bypass the solenoid by jumping directly to the starter post. Mower out of gear, key on and see if it turns over/starts.
