4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
81 registered members (4WD, 2010Civic, Agnosto, AlaskaMike, AdditiveOCD, 9 invisible), 1,496 guests, and 68 spiders.
Topics286,042
Posts4,901,388
Members67,551
Most Online2,967
Mar 10th, 2019
Hyundai GDI engine failure safety recall #4710501
03/29/18 11:38 AM
03/29/18 11:38 AM
Ontario Canada
caprice_2nv Offline OP
Ontario Canada
I searched and found nothing on here about this. My girlfriend's car is a 2013 Hyundai Sonata with the 2.4L and about 55k miles on it. I have only been with her about 4 months. After I saw the recall for failing rod bearings I checked her oil. It looked black as tar at 2k miles. She got it changed for free as part of the recall, they use a microphone to listen for rod bearing noise through the dipstick. I checked the oil a few days after the oil change and it's black again. Anyone here have any experience with the recall or these engines?
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710509
03/29/18 11:51 AM
03/29/18 11:51 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
It probably wasn’t serviced very often before, and it’s now cleaning it up with recent oil changes.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710524
03/29/18 12:21 PM
03/29/18 12:21 PM
NE Ohio
knerml Offline
knerml  Offline
NE Ohio
Hyundai/Kia had manufacturing problems with 4 cylinder GDI engines made in USA, I think from 2011 thru 2013. Some component was not properly flushed after machining, leaving metal shavings. Caused long term bearing failures. Includes Sonatas.
Hyundai/Kai has been replacing failed engines for free. Failure seems to occur at higher mileages.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Castrol Edge 5W40 & OEM/Mann W811/80 Filter
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710538
03/29/18 12:41 PM
03/29/18 12:41 PM
Ontario Canada
Ontario Canada
Average mileage at failure according to carcomplaints.com which appears to be based on complaints to the NHTSA is 73k miles. There have been 2 in the shop I work part time at. One had over 60k and the other one about 30k when the engine failed.
I don't believe that hers is "cleaning up". She's had the car for a few years so she put most of the mileage on. She's changed it every 3k miles but it's all short trips and she didn't know that time had any effect on service intervals. These cars do dirty the oil fast compared to others even at shorter intervals. She usually drives like 5 miles each way to both of her jobs. Last oil change was 2k and like 5 months. This would be basically what it's had for the past few years. Now it will be getting OCIs every 3 months after seeing the black, thick looking oil on the stick.
I'm just hoping Hyundai doesn't get away with some kind of mileage limit on the engine coverage. It is an actual safety recall which normally means no time or mileage limit. The original recall was just on 2011 but they were forced to expand it to 2013 when the failures kept happening and a Hyundai engineer blew the whistle on them that they knew about the problem. Hyundai tried to cover this all up originally.
79 Honda CX500
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710547
03/29/18 12:50 PM
03/29/18 12:50 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
I know usually oil appearance/smell isn't a great indicator. But on the Veloster turbo (1.6T GDI) car I maintain, at 4k miles its some funky oil coming out. Synthetic changes ever 4k, and the car isn't run hard. Hyundai must know they're hard on oil, the severe service interval is 3750 miles.
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710551
03/29/18 12:53 PM
03/29/18 12:53 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Is it really a safety recall? I so then Hyundai would need to automatically replace all the engines within certain Vin numbers. However; if it was a safety notification then any engines within a Vin group number would be eligible for replacement IF it was determined to be defective. A big difference in terminology. Ed
CX5 Touring 2.5L :-)
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710574
03/29/18 01:17 PM
03/29/18 01:17 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
2013 Sonata recall
Links to recall are notice are there.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710588
03/29/18 01:35 PM
03/29/18 01:35 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Subaru had a similar problem almost decade ago with Turbo EJ engines. Improperly cleaned crank oil drills.
% miles to work is short and an engine killer. 3K 3 mo max.
I recommend you try Valvoline 0w20 "syn" if the Hyundai spec 5w20 or 0W20; it worked best on my problematic subarus. (best as far as non specialty oils yo can by at Walmart, etc.) Ha d tried PP, M1, M1EP, QSUD, Idemitsu-Subaru)
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710729
03/29/18 05:01 PM
03/29/18 05:01 PM
Ontario Canada
Ontario Canada
I'm not doing any of the maintenance on it anyways because I want the oil changes on record if the engine does fail and I don't want to be blamed it it fails. Lol. I am recommending she just keeps getting conventional oil changes but every 3 months now. I might even tell her to keep going to the dealer for a bit. She was going to the local Midas which has a terrible reputation for ripping people off.
I really don't have any confidence that the engine is going to hold up long term. Luckily she's fine with me driving everywhere we go together and put all the miles on my best up 83 Caprice.
I'm going to read more of the many threads over on Hyundai forums. I might find some good info there to do with details about the recall. I've never seen a safety recall to do with an engine failing before, but all recalls I know about go for the life of the vehicle. I'd like to confirm if that's still true in this case.
79 Honda CX500
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710730
03/29/18 05:01 PM
03/29/18 05:01 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Use 5w40 or 0w40 oils.. And severe service interval...
My 50(EU) cents smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710732
03/29/18 05:07 PM
03/29/18 05:07 PM
Ontario Canada
Ontario Canada
My other thought is that the actual "recall" could just be the test to determine whether the engine is failing or not. Then Hyundai could decide whether or not to repair it based on age, mileage, maintenance history, etc. I'm hoping that's not the case.
79 Honda CX500
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710733
03/29/18 05:09 PM
03/29/18 05:09 PM
Ohio
2oldtommy Offline
2oldtommy  Offline
Ohio
Have you done an oil analysis? Anything that would show up such as lead would be an indicator to watch. FWIW
Oldtommy
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710735
03/29/18 05:12 PM
03/29/18 05:12 PM
PimTac Offline
PimTac  Offline
I thought Hyundai Kia extended the engine warranty period for the engines that may be affected?
Cannot see signatures any longer so it doesn’t matter.
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710773
03/29/18 06:08 PM
03/29/18 06:08 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
I know three people with 2012 Sonatas or Optimas whose engines seized. All were honored under warranty with a short block replacement. The time/mileage limits of the extended engine warranty to cover this problem MAY depend on whether you're the original vehicle owner or subsequent owner.
Best to check with Hyundai customer service, not with a dealer. See if you can find a copy of the service or recall bulletin. There have been hundreds if not thousands of these cars that have been repaired for this problem.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: Hyundai GDI engine failure safety recall [Re: caprice_2nv] #4710797
03/29/18 06:37 PM
03/29/18 06:37 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Is the new oil truly black,
Or REALLY dark brown?
