Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
37 registered members (alcyon, clinebarger, carlprop, csandste, Ag76, Bailes1992, 1 invisible), 734 guests, and 65 spiders.
Topics286,441
Posts4,908,218
Members67,622
Most Online2,967
Mar 10th, 2019
fuel hose / copper #4705160
03/24/18 11:23 AM
03/24/18 11:23 AM
KS
red7404 Offline OP
red7404  Offline OP
KS
WHY O WHY do some people think that its ok, to use. hose and / or copper can be used for carburetor fuel line?
Re: fuel hose / copper [Re: red7404] #4705202
03/24/18 12:13 PM
03/24/18 12:13 PM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
I've seen rubber hose used when the steel line is buggered. It must be used at some point by design between the frame rail and engine to take up the flexing from engine vibration. Carburators don't have the high pressure fuel lines that fuel injected vehicles have.
Re: fuel hose / copper [Re: red7404] #4705418
03/24/18 03:21 PM
03/24/18 03:21 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have not seen copper used much but NiCopp or SS as a corrosion resistant alternative to steel was common in the rust belt. As Kestas said at some point hose has to to be used, rubber fuel hose has been used OE for over a century.
I guess that's why people think its okay to use.
Re: fuel hose / copper [Re: red7404] #4705897
03/24/18 10:34 PM
03/24/18 10:34 PM
KS
red7404 Offline OP
red7404  Offline OP
KS
hose on my old Mopars was never longer than 6 inches. over the years i ended up thinking that SOMETIMES the factorys do it right. just saying.
Re: fuel hose / copper [Re: red7404] #4713974
04/02/18 09:55 AM
04/02/18 09:55 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Meh, depends on the spec of the hose. The hoses on my 528e s said made in W germany They were changed circa 2000 and still in good shape. 8x13mm FI hose with a rondel on it is a deal at a buck an inch. The spec is rated for probably twice what 2.5 bar it is regulated to. It is a maintenance item and a fairly easy driveway job. A copper line to a carb is a fashion statement.
Thick oil is better grin2
Re: fuel hose / copper [Re: andyd] #4720520
04/08/18 12:29 PM
04/08/18 12:29 PM
Trav Offline
Trav  Offline
Hose made in W Germany would be almost 30 years old today. Anything made pre 1949 and post 1990 are just "Germany".
