Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
89 registered members (53' Stude, andyd, alphadog, 2dogs, 2015_PSD, 11 invisible), 1,927 guests, and 26 spiders.
Topics287,853
Posts4,935,600
Members67,865
Most Online2,967
Mar 10th, 2019
Distributor Cap and Rotor Replacement? #4695562
03/15/18 11:26 AM
03/15/18 11:26 AM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
Does the Distributor Cap and Rotor need to be replaced? My 290k miles car has original distributor cap, rotor and wires and runs strong without any problems. Would I see any benefit changing those items even when my car is running perfectly?
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695568
03/15/18 11:31 AM
03/15/18 11:31 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Doubtful the originals are on this car. Unless you've owned this car since it was purchased new, those items have probably been replaced.
network down, IP packets delivered via UPS -BOFH
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695569
03/15/18 11:32 AM
03/15/18 11:32 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yes they do, like spark plugs they erode causing a wider air gap which requires higher firing voltage. You can have a low misfire count and not even notice it until it increases to a full blown miss, the wider air gap also places additional stress on the coil.
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695583
03/15/18 11:42 AM
03/15/18 11:42 AM
US
JLTD Offline
JLTD  Offline
US
Yes; when I had a vehicle with this ignition, I usually changed the plugs, cap and rotor at every 2nd spark plug change - each plug change was 30,000 miles.
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 146k, SS 5w30/Amsoil
His: 2015 4Runner 53k, OE 5w30/Wix
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695588
03/15/18 11:45 AM
03/15/18 11:45 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Yep, good idea to replace them. I replaced mine at 180k and noticed a smoother idle and small MPG increase.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695594
03/15/18 11:51 AM
03/15/18 11:51 AM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
I always replaced the cap and rotor when I replaced spark plugs. Seriously doubt you have the OEM parts. Don't expect a noticeable change if you haven't been experiencing ignition problems.
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695719
03/15/18 01:57 PM
03/15/18 01:57 PM
California
nthach Offline
nthach  Offline
California
It's a good idea to change the cap and rotor every other spark plug change. while the terminals do wear and pit due to unavoidable arcing everytime the rotor contact goes over the cap contact for each cylinder and the center contact wears down(it's a carbon nub that's spring loaded like a motor brush) you also have ionized air that has a good bit of ozone in it. If the cap's plastic weakens and cracks or if there's a carbon track on the inside of the cap, it's an ideal condition for a voltage leak.
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695741
03/15/18 02:25 PM
03/15/18 02:25 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Take the clips off the cap and have a look at each contact and the edge of the rotor. If there are any deposits on the contacts, replace the cap and rotor. I wouldn't bother with the wires unless you feel like updating them or the engine has trouble starting.
If you want the job done right......do it yourself.
Re: Distributor Cap and Rotor Replacement? [Re: javacontour] #4695785
03/15/18 03:18 PM
03/15/18 03:18 PM
Emanuel Offline OP
Emanuel  Offline OP
I'm the original owner
Re: Distributor Cap and Rotor Replacement? [Re: Yah-Tah-Hey] #4695791
03/15/18 03:21 PM
03/15/18 03:21 PM
Emanuel Offline OP
Emanuel  Offline OP
My dad is the original owner, I don't think he has changed those items
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695795
03/15/18 03:23 PM
03/15/18 03:23 PM
Emanuel Offline OP
Emanuel  Offline OP
Now that I'm starting to remember the car did died some years ago for a ignition problem, I think it does have a new rotor
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4695869
03/15/18 04:28 PM
03/15/18 04:28 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
FWIW I always replaced these parts at 60K miles. Never noticed a difference in how it ran, though. I wouldn't go over 100K miles.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Distributor Cap and Rotor Replacement? [Re: Emanuel] #4696006
03/15/18 06:59 PM
03/15/18 06:59 PM
Los Gatos, CA
JeffKeryk Online content
JeffKeryk  Online Content
Los Gatos, CA
Replace them with quality parts. I like OEM.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
