Originally Posted By: Egg_Head
This is from the 2018 Owner's Manual:
I think the 2 hours is for checking the oil.
If a low oil Driver Information Center
(DIC) message displays, check the
oil level. If the oil is not low and the
low oil message remains on, take
the vehicle to your dealer for
service.
Follow these guidelines:
. To get an accurate reading, park
the vehicle on level ground.
Check the engine oil level after
the engine has been off for at
least two hours. Checking the
engine oil level on steep grades
or too soon after engine shutoff
can result in incorrect readings.
Accuracy improves when
checking a cold engine prior to
starting. Remove the dipstick
and check the level.
If unable to wait two hours, the
engine must be off for at least
15 minutes if the engine is
warm, or at least 30 minutes if
the engine is not warm. Pull out
the dipstick, wipe it with a clean
paper towel or cloth, then push it
back in all the way. Remove it
again, keeping the tip down, and
check the level.
My wife's 2017 3.6 Impala owners manual also reads the same. I have waited the 2 hours as recommended but experimenting with this 2 hour recommendation, I have found 3 hours is a lot better as there is zero streaking/smudging on the dipstick after that time.
Our driveway is sloped so after a decent drive, I will park it partially on the road/driveway to get the car level as possible. Tinkering in the garage, etc, I check it after the 3hour window and all has settled which makes it very easy/accurate to read.
With my truck, I check it after work as it has sat at least 8 hrs on a very flat parking lot. Now, if I could just convince my wife to do the same thing at her work.
service.
check the level.
