Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
118 registered members (2015_PSD, 555, 97f150, 69Torino, 2012AccentSE, 64bawagon, 16 invisible), 2,104 guests, and 59 spiders.
Topics286,156
Posts4,903,136
Members67,565
Most Online2,967
Mar 10th, 2019
What weight oil would help this start up noise? #4693761
03/13/18 06:25 PM
03/13/18 06:25 PM
Suburban Washington DC
atikovi Offline OP
atikovi  Offline OP
Have a '93 Ford Ranger 2.3L with nearly 300,000 miles. Doesn't burn much oil but on cold starts I hear a lot of top end noise for 2 or 3 seconds. Right now it has 5W30. Would 10W40 help? Or go the other way with 0Wsomething? Either the thinner oil would flow better and thus reach the top end faster, but on the other hand it would drain off more when you shut down the engine and wouldn't reach the top end fast enough on the next cold start. But the thicker oil might stay longer in the top end after shut down but may be more difficult pump up to the top when cold.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693778
03/13/18 06:35 PM
03/13/18 06:35 PM
CZ factory 🏭 KC KS
Marco620 Offline
Marco620  Offline
CZ factory 🏭 KC KS
Why not just run either PYB 5w30 or Valvoline Maxlife with a bottle of liquimoly mos2 ? Lots of reviews on Amazon say this helps a lot.
15' Civic 1.8 i-vtec 221,000 mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: What weight oil would help this start up noise? [Re: atikovi] #4693806
03/13/18 06:58 PM
03/13/18 06:58 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
In a recent discussion it seemed higher viscosity or density was felt supress noise. Wasn't entirely clear which, but they probably usually go together.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4673788/Low_Noise_Oil#Post4673788
Re: What weight oil would help this start up noise? [Re: Marco620] #4693815
03/13/18 07:06 PM
03/13/18 07:06 PM
atikovi Offline OP
atikovi  Offline OP
I added Kreen 1200 miles ago which helped a good bit to the point now where most times there is no noise but on a few occasions there is. Only happens when cold leading me to believe it's more viscosity related. Time for an OC anyway and have some cheap 10w40 semisyn just taking up space and thought I could get rid of it this way.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693828
03/13/18 07:19 PM
03/13/18 07:19 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
My Ranger went to auction at 253K. It was noisy until I changed to Delo 400 15W-40.
Make sure the filter is known to have a good anti-drain-back-valve like a Wix or Baldwin or something smile
There is no "faster to the top end". It's a positive displacement pump. If it's fluid, it all gets there pretty equally time-wise ...
I know from any years of experimenting that some synthetics have lower surface tension (in part, that's how they get to 0W) and they do drain off faster. They also leave a thinner film (capillary fill) for the same reason. Quality Dino's are usually better at capillary fill, hence quieter on cold start.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693832
03/13/18 07:27 PM
03/13/18 07:27 PM
BrocLuno Offline
BrocLuno  Offline
Experiment a bit and see which is quieter smile
Re: What weight oil would help this start up noise? [Re: atikovi] #4693857
03/13/18 07:47 PM
03/13/18 07:47 PM
USA
slacktide_bitog Offline
USA
Try T6 5w40 smile
Re: What weight oil would help this start up noise? [Re: BrocLuno] #4693870
03/13/18 07:53 PM
03/13/18 07:53 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Exactly. I would vote to try a 10-30 first and run it this summer.
If you want the job done right......do it yourself.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693890
03/13/18 08:03 PM
03/13/18 08:03 PM
Snagglefoot Offline
Snagglefoot  Offline
Truth be known, your engine is worn but you made it to 300,000 km. What is your end game? How are the other issues such as rust etc. At this point you dont have much to lose. You might even want to run a 15-40.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693898
03/13/18 08:09 PM
03/13/18 08:09 PM
Snagglefoot Offline
Snagglefoot  Offline
Like this one. Its SM rated.
Re: What weight oil would help this start up noise? [Re: atikovi] #4693905
03/13/18 08:14 PM
03/13/18 08:14 PM
atikovi Offline OP
atikovi  Offline OP
Hmm, I do have 5 leftover quarts of Lubrigard 15W40 SM laying around. So that would be a better shot than 10W40?
Re: What weight oil would help this start up noise? [Re: atikovi] #4693923
03/13/18 08:28 PM
03/13/18 08:28 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
What brand oil filter are you using?
Re: What weight oil would help this start up noise? [Re: atikovi] #4693927
03/13/18 08:32 PM
03/13/18 08:32 PM
atikovi Offline OP
atikovi  Offline OP
Motorcraft
Re: What weight oil would help this start up noise? [Re: atikovi] #4693948
03/13/18 08:53 PM
03/13/18 08:53 PM
HondaBroMike Offline
I got a slight grind on warm re-stats but it's not consistent enough to even qualify as an issue, imo. But it's mechanical and not oil related.
Re: What weight oil would help this start up noise? [Re: atikovi] #4694047
03/13/18 10:10 PM
03/13/18 10:10 PM
California
vavavroom Offline
vavavroom  Offline
California
Why is there no oil at or near the engine top end before starting up? Doesn't this engine have oil retention valves in the head?
Do engine components that get oiled during operation lose all clinging lubrication within a relatively short period of time?
How long do 10W-40 and 5W-30 respectively take to reach the top of the engine and how long to they take to drain into the sump?
What results in less upper engine wear, oil that reaches the top end more quickly, or thicker oil that leaves a thicker film behind?
