more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
60 registered members (Astro14, AndyB, antik, aircooled, 10 invisible), 1,120 guests, and 52 spiders.
Topics286,271
Posts4,905,682
Members67,589
Most Online2,967
Mar 10th, 2019
Low Noise Oil #4673788
02/21/18 08:55 PM
02/21/18 08:55 PM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Not seen or heard of this "stealth" property being specifically advertised before, though it might have been. Niche market for private detectives, perhaps "As used by Phillip Marlowe"?
Its a 5W50. Is there any property apart from the high temp viscosity that would contribute to noise reduction?
Just curious, not interested in buying it, since its too wide a range and I don't particularly want to reduce my engine noise. I do use CPC stuff, but this is over twice as expensive as the 15W40, the price of silence.
Re: Low Noise Oil [Re: Ducked] #4673792
02/21/18 09:01 PM
02/21/18 09:01 PM
New England
pda1122 Offline
pda1122  Offline
New England
I wouldn’t trust that brand...never heard of it. How long have you been using it?
Edit: sorry didn’t realize your location.
‘19 Grand Caravan- factory fill
'13 Toyota Tundra 5.7-Idemitsu 0w-20/OEM
'08 Hyundai Elantra-Havoline 5w-30/Fram 9688
'96 Ranger R72 90hpJohnson
'03 Ski Doo REV 600 H.O.
‘01 Kawasaki KDX 220r
Re: Low Noise Oil [Re: Ducked] #4673794
02/21/18 09:02 PM
02/21/18 09:02 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I like the "Extra Special Motor Oil" part.
Re: Low Noise Oil [Re: Ducked] #4673807
02/21/18 09:15 PM
02/21/18 09:15 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The "standard low-noise motor oil" in the United States:
grin LOL grin2 crackmeup
Re: Low Noise Oil [Re: das_peikko] #4673832
02/21/18 09:32 PM
02/21/18 09:32 PM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
Re: Low Noise Oil [Re: pda1122] #4673918
02/21/18 11:15 PM
02/21/18 11:15 PM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Understood. I bought the SAE 40 for use in a motorcycle, and ended up using it in the car along with Delvac MX 15W40 after an oil leak.The Delvac is no longer available and CPC seems to be the only SJ oil readily obtainable now.
When that's gone I'll probably use Castrol "Go" 20W40 motorcycle oil, if it (and I, and the car) is/are still around. Made in Thailand.
Re: Low Noise Oil [Re: das_peikko] #4673923
02/21/18 11:21 PM
02/21/18 11:21 PM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Never heard of it? That makes it extra special.
Re: Low Noise Oil [Re: Ducked] #4673924
02/21/18 11:25 PM
02/21/18 11:25 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Well the question is; Does it work to make your car quieter ...
They can claim anything they want. But, does it work?
Re: Low Noise Oil [Re: Ducked] #4673971
02/22/18 12:16 AM
02/22/18 12:16 AM
workbench CZ-USA KS KC
Marco620 Offline
Marco620  Offline
How does Lucas Oil Stabilizer still sell? I only used Hyper-Lube Red Bottle with Jobaba to prime my oil filters long ago. Took 5 oci to use bottle. Big Lots special at 2.00qt, bought 5 qts.
15' Civic 1.8 i-vtec 222,222+ mi 0w20 Redline/Redline CVT/Archoil9100/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/87 E0 fuel/Yokohama
Son of a Navy Corpsman. Support vets!
Re: Low Noise Oil [Re: Ducked] #4674077
02/22/18 08:13 AM
02/22/18 08:13 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Depending on the engine, I can see 5w-50 causing a lot of top end noise .... Particularly in something pushrod with a weak oil pump.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Low Noise Oil [Re: BrocLuno] #4674110
02/22/18 08:58 AM
02/22/18 08:58 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Well, its a question, but not a very interesting one, unless you care about engine noise per se, which I don't.
More interesting questions, IMO, would be:-
(a) HOW would/could it work?
I THINK the Lucas stabiliser stuff is either just thick oil or viscosity improver (can't remember which but probably the latter?) That would suggest any sound reduction is simply a function of viscosity. Can't think of much else. Density? Don't put any anti-foam in so it forms a sound-insulating bubbles? (bad for lubrication though) Sound insulating nano-particles? (finely grround eggboxes/fullerenes). Maybe un-extended VII have some special sound-deadening properties due to (total?) internal reflection/absorbance of sound (maybe not).
If it IS just a viscosity effect you would think the 20W50 at less than half the price would be about as good (OK, the 50 is a range. I don't know the actual viscosities).
(b) Is engine noise a proxy for something more meaningful? Specifically, is it a proxy for wear? If it is (and I think it might be to some extent) then engine noise could be an indicator of an oils effectiveness which would in principle be measurable, and a whole new OCD arena trembles before the analytical power of the smartphone app.
Re: Low Noise Oil [Re: Ducked] #4674157
02/22/18 10:07 AM
02/22/18 10:07 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Lucas is heavy , detergentless oil.
Yes, putting a quart of 20w-50 would be entirely more beneficial than lucas.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Low Noise Oil [Re: Miller88] #4674168
02/22/18 10:29 AM
02/22/18 10:29 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
"putting a quart of 20w-50" in what?
I was comparing the CPC low noise 5W50 stuff pictured above with the CPC 20W50 stuff pictured above, because thats a more relevent comparison, and because I know nothing about Lucas. I suppose it was a bit ambiguous, though.
Re: Low Noise Oil [Re: Ducked] #4674189
02/22/18 10:54 AM
02/22/18 10:54 AM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
Putting a quart of 20w-50 would be better than a quart of lucas
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Low Noise Oil [Re: Ducked] #4674390
02/22/18 01:38 PM
02/22/18 01:38 PM
DC
fredly Offline
fredly  Offline
DC
Are you guys just figuring out that all the ridiculous claims oil makers make are complete nonsense? Three basic grades of motor oil, they are light, medium and heavy.
