Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
How bout them Patriots
by 53' Stude. 12/16/18 06:36 PM
Hand held Ham radio suggestions
by littleant. 12/16/18 05:20 PM
Ford 2.3 EB's using 87 vs 91/93 octane
by Whimsey. 12/16/18 04:48 PM
Oil analysis pump tube?
by maximum6. 12/16/18 03:56 PM
Mahle charcoal lined filter..the best!
by TiGeo. 12/16/18 03:45 PM
Diesel engines and emissions
by spasm3. 12/16/18 03:31 PM
Experiment time
by 53' Stude. 12/16/18 02:52 PM
2019 2.7L EB - Edge ST & Catch Can
by -SyN-. 12/16/18 02:51 PM
15 Grand Caravan
by zrxkawboy. 12/16/18 02:18 PM
Brandon9797, Landngroove, DanielH, Cpcz9382, PPWarrior
66699 Registered Users
106 registered members (A310, 69Torino, AP9, ABomb369, amblerman, 13 invisible), 1,924 guests, and 42 spiders.
Topics295,166
Posts4,929,017
Members66,699
Most Online2,553
Oct 27th, 2018
My engine knocking...video inside... #4685865
03/06/18 02:57 AM
03/06/18 02:57 AM
NY
TurboTravis Offline OP
NY
The long story short is that I got this car (2000 Accord 4cyl) from a friend awhile back, he got rid of it because it started making this noise (nearly instantly) during the short time he owned it. I don't blame him, I would of gotten rid of it also!
Anyway, I have driven this car over 13K miles in this condition. It has not gotten worse. Here is a list of what it is NOT-
-It's not valve adjustment as I have checked/adjusted it twice.
-It's not a timing component as I have replaced the timing belt, water pump, etc.
-It's not the balance shafts, as I have removed the belt and it did not change. It may of gotten a little better with the belt removed but that is probably in my head.
-I do not think it's a rod bearing, as it does not change at all when removing spark plug wires one at a time. I have even run the engine without a spark plug at a time, no change.
-It does not change warm or cold. It may be a little worse cold, but not much at all.
-I have had a UOA done, and it did not show wear that suggested something is failing.
-It's not the camshaft loose.
-The flexplate to tq converter hardware is tight.
Honestly, I think it's a wrist pin, bad piston slap, or perhaps flexplate/tq converter related. Not too worried about it as it's not worth taking stuff apart to search for it (the car is not worth that effort), but it is hard not to wonder.
Anyway, here is the video.
https://youtu.be/kn-0hdLCBzQ
-Travis
Re: My engine knocking...video inside... [Re: TurboTravis] #4685866
03/06/18 02:58 AM
03/06/18 02:58 AM
NY
NY
For whatever it's worth, I have seen other videos on youtube of Accords of the same era, making the same noise, however no cause was mentioned.
Re: My engine knocking...video inside... [Re: TurboTravis] #4685885
03/06/18 04:18 AM
03/06/18 04:18 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
It sounds like something in the exhaust system...somewhere up close to the engine. Maybe a heat shield?
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: My engine knocking...video inside... [Re: TurboTravis] #4685902
03/06/18 05:30 AM
03/06/18 05:30 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
If you like, you might throw in a bottle of STP oil treatment, the old style with the consistency of honey, and see if it can quiet it down. Also, have you tried a 10W-40 weight oil?
If you want the job done right......do it yourself.
Re: My engine knocking...video inside... [Re: Char Baby] #4686009
03/06/18 08:26 AM
03/06/18 08:26 AM
Canada
Run Offline
Run  Offline
Canada
This would be my guess also.
03 Neon 2.0 - VSP 5W-30 Pentius XL
Re: My engine knocking...video inside... [Re: Char Baby] #4686054
03/06/18 09:22 AM
03/06/18 09:22 AM
NY
NY
The entire exhaust is brand new sir (noise was there before and after).
Re: My engine knocking...video inside... [Re: Snagglefoot] #4686056
03/06/18 09:23 AM
03/06/18 09:23 AM
NY
NY
I have tried many additives (mostly for fun), and I currently run 40 or 50 weight oil. It seems quieter with thicker oil but it could be in my head.
Re: My engine knocking...video inside... [Re: TurboTravis] #4686083
03/06/18 09:57 AM
03/06/18 09:57 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
How much of the exhaust got replaced? Sounds like an exhaust leak between the manifold and front pipe.
Could also be a leaking exhaust valve. Have you done a compression test?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: My engine knocking...video inside... [Re: mightymousetech] #4686088
03/06/18 10:04 AM
03/06/18 10:04 AM
NY
NY
As stated above, the entire exhaust is new. This is not an exhaust leak.
Re: My engine knocking...video inside... [Re: TurboTravis] #4686089
03/06/18 10:05 AM
03/06/18 10:05 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
I'm pretty sure that's the same sound my old Accord has made for the past 125,000 miles or more. Does it seem to be originating from the right (passenger) side of the engine slightly below the head?
It is interesting that you say it isn't related to the balance shafts, when I replaced the oil pump o-rings on my Accord this last summer I noticed that there seemed to be excessive axial play in the balance shafts but I wasn't sure. But if you removed the balance shaft belt and it still made that noise then obviously that isn't it.
On my car no oil grade has made any kind of difference in the noise. It is indeed somewhat worse when cold but it is still very noticeable when warm. And as your friend noted it did come on suddenly, got worse for a while, then for the past many miles it has stayed constant. I too have no other symptoms of a problem except the noise, the engine seems to work perfectly fine otherwise.
I too have a relatively new exhaust system (OEM Honda) and I even put on a new exhaust manifold thinking that might be the cause. It was not.
Like was asked did you do a compression or leakdown test?
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: My engine knocking...video inside... [Re: TurboTravis] #4686098
03/06/18 10:18 AM
03/06/18 10:18 AM
Upper Midwest
Upper Midwest
FWIW here is my old thread from 10 years ago on the subject:
https://www.bobistheoilguy.com/forums/ub...ock#Post1134721
1994 BMW 530i, 238K
Re: My engine knocking...video inside... [Re: kschachn] #4686099
03/06/18 10:19 AM
03/06/18 10:19 AM
NY
NY
Thanks for your input! My problem sounds identical to yours.
The compression/leakdown are well within limits (leakdown was under 10 percent on all cylinders).
Re: My engine knocking...video inside... [Re: TurboTravis] #4686100
03/06/18 10:20 AM
03/06/18 10:20 AM
Phoenix, Arizona - USA
SirTanon Offline
SirTanon  Offline
Bad motor mount? Revving the engine causes a sudden change in torque and vibration frequency. Have you had someone watch the engine with the hood up while you rev it?
Just a guess
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 266,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 60,000mi
Re: My engine knocking...video inside... [Re: TurboTravis] #4686103
03/06/18 10:24 AM
03/06/18 10:24 AM
Margate England
Claud Offline
Claud  Offline
Margate England
I have no idea what might be causing the noise, but I doubt it's a bad bearing, it would have failed long ago if that was the case.
If you can put up with the noise, and the engine runs smooth and returns decent gas mileage, don't sweat it, but have a back up plan in case it suddenly leaves you stranded. If it does please let us know what was making the noise.
Claud.
Re: My engine knocking...video inside... [Re: TurboTravis] #4686187
03/06/18 11:30 AM
03/06/18 11:30 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
collapsed piston skirt?
Loose core in primary cat?
Loose/cracked motor mount?
(Carefully) Open filter and look in pleats - UOA wont evidence catastrophic component failure - all that metal ends up in the filter, not the oil.
I had an EJ Subaru that did that and it was diagnosed as a wrist pin by a Subaru Master. I was not convinced of that.
Is it easy enough to drop the oil pan and look at the rod bigs?
2014 Nissan Rogue S CVT, OC#10 47272mi-QSUD10W30+5w20 Toughguard Filter; '17 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
