help me choose...
by chaindrive
06/21/18 04:07 PM
France F1 Grand Prix
by DeepFriar
06/21/18 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
06/21/18 03:16 PM
Best additive in oil to clean sludge?
by ffgb
06/21/18 02:19 PM
Who is a Dirt Track regular?
by thooks
06/21/18 01:39 PM
eco plug oil plug video is restricted
by edwardh1
06/21/18 01:27 PM
Political comments
by ridgerunner
06/21/18 01:23 PM
My Ford orange turned pink
by BeerCan
06/21/18 12:45 PM
Any plants/garden experts?
by maverickfhs
06/21/18 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
06/21/18 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
06/21/18 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
06/21/18 11:20 AM
Kia ATF - OEM, Eneos, Maxlife - TDS - DIFFERENT!
by Spddm0n
06/21/18 11:19 AM
Dillon Precision Is Simply The Best!
by 2015_PSD
06/21/18 11:17 AM
First OCI - 156k miles Prius
by Greg L
06/21/18 11:11 AM
Brake Squeal on Rear Discs
by BlitzPuppet
06/21/18 11:10 AM
Coolant leak.
by LeakySeals
06/21/18 11:05 AM
Looking for a Home Depot coupon 10% off?
by GravelRoad
06/21/18 10:59 AM
Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
116 registered (28oz, Astro_Guy, 2dogs, aquariuscsm, 77GrandPrix, azjake, 12 invisible), 1676 Guests and 45 Spiders online.
65286 Members
67 Forums
285719 Topics
#4684783 - 03/05/18 04:06 AM Replacing coils w/ struts; All 4 or none?
dlundblad Online   happy
Loc: Indiana
The Volvo in my signature is due for some fresh suspension. Thinking either Sachs or Bilstein Tourings.
I can get "loaded" Sachs with the coil ready to install or I can get just the strut itself and swap everything over.
Question being, would I run into any issues replacing just the front coils, but not the rear?
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4684803 - 03/05/18 05:49 AM Re: Replacing coils w/ struts; All 4 or none? [Re: dlundblad]
Billbert Online   content
Loc: California
you are likely to have an increased ride height in the front of your car, it will throw off the headlight adjustment and you will get a bit of the (lowrider look) without the car being low. Best to replace all 4 springs.
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
#4684829 - 03/05/18 06:37 AM Re: Replacing coils w/ struts; All 4 or none? [Re: Billbert]
Trav Offline
Loc: MA, Mittelfranken.de
+1 The springs are 16 years old and definitely sagging, you don't notice it as they are all sagging at the same rate.
You could do the fronts with the coils as a unit and buy the springs extra for the rears if they don't sell an assembly. Look at Lesj÷fors Springs if Sachs doesn't make them.
Make sure to get any dot colors of the old coils if there are any Lesj÷fors make to exact OE.
#4684957 - 03/05/18 09:12 AM Re: Replacing coils w/ struts; All 4 or none? [Re: dlundblad]
maxdustington Online   content
Loc: Toronna
You should do all four, it would be weird to have the front stiff and the rear bouncy.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
#4685119 - 03/05/18 11:51 AM Re: Replacing coils w/ struts; All 4 or none? [Re: dlundblad]
jaj Offline
Loc: Vancouver, Canada
If it were I, because it sounds like you don't need springs, I wouldn't replace them. However, if you're doing the work yourself and you like the convenience of the full corner module for the front, then do the fronts first and see how if ride height changes. If the front end rides higher, then replace the rear springs when you do the rear end, but if the car's still level, then just replace the rear shocks.
#4685139 - 03/05/18 12:12 PM Re: Replacing coils w/ struts; All 4 or none? [Re: jaj]
Loc: Toronna
A few summers ago I had a 2000 Golf that I put new struts and rebuilt the front suspension. I put that entire suspension on a 2003 Jetta a year later but replaced the springs with low mileage used neuspeed sport springs that I got off of kijiji. The springs made more of a difference in the way the car felt more than any of the other stuff, and the springs were like 1/3 the cost of the other components (bilstein touring stuts and an IDparts front end kit). I know that I replaced worn sport springs with new, stiffer sport springs but the car did not crash over bumps and actually absorbed some of the impacts. The car had about 195k km on it on completely stock suspension down to the tie rod ends IIRC.
I've seen people say that springs never need to be replaced, but they made my car feel brand new. I know factory springs are expensive, but you can always get good quality aftermarket springs for cheaper. I am not sure that you could get a stiffer spring in a stock ride height though.
#4685422 - 03/05/18 05:22 PM Re: Replacing coils w/ struts; All 4 or none? [Re: Trav]
slacktide_bitog Offline
Loc: USA
approved
Get the Sachs quick struts and then buy the rear springs too thumbsup
#4689785 - 03/09/18 04:36 PM Re: Replacing coils w/ struts; All 4 or none? [Re: dlundblad]
Loc: Indiana
Confession:
I ended up just buying the quickies for the front and shocks for the rear; no rear coils.
Between the replacement control arm/ ball joint and 4 corners of suspension, I'm at $900. I'll take some measurements and if it looks to be needed, I'll get some Lesjofors rears for $70 each. At the moment, the rear looks to be higher than the front so we shall see. shrug
They were supposed to be in today, but they look to be held up on the east coast from weather.
Edited by dlundblad (03/09/18 04:41 PM)
