Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
19 registered members (billt460, ctechbob, dlundblad, avi1777, cjolson140, 2 invisible), 542 guests, and 55 spiders.
Topics286,171
Posts4,903,552
Members67,572
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Venting my New Dryer #4675919
02/23/18 10:05 PM
02/23/18 10:05 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Just purchased a new dryer and trying to upgrade my venting system. I have rigid 4" pipe on about a 20 ft run from laundry room to outside. My problem is getting from the back of my dryer to the straight run. Here are some pictures. Feel free to jump in. I HATE flex ducting. Opinions? I can't cut any farther to the right as the current cut is right up against the floor joist. I can cut more to the left. You can see my 4" rigid pipe is pretty tight as it is. The vent in the dryer will not line up with the current hole as it is more to the right and I can't cut the floor joist.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Venting my New Dryer [Re: Gebo] #4675941
02/23/18 10:22 PM
02/23/18 10:22 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Interesting shape for the cutout; never seen that before. Most people like squares, rectangles, and circles.
Re: Venting my New Dryer [Re: Gebo] #4675946
02/23/18 10:26 PM
02/23/18 10:26 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
I mean you can buy a bunch of rigid pipe and make it work or use flex.
Just make sure the flex is fully stretched to improve airflow.
Those seem to be the only options unless you are willing to run vent pipe inside the wall and up through the ceiling.
Re: Venting my New Dryer [Re: Gebo] #4675947
02/23/18 10:27 PM
02/23/18 10:27 PM
Tennessee
SWS Offline
SWS  Offline
Tennessee
Maybe I'm wrong, but it looks like 3 elbows are needed...?
Re: Venting my New Dryer [Re: Gebo] #4675950
02/23/18 10:30 PM
02/23/18 10:30 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I think there are some swiveling ones available with some adjustment in them. that gas line sure looks twisted!
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Venting my New Dryer [Re: Gebo] #4675958
02/23/18 10:34 PM
02/23/18 10:34 PM
PimTac Offline
PimTac  Offline
Seems like you can go solid to just above the floor then flex to the dryer. That 2x4 in the back is useless. Looks like its detached from the stud.
Is this on a upper floor?
Cannot see signatures any longer so it doesn’t matter.
Re: Venting my New Dryer [Re: Gebo] #4675960
02/23/18 10:36 PM
02/23/18 10:36 PM
windsor, ontario, canada.
yeti Offline
yeti  Offline
check out the copper line. could become a problem.
good luck with the job.
"there is no sense in having an argument with a man so stupid, he doesn't know you have the better of him." -- john raper
Re: Venting my New Dryer [Re: Gebo] #4675965
02/23/18 10:44 PM
02/23/18 10:44 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Rest easy. Copper line is non-functional. It was from 15 years ago when I had propane gas dryer.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Venting my New Dryer [Re: das_peikko] #4675967
02/23/18 10:47 PM
02/23/18 10:47 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
My 3 year old daughter did the cutting. She did do a nice sweeping curve. She was gonna make one big circle but she hit the floor joist on that right side. grin
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Re: Venting my New Dryer [Re: Gebo] #4675990
02/23/18 11:16 PM
02/23/18 11:16 PM
USA
oldhp Offline
oldhp  Offline
USA
I think I would build a raised platform from 2"x 10"/3/4" plywood to gain more clearance for venting. Make a easy opened access panel at bottom to hook up the vent when dryer is setting there. Does the dryer have a optional bottom vent outlet? Mine did. If so you could use that outlet. Raising the washer/dryer would also help the bending over stuff. Can you return dryer and get a bottom vent if yours doesn't have one?
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: Venting my New Dryer [Re: Gebo] #4675998
02/23/18 11:30 PM
02/23/18 11:30 PM
PimTac Offline
PimTac  Offline
Just looking at it some more, I think one adjustable elbow to get it pointing up and then flex the rest of the way. Get a hinged cover plate to hide the gap where the duct comes through the floor. Covering up the rest of the hole will finish it off.
Re: Venting my New Dryer [Re: Gebo] #4676014
02/23/18 11:48 PM
02/23/18 11:48 PM
MI
doitmyself Offline
doitmyself  Offline
MI
It looks like you have a number of challenges.
- Look at the dryer owners manual to determine longest allowable vent length. It varies by brand and each elbow (90 or 45) reduces the allowable length considerably. At 20 ft. in your OP, you are getting close to maximum with any elbows. There are long vent dryer models and booster fans. Whether you use flexible metal or 3 els. described above by SWS, you need to adhere to maximum length guidelines.
- Duct hidden within walls/floors must be rigid. UL transition duct from dryer to rigid can be flexible.
- Floor trusses(not joists)..... any chance you can re route the rigid pipe in the floor trusses to come up further to the right. This would require a new hole.
- I would explore the products of companies like Builders Best and maybe Dundas Jafine to look for problem solver products.
http://www.buildersbest.com/product-industry/dryer-vent-kit/
Here's one example of UL listed semi rigid flexible transition duct:
EDIT: just noticed that the final piece under the floor is an adjustable elbow. You should be able to make it turn up a bit to allow smoother transition to the flex pipe.
Re: Venting my New Dryer [Re: Reddy45] #4676015
02/23/18 11:53 PM
02/23/18 11:53 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Actually - Use the all-aluminum stuff (not the shiny plastic tubing with a wire wound in it)
and leave it fully collapsed so there's no ridges inside. Use the shortest piece possible.
Evil stuff:
The GOOD stuff:
Re: Venting my New Dryer [Re: Gebo] #4676020
02/24/18 12:05 AM
02/24/18 12:05 AM
Minnesota
bruckus Offline
bruckus  Offline
Minnesota
My last dryer allowed me to vent downward by installing an elbow This way it vents out the bottom and not the back. Maybe then it would move farther left. Just a thought. Thats how I did mine and then you can push dryer right against the wall.
Re: Venting my New Dryer [Re: Gebo] #4676047
02/24/18 01:12 AM
02/24/18 01:12 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
In that case I would say it's very innovative and artistic. smile
Page 1 of 3 1 2 3
