Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
90 registered members (2004tdigls, 69GTX, 2003f7, 53' Stude, 97K15004WD, 8 invisible), 1,964 guests, and 39 spiders.
Topics295,123
Posts4,928,097
Members66,688
Most Online2,553
Oct 27th, 2018
Honda DW-1 UOA 35k miles w/Pics #4675427
02/23/18 11:54 AM
02/23/18 11:54 AM
Pacific NW USA
GemStater Offline OP
Pacific NW USA
For what it's worth, here is an ATF Used Oil Analysis report from my recently purchased 2006 Accord.
This oil was confirmed to the best of my ability with the Honda dealer who installed it confirming it to be Genuine Honda DW-1.
This DW-1 was installed by Manly Honda of Santa Rosa CA on June 19th 2015 at 80,685 miles. I beleive this was the first transsmission service.
The customer was charged for 12 quarts of ATF on the service invoice.
Manly Honda also use/installed the following additives at the time of this transmission service:
- PN 106 BG Quick Clean for Transmissoins
- PN 310 BG ATC Automatic Transmission Conditioner
I am aware and fully understand that the Honda Dealer's use of aftermarket oil additives has somewhat skewed results of this UOA.
I got the UOA done because I was curious what the Viscosity of the ATF looked like after 35k miles and what the wear numbers looked like. The only thing Polaris flagged as abnormal is the viscosity being "Moderately Low". The only data I can seem to find on Honda DW-1 is an MSDS sheet which puts the viscosity at 6.83 @ 100C. Don't know if the lower viscosity condition on this UOA is from the DW-1 fluid shearing and or the aftermarket additives diluting the formulation?
Since purchasing this car, I've personally performed a 3/3 fluid drain and fill, ATF filter change and replaced both pressure switches.
Transmission BAYA UOA #1
Vehicle----------2006 Honda Accord EX-L,
Engine-----------J30A5 3.0L VTEC, 6 cyl
Trans------------BAYA Five Speed Automatic
OIL--------------Honda (Idemitsu) DW-1
Oil additive----- PN 310 BG ATC Automatic Transmission Conditioner
Make-up oil----N/A
Oil filter---------Honda OEM #25450-RAY-003
Miles on oil------34,868
Miles on vehicle---115,553
UOA by Polaris Labs private label program, Oil Analyzers Inc:
WEAR METALS (PPM)
iron-------------------77
chromium-------------0
nickel------------------0
aluminum-------------85
copper----------------15
lead-------------------3
tin---------------------0
cadmium--------------0
silver------------------0
vanadium-------------0
Contaminant Metals (PPM)
silicon------------------16
sodium----------------4
potassium-------------2
Multi-Source Metals (PPM)
titanium-----------------0
molybdenum-------------1
antimony-----------------0
manganese--------------1
lithium-------------------0
boron---------------------261
Additive Metals (PPM)
magnesium----------216
calcium---------------374
barium-----------------1
phosphorus--------127
zinc-----------------344
fuel-----------------N/A
visc40---------------N/A
visc100--------------5.4 (rated at 6.83 as per Honda DW-1/IDEMITSU MSDS)
water----------------<.1
soot/solids----------N/A
change---------------YES
oxida-----------------35
nitr------------------8
TBN------------------N/A
Visual condition of Honda DW-1 at time of sample:
Pic of my newly Purchased 2006 Honda Accord EX-L 3.0L w/Navigation - 115k mi.
06 Honda Accord EX-L 3.0L Mobil 0W-20 AFE | Fram XG7313
02 Dodge Grand Caravan 3.3L - PP 5W-30 | Fram Ultra XG8A
69 Plymouth Road Runner 383 - Restoration
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675435
02/23/18 12:02 PM
02/23/18 12:02 PM
Pacific NW USA
Pacific NW USA
For comparison, this recent 2012 Honda Pilot 32k DW-1 UOA had a viscosity of 4.83 @ 100C ->
https://www.bobistheoilguy.com/forums/ub...ion#Post4597568
Questions:
1) Is there a VOA of DW-1 anywhere?
2) Any other DW-1 UOAs?
Curious if DW-1 is prone to shearing?
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675446
02/23/18 12:14 PM
02/23/18 12:14 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Thanks for posting this.
I'll raise a glass of ATF with you, cheers!
1997 Maxima 190k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 193k, VWB 5w20 + SSS 10w40, MGL4967
Re: Honda DW-1 UOA 35k miles w/Pics [Re: zorobabel] #4675453
02/23/18 12:20 PM
02/23/18 12:20 PM
Pacific NW USA
Pacific NW USA
You're welcome. Just don't tell the wife what I do with her glass wear grin
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675577
02/23/18 02:08 PM
02/23/18 02:08 PM
Pacific NW USA
Pacific NW USA
Just found this...
The BG ATC Transmission Conditioner has a viscosity of 6.29 @ 100C > http://www.lubri-care.com/msds/downloads/310.pdf
BG ATC link: https://www.bgprod.com/catalog/transmiss...r/#bg-product-3
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675592
02/23/18 02:28 PM
02/23/18 02:28 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Valvoline maxlife is DW1 approved. Although no uoa I change the fluid every 30K. Going on 175K on the same transmission. Shifts like butter.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Honda DW-1 UOA 35k miles w/Pics [Re: ARB1977] #4675613
02/23/18 02:56 PM
02/23/18 02:56 PM
Pacific NW USA
Pacific NW USA
Yeah, I see quite a few people using Maxlife in their Honda transmissions with good results. I prefer Amsoil Signature Series ATF in all my transmissions and that's what went back into this Honda. The Amsoil (ATF) is Honda Z1 rated having the slightly thicker viscosity my car came from the factory with. Figured a transmission with 115k, probably error on the side of thicker.
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675719
02/23/18 05:38 PM
02/23/18 05:38 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Amsoil ATF is all I use in these and most others. Line off exchange only I don't waste my time or money with almost useless drain and fills.
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675861
02/23/18 08:00 PM
02/23/18 08:00 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
I did a ATF UOA for my DW-1 drain @30,735m in my 08 CRV K24 with the 5 speed auto-though Im not completely sure the trans is the same as your V-6 accord, my results were fairly similar, aside from the additives in yours
Highlights:
AL-51
FE-40
Boron-125
Calcium-189
Mag-38
Pho-201
Zinc-94
cST vis @100c was 5.3
Flashpoint 420F
FWIW Blackstone flagged the AL as a little higher than average, but not worrisome
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Honda DW-1 UOA 35k miles w/Pics [Re: GemStater] #4675905
02/23/18 08:45 PM
02/23/18 08:45 PM
Arizona
bulwnkl Offline
bulwnkl  Offline
Arizona
2013 Ridgeline DW-1 UOA
Re: Honda DW-1 UOA 35k miles w/Pics [Re: Trav] #4677183
02/25/18 01:50 AM
02/25/18 01:50 AM
CA
The Critic Offline
The Critic  Offline
CA
A lot of the newer Honda units no longer run atf to the radiator. Which cooler lines are you using? I suppose I could tap into the line for the external filter, but that is a bit annoying and messy.
2011 Toyota Prius - 178k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 133K - Mobil 1 EP HM 5W-30
Re: Honda DW-1 UOA 35k miles w/Pics [Re: The Critic] #4677402
02/25/18 09:22 AM
02/25/18 09:22 AM
Pacific NW USA
Pacific NW USA
Correct! My application has a standalone external heat exchanger, not on the radiator, and internal, replaceable filter. I suppose a guy could try and do fluid exchange at the external exchanger, but what a pain. I opted for the costly, wasteful, Honda approved drain and fill method.
Upper left = Heat Exchanger. Lower right = filter housing
