Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
67 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 5 invisible), 771 guests, and 53 spiders.
Topics286,105
Posts4,902,665
Members67,563
Most Online2,967
Mar 10th, 2019
run straight coolant #4674320
02/22/18 12:43 PM
02/22/18 12:43 PM
Oklahoma
slomo Offline OP
slomo  Offline OP
Oklahoma
Who has done this?
Re: run straight coolant [Re: slomo] #4674324
02/22/18 12:46 PM
02/22/18 12:46 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Why would you want to so this? In general, heat transfer is compromised compared to a water mixture, as is freezing point. Most automakers specify a maximum concentration and there's a reason they do so.
For reference here are a few threads on waterless coolants, including one you started a year or two ago:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4338324/Waterless_Anti-freeze#Post4338324
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4038277/Evans_waterless_coolant#Post4038277
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3699927/Waterless_coolant#Post3699927
https://www.bobistheoilguy.com/forums/ub...ant#Post4491106
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: run straight coolant [Re: slomo] #4674326
02/22/18 12:46 PM
02/22/18 12:46 PM
NJ, USA
MotoTribologist Offline
NJ, USA
What do you mean by coolant? Are you referring to water?
Re: run straight coolant [Re: slomo] #4674329
02/22/18 12:48 PM
02/22/18 12:48 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
50/50 for me
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: run straight coolant [Re: slomo] #4674343
02/22/18 01:00 PM
02/22/18 01:00 PM
Ohio
Dave Sherman Offline
Ohio
No, because it would be expensive and pure coolant does not transfer heat as well.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: run straight coolant [Re: slomo] #4674351
02/22/18 01:05 PM
02/22/18 01:05 PM
NY, USA
windeye Offline
windeye  Offline
NY, USA
No one should be doing this. Aside from the reasons mentioned already, straight (near 100%) coolant actually has a much higher freezing point than 50/50 mixed with water. Use de-ionized water or distilled water, or buy premixed from dealer.
2000 Mazda MPV LX, 202,500 miles
2007 Mazda 3 Touring, 112,800 miles
2013 Toyota Camry XLE, 100,800 miles
Re: run straight coolant [Re: slomo] #4674367
02/22/18 01:21 PM
02/22/18 01:21 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
Never run straight coolant it doesn't transfer heat very well. Ideally straight DI water is the best coolant due to its ability to absorb heat, however using pure water leads to lubrication and oxidation issues. Most race tracks especially for motorcycles ban the use of coolant and will check you radiator to pass tech they only thing allowed is water wetter (purple ice or redline water wetter for example)
Question is why would you want to do that, just run what the OEM recommends, don't try to out think the automotive engineers, they test vehicles in severe conditions for a reason, plus running 12 or 14 quarts of pure coolant is way more expensive than diluting it.
Re: run straight coolant [Re: windeye] #4674369
02/22/18 01:22 PM
02/22/18 01:22 PM
wv
krismoriah72 Online content
krismoriah72  Online Content
wv
If you dont do a complete block flush and drain and only do the petcock or lower hose removal.. you can run straight coolant then drain at a later date and install the 50/50 mix. There is a bit of coolant that doesnt get removed in a lower radiator drain so you wont technically be running 100 percent coolant if you just fill the rad with straight unmixed coolant.
Re: run straight coolant [Re: slomo] #4674377
02/22/18 01:25 PM
02/22/18 01:25 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Is there a particular reason to ask the question?
  • 2017 Toyota Sienna
Re: run straight coolant [Re: slomo] #4674378
02/22/18 01:26 PM
02/22/18 01:26 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I ran 80-90% water + RL WW during hot summers on one of my old muscle cars that ran "hot." Would never think of running beyond 60-70% straight coolant. What's the advantage?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: run straight coolant [Re: Gimpy1] #4674380
02/22/18 01:29 PM
02/22/18 01:29 PM
DC
fredly Offline
fredly  Offline
DC
Why you think glycol coolants not allowed on race track? Reason has nothing to do with which better, reason is strict ly to do with glycol spills are very slippery. Period, end of discussion. Water wetter garbage fine for track events where you changing it out constantly. Go peddle your water wetter elsewhere.
Re: run straight coolant [Re: fredly] #4674411
02/22/18 01:54 PM
02/22/18 01:54 PM
Gimpy1 Offline
Gimpy1  Offline
Who's peddling water wetter, I simply stated what is allowed. Never said put water wetter in your radiator did I?
Re: run straight coolant [Re: slomo] #4674416
02/22/18 01:58 PM
02/22/18 01:58 PM
NJ, USA
NJ, USA
Apparently you didn't read about how the discussion (that we were all obviously having about why water wetter is so great whistle) was ended.
No need to respond further LOL
Re: run straight coolant [Re: slomo] #4674459
02/22/18 02:27 PM
02/22/18 02:27 PM
Balearic Islands , Spain
FordCapriDriver Offline
I run premixed 20-30% coolant 80/70% water green gycol coolant in everything i own.
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
Re: run straight coolant [Re: FordCapriDriver] #4674465
02/22/18 02:32 PM
02/22/18 02:32 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
if you use less than 30% coolant or more than 70% coolant it can cause issues
30/70 is a good compromise for hot climate.
70/30 is for best freezing protection
50/50 for most climates is great.
disclaimer I am talking about normal stuff, green,pink,red,orange,blue etc.
not including exotic "waterless coolant" etc.
