2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
108 registered members (28oz, 97prizm, 87sammy, 14Accent, 15 invisible), 1,974 guests, and 40 spiders.
Topics295,221
Posts4,930,285
Members66,716
Most Online2,553
Oct 27th, 2018
new oils 0/16 and in future 0/4 #4672497
02/20/18 09:13 PM
02/20/18 09:13 PM
California
Bullwinkle007 Offline OP
California
here is an interesting article, honestly, i dont care for the thin oil, obviously, only darn thing they care about is fuel mileage, not life after 100k miles
On April 1, 2013 the Society of Automotive Engineers (SAE) introduced a new viscosity grade called SAE 16. This is a new high temperature viscosity grade hence it's not 16W just simply 16 or SAE 16. This is the lowest high temerature SAE engine oil viscosity grade yet, replacing SAE 20 in this role. The introduction of this viscosity grade is another step towards motor oils providing better and better fuel economy and such oils will most likely to be first recommended by companies that emphasize fuel economy oils (e.g. Ford, Honda).
When the first SAE 16 oils will appear (likely as 0W16 and 5W16 oils) they will only be suitable to be used in vehicles where the engine is designed to operate with such a low viscosity oil. Just as 5W20 and 0W20 oils these oils will also be unsuitable to be used in older engine designs since it would not provide sufficient wear protection on operating temperature.
The number 16 itself does not have a special meaning it does not point at any specific oil property, it is only the name of the viscosity grade. SAE decided to choose a number that breaks the must-be-divisible-by-5 rule to avoid any mix-up with the winter viscosities. SAE 15 would have been easy to confuse with 15W (even though the very same problem did not influence SAE's decision when SAE 20 was introduced).
With the introduction of SAE 16 the limit on 100 C viscosity for SAE was changed from 5.6 cSt to 6.9 cSt minimum. SAE 20 oils didn't make use of this interval so far and the limits for SAE 16 partially extend to this segment. For an oil to be of SAE 16 viscosity grade its viscosity on 100 C must be between 6.1 and 8.2 mm2/s and its HTHS viscosity must be at least 2.3 mPa*s.
The official SAE viscosity grades are now 0W, 5W, 10W, 15W, 20W, 25W, 16, 20, 30, 40, 50 and 60. SAE is considering introducing the 12, 8 and 4 viscosity grades when there will be demand by the car manufacturers. This also outlines the likely direction of the lubricant development: oils will become ever thinner but their advanced chemistry must make sure that they still provide the same or better protection as their older, thicker counterparts did.
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672501
02/20/18 09:22 PM
02/20/18 09:22 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Think this was posted already. 16, 12, 8, 4 it's only a matter of time. The rationale about confusing new grades for W-grade ratings is interesting but completely rational considering the only real estate left for expansion in the J300 is smack dab in the middle of the traditional W -rating territory.
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672502
02/20/18 09:23 PM
02/20/18 09:23 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
The Japanese have been using 16-weight oil in their home market for many years, and lobbied the SAE to add that grade to the J300 spec.
The SAE has more recently approved 4, 8, and 12 grades. All of the lower number high-temperature grades step down in minimum HTHS. The KV100 ranges overlap, so the allowable HTHS is what defines the grades.
20 is 2.6 cP.
16 is 2.3
12 is 2.0
8 is 1.7
blah, blah, blah.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672544
02/20/18 09:56 PM
02/20/18 09:56 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
SAE 8 - <= 1.7cP shocked2 Oh my
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672584
02/20/18 11:00 PM
02/20/18 11:00 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Actually, it'll be great to have on hand to "blend down" all the 10W-40 and 20W-50 oils we get on sale so cheap when they get "clearanced out".....
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672693
02/21/18 05:43 AM
02/21/18 05:43 AM
Onondaga County
Miller88 Offline
Miller88  Offline
Onondaga County
Gosh dang water oil.
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672698
02/21/18 05:51 AM
02/21/18 05:51 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Old news, 12s and 8s are 3 years old...
Re: new oils 0/16 and in future 0/4 [Re: Bullwinkle007] #4672717
02/21/18 06:42 AM
02/21/18 06:42 AM
New England
Virtus_Probi Offline
New England
7.5W4 anybody?
Sorry, couldn't resist...
2014 Forester XT, 90000 miles
Last Change;
M1 5W30 d1G2
Tokyo Roki 15208AA170 filter
Re: new oils 0/16 and in future 0/4 [Re: Linctex] #4673421
02/21/18 03:25 PM
02/21/18 03:25 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
That's what I'm talking about! And they'll most likely be very high quality synthetic formulas with minimal VII reliance hide
