Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
40 registered members (Bjornviken, Ablebody, andyd, 7 invisible), 952 guests, and 34 spiders.
Topics290,743
Posts4,849,431
Members66,033
Most Online3,590
Jan 24th, 2017
Removing Catalytic Converters Reduces Gas Mileage? #4672344
02/20/18 08:11 PM
02/20/18 08:11 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
I was talking to a mechanic/technician today regarding removing both my rear cats off of my 2000 F150 4.6 V8. He told me if I did that ,that I would get worse gas mileage. Is this an actual fact?
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672354
02/20/18 08:24 PM
02/20/18 08:24 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
I vote false; although your OBDII system is not gonna like your non-functioning cats. It should throw codes and illuminate the MIL for loss of efficiency from the cats
2019 Cherokee, 2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672363
02/20/18 08:30 PM
02/20/18 08:30 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
you wanna max out the cats. Pull the Vacuum line off the fuel pressure regulator and drive around moderately to load up the cats with a little richness. Reconnect and take the car for a 1/2-3/4 hr drive in a lower gear that will allow you to run the engine at high RPM and not get arrested. Its a hold over from carb days. AKA the Italian tuneup. The engine management wants to see those cats.New O2 sensors up front may help. Taking off the cats may probably throw the timing and fuel maps off is a wild guess.
Thick oil is better grin2
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672366
02/20/18 08:39 PM
02/20/18 08:39 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
I would say 'possibly'. Your exhaust system is designed to provide an optimum amount of back pressure. Too little, and the engine will lose low-end torque (and thus use more fuel at low RPM). The cats provide some of the back pressure, so removing them may hurt idle quality and low-end torque. (The advantage would come at the top end, where the reduced back pressure would result in better flow and thus more HP at higher RPM.) It's a truck, not a race car - I'd leave them in place.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672382
02/20/18 08:49 PM
02/20/18 08:49 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Removing the secondary catalysts is going to provide nothing but a stronger exhaust note and will require a tuning device to disable the rear monitors or anti-foulers to trick the ECM.
What are you trying to accomplish?
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: OVERKILL] #4672394
02/20/18 09:03 PM
02/20/18 09:03 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
looks like he wants to pay a huge fine for tampering with emissions equipment.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672414
02/20/18 09:12 PM
02/20/18 09:12 PM
Tennessee, United States
ZraHamilton Offline
ZraHamilton  Offline
Exhaust systems do not need any backpressure at all to run right. Look at the video made by Engineering Explained. Exhaust VELOCITY is needed for low-end torque, not backpressure. However, to get higher exhaust velocity, the diameter of the pipe must be decreased, and a negative consequence is increased backpressure. When tuning an exhaust, you have to find a balance between sufficient exhaust velocity for low rpms, and the least backpressure possible for high rpms. If removing the cats doesn't decrease the velocity, then it wouldn't lose any low-end torque or mpgs.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672427
02/20/18 09:21 PM
02/20/18 09:21 PM
ZraHamilton Offline
ZraHamilton  Offline
Also, where I live, there are no emissions requirements, so a lot of people drive around without cats lol. There are a lot of diesels blowing black smoke everywhere too.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: OVERKILL] #4672450
02/20/18 09:40 PM
02/20/18 09:40 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
Better airflow equating to more HP.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: ZraHamilton] #4672452
02/20/18 09:41 PM
02/20/18 09:41 PM
Chris142 Offline
Chris142  Offline
does not matter. It's still against federal law to tamper with emissions.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672467
02/20/18 09:51 PM
02/20/18 09:51 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Yeah, that's gonna be another monumental waste of money.
We have talked about this how many times now? Buy a Lightning, you can gear this thing to the moon with 4.56's, spend 2K on a full custom tune with programmer, another 2K on a full exhaust system with shorty headers and you still won't make as much power as a stock PI 5.4L and a Lightning bone stock, would decimate you in every possible metric and have cost you less money than what'd you'll have into this rig.
This isn't a 302 where you can toss heads/cam/intake on it and make >300HP for a couple K. I've been there and done that. The 4.6L Modular is expensive to build and your best improvement is going to come from forced induction.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: OVERKILL] #4672474
02/20/18 09:57 PM
02/20/18 09:57 PM
Florida
lawnguy Offline OP
lawnguy  Offline OP
Florida
Got it. Thanks OverKill!
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: tomcat27] #4672478
02/20/18 10:01 PM
02/20/18 10:01 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
If the ECU throws trouble-codes it may also go into a semi-limp mode which certainly could hurt engine efficiency and gas mileage.
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: ZraHamilton] #4672481
02/20/18 10:03 PM
02/20/18 10:03 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
Agreed, it's not the back pressure itself, but the velocity of the exhaust gas (which is, of course, dependent on the back pressure). Think of trying to blow through a straw that's too bid - the air velocity will be quite low. I believe that the exhaust system is designed around the cats such that exhaust gas velocity is maximized for idle and low RPM. Without the restriction of the cats, the exhaust gas velocity may be compromised. Make sense?
Re: Removing Catalytic Converters Reduces Gas Mileage? [Re: lawnguy] #4672482
02/20/18 10:04 PM
02/20/18 10:04 PM
Al
cashmoney Offline
cashmoney  Offline
Al
There are more than a few donkey holes out there these days illegally jacking with their exhaust systems to make their vehicle louder, supposedly faster (but mostly not really) and most impressively to make thick black smoke. The extra noise, pollution, smoke, and the clearly evident obnoxious stupidity and insecure selfishness that goes with it is very impressive.
