The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
84 registered members (2002 Maxima SE, 08z06, 4WD, 2010Civic, 77GrandPrix, 53' Stude, 5 invisible), 1,588 guests, and 68 spiders.
Topics290,728
Posts4,849,192
Members66,021
Most Online3,590
Jan 24th, 2017
'02 Accord V6 Timing Belt Job ? #4672122
02/20/18 05:12 PM
02/20/18 05:12 PM
northern Alabama
benjamming Offline OP
northern Alabama
About to do the timing belt for the 2nd time on my J30A1 V6 engine at 240k miles & almost 18 years old. It was previously changed at 140k miles in 2010-May. Two pictures - one of the crankshaft white mark almost aligned (need slightly more clockwise rotation to be perfect) with the pointer & another picture of the rear camshaft pulley mark aligned (very well I think) with the rear upper cover mark. Am I good to proceed with removing the belt (and water pump, etc.)? In other words, which one rules? Is the crankshaft white mark to get you close & then the rear camshaft pulley mark the more precise locator, vice versa, or is something wrong?
Thanks.
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672165
02/20/18 05:39 PM
02/20/18 05:39 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
The cam mark is not aligned either from the picture, move the crank a hair then look again.
Edit: The black pointer on the cam should fill the V cutout. See it?
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672178
02/20/18 05:48 PM
02/20/18 05:48 PM
MN
14Accent Offline
14Accent  Offline
MN
Why are you trying to align it with the covers on? Take it apart so you can see.
I never line up a J-series before removing the balancer and covers. Once I can see the ACTUAL mark on the crank and cams is when I remove the belt.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: '02 Accord V6 Timing Belt Job ? [Re: benjamming] #4672224
02/20/18 06:30 PM
02/20/18 06:30 PM
Virginia
GlazeB Offline
GlazeB  Offline
Virginia
Line the crank mark then remove the 2 upper timing belt covers. There's a line cast into the backside of the timing covers.
2006 Toyota Corolla 270k
2005 Toyota Tacoma 137k
2008 Honda Pilot 101k
1978 Jeep Cj7
