Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
102 registered members (aquariuscsm, 928, Ag76, Alfred_B, Aero540T, Altima2, 12 invisible), 2,095 guests, and 58 spiders.
Topics286,236
Posts4,904,891
Members67,582
Most Online2,967
Mar 10th, 2019
Zerex G-05 and Asian Formula interaction #4666957
02/15/18 04:51 PM
02/15/18 04:51 PM
Central Texas
Brian553 Offline OP
Brian553  Offline OP
Central Texas
I understand that Dex-cool formulas, which are a type of OAT, should not be mixed with HOAT formulas, nor IAT formulas.
But I cannot find out if Zerex Asian formula will react or interact with Zerex G-05.
The non-technical differences between these are that one is Phosphate included (Asian), and one is Silicate included (G-05).
Both are HOAT antifreeze. The Phos or Silicate are the inorganic additives that define it as a Hybrid, as opposed to an OAT.
Dex-cool OAT is a different organic acid chemistry to modern HOATs.
But what about HOATs interacting negatively with other HOATs?
Do either of these, Zerex G-05 or Zerex Asian Formula have anything in them that would interact for a negative outcome in nominal engine operation, and if so, what would it be and do?
Let me get this out of the way before it is suggested; yes, I know you can flush old antifreeze out and put in fresh. Such method is good, but not the object of this discussion/thread.
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4666961
02/15/18 04:55 PM
02/15/18 04:55 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
I've heard of people mistakenly adding conventional green to Mazda/Ford FL22 & Nissan PHOAT antifreeze, not realizing they weren't the same, but no bad effects happened. Conventional & Dexcool is a different story... puke I still wouldn't mix them, the mix wouldn't have the same long lasting characteristics of a totally PHOAT solution.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4666982
02/15/18 05:10 PM
02/15/18 05:10 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
If you referring to your Toyota vehicle, use the Zerex Asian. Toyota doesn't want silicate coolant used in its products.
Re: Zerex G-05 and Asian Formula interaction [Re: Yah-Tah-Hey] #4666990
02/15/18 05:24 PM
02/15/18 05:24 PM
Central Texas
Brian553 Offline OP
Brian553  Offline OP
Central Texas
No, not really, I ask because I'm frustrated at coming up essentially empty, so I decided to ask. Inquisitive by nature.
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4667003
02/15/18 05:39 PM
02/15/18 05:39 PM
California
nthach Online content
nthach  Online Content
California
While the Japanese has made their disdain for phosphate well known, they also don't like the borates in G-05, saying they can cause pitting of aluminum. However, I think G-05 in small amounts won't cause harm. The organic acid in G-05 and Zerex Asian Formula are the same(sodium benzoate).
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4667117
02/15/18 07:21 PM
02/15/18 07:21 PM
WI
HoosierJeeper Offline
WI
Walmart has the Asian Zerex.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4667139
02/15/18 07:40 PM
02/15/18 07:40 PM
pa
benjy Offline
benjy  Offline
pa
you gotta go walmart.com for the full strength, the already diluted 50-50 asian Zerex is on the shelf, buying full + .80 for a gallon of distilled water = more for less!!
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4667517
02/16/18 09:04 AM
02/16/18 09:04 AM
Central Texas
Brian553 Offline OP
Brian553  Offline OP
Central Texas
I meant that I was not referring to my Toyota, but instead coming up empty with regards to the question of "what happens when these two mix?"
Re: Zerex G-05 and Asian Formula interaction [Re: Brian553] #4667546
02/16/18 09:31 AM
02/16/18 09:31 AM
Canuck living in California
KrisZ Online content
KrisZ  Online Content
I don't know exactly what happens when you mix these two formulas, as I never mixed them, but they are both HOAT, so nothing catastrophic, like mixing HOAT with OAT, should happen. I think the long life aspect is lost at that point.
The safest way is not to mix at all. I've been using G-05 in my Mazda 3 for close to 10 years now, after a full flush of course, with the feared silicates, and when I changed the thermostat the internals looked pristine.
2015 Grand Caravan 3.6L - 31k miles.
2006 Mazda 3 2.0L - 171k miles
