Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
72 registered members (AdditiveOCD, AndyB, Ag76, 69GTX, 4WD, andyd, 10 invisible), 1,247 guests, and 40 spiders.
Topics295,090
Posts4,927,579
Members66,684
Most Online2,553
Oct 27th, 2018
Findings Regarding Tire Life Relative to Time #4664335
02/12/18 09:03 PM
02/12/18 09:03 PM
Iowa
Nyquist Offline OP
Nyquist  Offline OP
Iowa
So I've recently been in the market for some snow tires. These would be mounted on separate rims and only bolted on to the vehicle when inclement weather arrives. Aside from those instances, they will be stored in my garage away from UV light and any ozone producing electric motors. Given that they will likely see less than 1,500 miles each year, I decided to contact manufacturers to see what their maximum expected life is of their tires.
Bridgestone/Firestone warrants their tires up to five years and says to absolutely not run any of their tires if they are older than five years from the date of manufacture (note the manufacture date and not the purchase date). Their tech support line told me that their tires are compromised after that whether or not there are visible cracks.
Goodyear says to start inspecting them annually around year 4 for cracks and such. If no cracks are found (inside or out), continue to run them until they are about 7-10 years old depending on how and where they are stored. They typically have a 12 month warranty from date of purchase regardless of manufacture date. The bulk of their warranties are mileage-focused and are silent with regards to time.
Michelin warrants their tires for six years and says to start annually inspecting the tires around year 5 for cracks and signs of degradation. If no cracks are found (inside or out), continue to run them until they are about 10 years old. They typically have a six year warranty. They are also the only manufacturer that I've found that actually puts a mileage warranty on their winter tires. In the case of the X-Ice XI3, it is 6 years or 40,000 miles.
General and Continental mirror Michelin with regards to inspections and time. Their techs seemed very confident that their tires would last 10 years with minimal road time so long as they are away from UV light and ozone.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2017 Chevy Cruze Hatchback 1.4L (LE2) Mobil 1 5w30 w/ Wix
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664379
02/12/18 09:53 PM
02/12/18 09:53 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
It probably depends which monkey you get on the phone the day you call.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664394
02/12/18 10:15 PM
02/12/18 10:15 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
Firestone translation: We had problems with tire blowouts and now we are very conservative with our recommendations. The information I am reading to you was prepared by our legal department. grin
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664403
02/12/18 10:31 PM
02/12/18 10:31 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
No, Firestone had problems with their manufacturing processes... that's what led to the tire failures.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664406
02/12/18 10:36 PM
02/12/18 10:36 PM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
I had some very slightly used Blizzaks I wanted mounted. They had been stored indoors in plastic bags and were still in pretty much brand new condition. The first shop I went to checked the date code and refused to mount them because they were 4 years old. Second place I went to had no problem mounting them.
Re: Findings Regarding Tire Life Relative to Time [Re: mrsilv04] #4664427
02/12/18 11:27 PM
02/12/18 11:27 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
Thanks for clarifying.
2017 Elantra SE
Re: Findings Regarding Tire Life Relative to Time [Re: mrsilv04] #4664452
02/13/18 01:23 AM
02/13/18 01:23 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Doesn't seem in any way incompatible with the above statement.
IIRC this was a combination of dodgy tyres and dodgy recomendations from Ford over the minimum tyre pressures to be used in the Explorer, leading to rollovers and litigation.
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664472
02/13/18 03:42 AM
02/13/18 03:42 AM
CA
raytseng Offline
raytseng  Offline
CA
snow tires aren't suddenly going to turn into pumpkins on a magical date. Over the years in storage and use they will get harder and harder and give up their cold weather effectiveness.
This is far different than the it becomes unsafe to drive as it is still technically safe.
But if the performance of your 6 season old snow tires is now worse than the allseason regular tires you are switching out whats the point in switching them at all.
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664532
02/13/18 07:21 AM
02/13/18 07:21 AM
Great Lakes
Quattro Pete Offline
Great Lakes
While you're doing your research, it is important to differentiate between "lasting" X number of years vs "performing well" X number of years.
My current example is General Altimax Arctic. They are now 8 years old, and despite looking great (visually) and having majority of their tread still left, their winter/snow performance isn't anywhere as good as it was the first few seasons. And my usage is very similar to yours... no more than about 2K miles put on them each season, stored in a cool/dry place the rest of the time.
Also, see this recent thread:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4625189/Snow_Tire_Life_Span#Post4625189
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664558
02/13/18 07:59 AM
02/13/18 07:59 AM
Illinois
javacontour Offline
javacontour  Offline
Illinois
Just to be pedantic, what you have here are finding regarding tire manufacturer recommendations, not actual tire life relative to time.
network down, IP packets delivered via UPS -BOFH
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664615
02/13/18 09:04 AM
02/13/18 09:04 AM
New York
pbm Offline
pbm  Offline
New York
When snow tires still look fine but are 5 or 6 years old....is the general consensus to just leave them on (after winter is over) and wear them out (rather than discard them)??
'Journalism is Dead'
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664631
02/13/18 09:22 AM
02/13/18 09:22 AM
MA, USA
krzyss Offline
krzyss  Offline
MA, USA
I think it depends how much they suck in summer. I try to do this but if summer is wet then winter tires are completely out of its element and it may not be prudent to use them up, unluckily.
Krzys
Re: Findings Regarding Tire Life Relative to Time [Re: Ducked] #4664646
02/13/18 09:38 AM
02/13/18 09:38 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Corporate lawyer caution is probably why my Bridgestones (Uniquely, AFAIK) don't have a maximum pressure rating moulded into the sidewall. Not a VERY big deal, but I don't like it. Seems evasive to me.
Re: Findings Regarding Tire Life Relative to Time [Re: Nyquist] #4664679
02/13/18 10:12 AM
02/13/18 10:12 AM
Nebraska
BJD78 Offline
BJD78  Offline
Nebraska
I keep the snow tires on our Tuscon year round. Mainly drive it only in Lincoln with maybe 2-3 hiway trips during the summer of 100 miles max. Probably put about 5K on it each year. Mostly has been a school car for our HS daughter. Snows have been on for about 4 years so far. I swap out snows for all season on my other 2 but do not have spare wheels( our 1 car garage is small enough without storing 8 mounted tires. Cost about $20.00 per tire to have tires swapped out every fall and spring for our Sonata and Forester. I will likely keep the snow tires (all General arctic) for 7-8 years max.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
Re: Findings Regarding Tire Life Relative to Time [Re: Ducked] #4664781
02/13/18 12:34 PM
02/13/18 12:34 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
Not all of Firestone's tire problems were linked to the Explorer.... the Explorer fiasco was likely the highest profile one.
