Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
MikeMTL, AJ11, bandito, Spkrdctr, torchredone12
66691 Registered Users
99 registered members (4WD, 53' Stude, 2003f7, 72BBNova, ABomb369, alarmguy, 7 invisible), 1,893 guests, and 41 spiders.
Topics295,142
Posts4,928,496
Members66,691
Most Online2,553
Oct 27th, 2018
Oil Recommendation for an '86 Nissan D21 #4663881
02/12/18 12:22 PM
02/12/18 12:22 PM
TX
2012AccentSE Offline OP
TX
My dad and I have decided we're going to fix up our old family truck and get it to tip top shape in case we need a backup vehicle. The truck will be run ~5-10k miles a YEAR and will most likely sit for the remainder of the time. It's a 1986 D21 with the 3.0 VG30e v6 engine, 5 sp manual, 2wd with about 160k on the clock. What oil and filter should I throw in there? We were just using bulk quick lube conventional until it started sitting. The truck uses no oil that I can tell and no leaks. I plan on doing 1 oil change per year. The truck is for the most part mechanically sound, just not cosmetically. It does get a lifter tick on initial startup, but goes away once oil pressure builds. I was thinking M1 EP 10w30 with an Ultra filter since it will only be changed once a year. Recommendations?
2008 F150 KR 5.4L 3v
MileSyn blend 5w30
MC 820s
TCW3
2010 Corolla 1.8L
MileSyn blend 5w20
Toyota OEM
Top Tier
2014 CFMoto 650NK
Rotella T6 5w40
CFMoto OEM
Stabil
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4663900
02/12/18 12:53 PM
02/12/18 12:53 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I love hardbodies. I would be going conventional for sure because this seems like the perfect situation for synthetic oil to cause leaks.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4663901
02/12/18 12:53 PM
02/12/18 12:53 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
I'd stick with a good dino,like PYB 10W30.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4663919
02/12/18 01:11 PM
02/12/18 01:11 PM
TX
TX
What is the recommendation on a filter? I think I'm most concerned with condensation.
MileSyn blend 5w30
MC 820s
TCW3
2010 Corolla 1.8L
MileSyn blend 5w20
Toyota OEM
Top Tier
2014 CFMoto 650NK
Rotella T6 5w40
CFMoto OEM
Stabil
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4664075
02/12/18 04:02 PM
02/12/18 04:02 PM
Tn.
CourierDriver Offline
Tn.
If you live near Laredo,,most likely u could run whatever wgt oil you want,straight 30 weight comes to mind,,but most good old 10/30 any major brand would be fine
turn in your old jackets, shirts and other clothes to a Salvation Army or any homeless shelter this year...
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4664165
02/12/18 05:59 PM
02/12/18 05:59 PM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Just some typical dino between 5w30 to 10w40 every 5k and call it a day.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4664343
02/12/18 09:10 PM
02/12/18 09:10 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Whatever 10w-30 you can find on sale. I like M1 HM 10-w30 because itís a thick 30 and ACEA A3/B3. Will do just fine for an annual oil change.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4664632
02/13/18 09:22 AM
02/13/18 09:22 AM
Florida
artificialist Offline
Florida
When was your timing belt replaced? The Nissan VG-series engine is an interference engine. After 9 years, a failed timing belt destroyed my mom's 1985 Nissan Maxima. I suggest getting all OEM parts and replace the water pump when you are replacing the belt.
You shouldn't be worried about using bulk oil from quick lubes. Most Nissan V6 engines are known to go 220,000 miles using whatever bulk oil was on sale, so long as all other maintenance was performed.
High mileage oil does sound like a good idea. Walmart sells Havoline high mileage at a great price everyday.
I suggest getting a Motorcraft filter for an early Mercury Villager. They used a VG30E engine and Motorcraft filters are high quality. The filter might not be that easy to get because the Mercury Villager is almost extinct. Don't get a filter from a later model of Mercury Villager, they had a VG33E engine which used a different kind of filter.
You might have a VG30I engine instead of a VG30E engine. VG30I engines have "Electro Injection" written on the air cleaner and use throttle body injection. It isn't as good as multi port fuel injection, but it is better than having a carb.
2010 Lancer Ralliart Sportback
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4664708
02/13/18 10:41 AM
02/13/18 10:41 AM
TX
TX
I need to see if the timing belt has ever been done. Looks easy from forums. I stand corrected; I do have the 'i' VG30. I confused the 'e' for Electro-Injection. Good catch!!
MileSyn blend 5w30
MC 820s
TCW3
2010 Corolla 1.8L
MileSyn blend 5w20
Toyota OEM
Top Tier
2014 CFMoto 650NK
Rotella T6 5w40
CFMoto OEM
Stabil
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4665668
02/14/18 10:42 AM
02/14/18 10:42 AM
TX
TX
Timing belt, tensioner pulley, and water pump ordered.
MileSyn blend 5w30
MC 820s
TCW3
2010 Corolla 1.8L
MileSyn blend 5w20
Toyota OEM
Top Tier
2014 CFMoto 650NK
Rotella T6 5w40
CFMoto OEM
Stabil
Re: Oil Recommendation for an '86 Nissan D21 [Re: 2012AccentSE] #4665782
02/14/18 12:27 PM
02/14/18 12:27 PM
Ontario, Canada
AdamZ Offline
AdamZ  Offline
Ontario, Canada
My 1994 Pathfinder has over 275k miles on it now, it uses the same motor as your D21, and lived on dealer/quick lube bulk oil most of its life until I started doing it myself. I would stick to the 5w30 spec'd by the factory. I found 10w30 made mine noisier on cold starts. As for filters I'd use any filter you prefer. I tend to use the Fram TG3692 or XG3682 as they're readily available.
94 Nissan Pathfinder 493k km R.I.P.
95 Nissan Pathfinder 200k km
02 Nissan Xterra SC 170k km
04 VW Golf 2.0 245k km
